Re: I THINK WE`RE ON TO SOMETHING.............
[Re: Thumperdart]
#237902
02/27/09 02:08 PM
02/27/09 02:08 PM
it sure can't hurt to check the springs but, don't you think if they were an issue, you would notice float in 1st and 2nd gear also?
#237903
02/27/09 02:23 PM
02/27/09 02:23 PM
Posts: 12,419 Taxes & Virus's R-US, NY
Dragula
Ditto...
I would be looking at a fuel supply issue on the big end. I have had it, as well as many of my friends. Pump might say 140gph, yet you will find, it just might not be enough.
I had a 340 car with 3/8" fuel line and such, jetting changes made no difference in mph, car would not climb much past 1/8 in high gear only. It had a holley blue on it. I put a second one inline with the first....From one pump right into the other and up to the carb. I dropped 10 jet sizes, and mph picked up big time.
[Re: Thumperdart]
#237905
02/27/09 03:03 PM
02/27/09 03:03 PM
Posts: 4,079 Mo.
racerx
Mo.
If you`ve seen/heard my vid this pig is laying over in high gear.....I checked flash stall yesturday in 3rd and it flashes bet 4000-4500rpm`s so that seems ok. After thinking about it and talking to my machinest,I`m going to check my valve springs and see how they look and (for now) shim em up to get back my pressures since they`re 4+ years old w/LOTS of street miles. Hopefull that`s the reason it`s laying over if not, we`ll try something else. Thankxx 4 listning.
No proooblem thump.always like 2 read you'r post ![](/ubbthreads/images/graemlins/thumbs.gif)
#237906
02/27/09 03:18 PM
02/27/09 03:18 PM
Thumperdart
State of confusion
I just assumed it mattered more in high gear than down low since the motors loaded most in high gear. ![](/ubbthreads/images/graemlins/shruggy.gif) It could be fuel related but I figured if I shimmed up the springs and it picked up, then I`d put new springs on+ people have been shimming for years w/out issues. This thing 1/8th miles great that`s ANOTHER reason for my goofy thaughts. ![](/ubbthreads/images/graemlins/whistling.gif)
[Re: Thumperdart]
#237908
02/27/09 03:35 PM
02/27/09 03:35 PM
Posts: 1,260 Las Vegas NV
moparmanjames
Las Vegas NV
I just assumed it mattered more in high gear than down low since the motors loaded most in high gear. It could be fuel related but I figured if I shimmed up the springs and it picked up, then I`d put new springs on+ people have been shimming for years w/out issues. This thing 1/8th miles great that`s ANOTHER reason for my goofy thaughts.
I also think it's a fuel issue, like others have stated, engine load has very little to do with valve float, it's more of an rpm issue and if you are not having issues in the 1/8 then it's almost certainly a fuel issue.
[Re: Thumperdart]
#237909
02/27/09 03:59 PM
02/27/09 03:59 PM
Posts: 307 OH
TheBlackCar
OH
If you short shift car and ET stays same or improves, replace valve springs. Also, if it has a roller cam, pull cam and look at it, if springs are weak you will see where the lifter is landing on the backside flank.(jumping the lobe) In which case, thats why most people have lifter issues, the wheel splits after a while. As long as you claim the the springs have been in there, they are more than likely shot, unless you back off the rockers when car sits. As for the fuel possibilities, if you keep throwing jet at the carb to satisfy top end plug reading and the bottom end numbers start to falter, its fuel volume. Good Luck
[Re: Thumperdart]
#237911
02/27/09 04:29 PM
02/27/09 04:29 PM
Thankxx.....I`m no expert by any means and am open to all suggestions. It`s possibly a combinatin of ALL the above as this thing has hundreds of street miles w/open pressures bet 580-600lbs and closed #`s around 260-280. I`ll flow my pump again at the new 9 lbs. and see how long it takes to get a gal.
with an adequate pump you don't need 9 lbs of fuel pressure. volume is the key thing. if your raising fuel pressure and the e.t. improves, you need more volume. raising the pressure is nothing more than a band-aid. 7.5 lbs should me more than enough pressure if you have enough pump and proper sized fuel lines.
#237912
02/27/09 04:33 PM
02/27/09 04:33 PM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
If it's fuel delivery or shortage and that's what it sounds like to me you better get out of it quick or you'll melt spark plugs and pistons, I speak from experience....
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
[Re: 493_DART]
#237914
02/27/09 05:49 PM
02/27/09 05:49 PM
Thumperdart
State of confusion
I didn`t look at my tach through the stripe so I don`t know where I was at. In the past if I remember correctly, I went 10.13 @ 132+ w/4.11`s at 6800-7000 rpm`s if that helps.
[Re: 493_DART]
#237917
02/27/09 06:50 PM
02/27/09 06:50 PM
Thumperdart
State of confusion
Punching in my stats gave me 9.79%...... ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) ?
