Flexplate #237919
02/27/09 01:56 PM
02/27/09 01:56 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
HI ,
When installing an early 360 magnum engineto an old 904, which flexplate do I use ? the one from the magnum or the LA engine ?
THanks for the info
Dan
Re: Flexplate [Re: Wedgeman] #237920
02/27/09 02:08 PM
02/27/09 02:08 PM
PA
70Duster Offline
70Duster  Offline
PA
Doesn't matter as long as the torque converter is properly balanced for the early 360 magnum.
Re: Flexplate [Re: 70Duster] #237921
02/27/09 02:17 PM
02/27/09 02:17 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
So does the magnum converter fit on my old 904 ? or do I have to balance the whole rotating assembly ?
Dan
Re: Flexplate [Re: Wedgeman] #237922
02/27/09 02:21 PM
02/27/09 02:21 PM
PA
70Duster Offline
70Duster  Offline
PA
Depends on what tranny the magnum converter is from. The other option is to use a neutrally balanced torque converter and buy a new balanced flexplate from B&M or use the weight kit and template from Mopar Performance and weld the supplied weights onto the neutrally balanced torque converter to balance to early Magnum specifications.
Re: Flexplate [Re: 70Duster] #237923
02/27/09 02:35 PM
02/27/09 02:35 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
The engine comes from a Ram truck......to give you any idea...........did not want to mess with the trans trough that swap
Dan
Re: Flexplate [Re: Wedgeman] #237924
02/27/09 02:43 PM
02/27/09 02:43 PM
PA
70Duster Offline
70Duster  Offline
PA
Sounds like the new balanced flexplate from B&M or the weight kit and template from Mopar Performance to weld the supplied weights onto the neutrally balanced torque converter will be your best options.
Re: Flexplate [Re: 70Duster] #237925
02/27/09 02:47 PM
02/27/09 02:47 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Ok.....THat's nstep 1 , now, where a balanced converter ? from the mag engine ? my old LA engine ? can get a lot of stuff from the junkyard...
Many thanks 70Duster !!!
Dan
Re: Flexplate [Re: 70Duster] #237926
02/27/09 02:48 PM
02/27/09 02:48 PM
W. Sacto CA. USA
P
phantomx Offline
phantomx  Offline
P
W. Sacto CA. USA
Do the flexplate, they work great. It will also make torque converter selection/replacement easier if you decide to change later.
Travis..
70 GTX project, orig 440-4, 4 spd, track pack, FC7, stripper/street racer special.
Re: Flexplate [Re: phantomx] #237927
02/27/09 02:52 PM
02/27/09 02:52 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Hey phantomx !
The flexplate from B&M will bolt to my 904 convert?
No need for anything else to balance ? souds just like an adaptor for 2 eras to me.....you have a part number ?
Dan
Re: Flexplate [Re: phantomx] #237928
02/27/09 02:59 PM
02/27/09 02:59 PM
Mechanic Falls, Maine
4BBodies Offline
mopar addict
4BBodies  Offline
mopar addict
I got a Hayes flexplate for my 340, and got a neutral balanced torque converter. Works great, just make sure that you get the 360 one, as they are not the same as the 340 ones.
Re: Flexplate [Re: 4BBodies] #237929
02/27/09 03:03 PM
02/27/09 03:03 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Ok......so where do I ge a neutral balance conv ?
Are they expensive ?
Can I find this in a junkyard ?
DAn
Re: Flexplate [Re: Wedgeman] #237930
02/27/09 03:06 PM
02/27/09 03:06 PM
W. Sacto CA. USA
P
phantomx Offline
phantomx  Offline
P
W. Sacto CA. USA
Your current converter is neutral balance if it came from a 273 or 318. You are kinda confusing me with the "early" magnum. Is it a magnum or an LA 360? Just know that the two are balanced different and the magnum needs the tone ring flexplate.
Travis..
Re: Flexplate [Re: Wedgeman] #237931
02/27/09 03:09 PM
02/27/09 03:09 PM
PA
70Duster Offline
70Duster  Offline
PA
DAn
Get a torque converter that lived in a 904 and was bolted to a 273 or 318. Then use the B&M flexplate that is balanced for an early magnum and you will be all set! There should be more than a few to choose from in the junkyard.
Re: Flexplate [Re: phantomx] #237932
02/27/09 03:10 PM
02/27/09 03:10 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Sorry for the confusion..
tranny was bolted to a 273 and want to hook up a 360 Mag from a ram truck.....
The way I see it, all I need is a flexplate ?
Many thanks everyone !!
Dan
Re: Flexplate [Re: Wedgeman] #237933
02/27/09 03:11 PM
02/27/09 03:11 PM
PA
70Duster Offline
70Duster  Offline
PA
You got it!
Re: Flexplate [Re: 70Duster] #237934
02/27/09 03:15 PM
02/27/09 03:15 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Great!!!!
I'll go on with the swap, heard this combo is a lot of fun......
Thanks again everyone !!
If you have any more hints on the swap, please feel free !!!!!
Dan
Re: Flexplate [Re: Wedgeman] #237935
02/27/09 03:57 PM
02/27/09 03:57 PM
scratchnfotraction Offline
you will need 360 motor mounts for the old LA style blocks to go in where a 273 was
273,318,340 are a different mount than a LA360
the mag engen will have the old LA engine mount bosses and some engine mount boss in the middle of the block for the magnum "ram" trucks mounts
B&M flex plate for 360 magnum engine will use the 273,318,340, torque converters which are nutural balance
the old 273 dist will fit in the mag engine
the old LA style timming cover and v belts all bolt on
the cam is a roller cam with a short nose and can not run a fuel pump
there are adaptors for this to run the ecentric and stock fuel pump
you will need a 360 car oil pan if you put it in a car
its a great swap with a carb/intake,elect dist,headers into an older ride
you can run the newer mini starter also which is a good upgrade for it as well
Re: Flexplate [Re: scratchnfotraction] #237936
02/27/09 04:46 PM
02/27/09 04:46 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
I'v checked for a B&M flexplate.....they offer units for the 727, but haven't seen any for 360mag/904......anyone has onther brand with part number in mind ?
Dan
Re: Flexplate [Re: Wedgeman] #237937
02/27/09 04:51 PM
02/27/09 04:51 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
The years of the engines could be a problem, in some years the 273 crankshaft has a smaller register for the converter pilot hub, to mate the 273 converter to a later LA or Magnum a spacer ring is needed.
If the Magnum is '96 or later and the crank position sensor is going to be retained the original flexplate must be retained and redrilled for the 904 converter.
Years make a difference, it's best to be specific.
Re: Flexplate [Re: John_Kunkel] #237938
02/27/09 05:10 PM
02/27/09 05:10 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
The engine comes from a '98 ram truck.....
DAn
