Re: Looking for GOOD air shocks ro something like that.
[Re: MidPenMopar]
#2380300
10/01/17 11:22 PM
10/01/17 11:22 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
[Re: MidPenMopar]
#2380573
10/02/17 01:50 PM
10/02/17 01:50 PM
Posts: 8,668 Buford, GA
I_bleed_MOPAR
Buford, GA
... I carry a lot of weight between people and stuff in the car and need to raise and lower it when needed. So I guess shackles are out of the question? Shackles and sidepipes Well i tried, but going in i knew it was a lost cause..... Sorry Stu. I couldn't resist. Hope you find what you need. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: MidPenMopar]
#2380627
10/02/17 03:08 PM
10/02/17 03:08 PM
Posts: 3,921 Richmond, Indiana
19swinger70
Richmond, Indiana
I had some Gabriel Hijackers on my car when i was in High School in the mid 90's. I drove that car my junior and senior year, and then 2 years after. NEVER did the air shocks fail or hurt the upper mounts. I dont know where to tell you to buy them now.
1970 340 swinger. sublime 1967 barracuda fastback BB 55 Plymouth Project
[Re: MidPenMopar]
#2381113
10/03/17 08:20 AM
10/03/17 08:20 AM
Posts: 1,646 Ringtown, Pa.
Dartsport540
Ringtown, Pa.
I have a set from NAPA on my 1973 Duster. Installed them in 1996, they still work great!!
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
[Re: Dartsport540]
#2381187
10/03/17 11:49 AM
10/03/17 11:49 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I have a set from NAPA on my 1973 Duster. Installed them in 1996, they still work great!! And I guarantee those shock are not longer available. What you will find is some cheap substitute.
[Re: MidPenMopar]
#2381621
10/04/17 06:22 AM
10/04/17 06:22 AM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
Why do you need to adjust ride height? The problem with air shocks is the upper bracket where they mount isn't made for that kind of abuse. So i have been told, but there is not any wear on that area and all looks good. I carry a lot of weight between people and stuff in the car and need to raise and lower it when needed. You do realize that the shocks with the helper springs on them that you have been trying to order are just as likely to damage the top mounts, for the same reason - the upper mounts aren't really designed to carry a load. Not that common with Mopars, but I've seen a lot of cars with air shocks or the shock helper springs snap the ear off of the lower shock bracket, too.
Free advice and worth every penny... Factory trained Slinky rewinder.........
