Re: THINKING ABOUT GOING TO AMSOIL..........
[Re: nss guy]
#2379071
09/29/17 10:08 PM
09/29/17 10:08 PM
Thumperdart
State of confusion
I do not run that thick stuff ever and it's not available near me......So, which Amsoil is recommended.........
[Re: Thumperdart]
#2379080
09/29/17 10:34 PM
09/29/17 10:34 PM
Posts: 4,457 Washington
madscientist
Washington
I'd suggest doing a bit more research.
Get on the phone and call some people.
I wouldn't buy an oil based on price, nor would I use a group III synthetic, which I'd not really a synthetic.
[Re: madscientist]
#2379104
09/29/17 11:09 PM
09/29/17 11:09 PM
Thumperdart
State of confusion
I wouldn't buy an oil based on price, nor would I use a group III synthetic, which I'd not really a synthetic. If it was based on price, then I'd stick to Valvoline that most on here say is crap............
[Re: mopar dave]
#2379105
09/29/17 11:10 PM
09/29/17 11:10 PM
Thumperdart
State of confusion
Dom, i used to run the 15/50 Dominator by Amsoil in my small block. Holds viscosity very well. Expensive, but a great product. I will be using the Dominator 20/50 next yr. Thats what Amsoil suggested for my street/strip deal. No 20w50 ever for me but will check it out further when time permits......
[Re: Thumperdart]
#2379116
09/29/17 11:48 PM
09/29/17 11:48 PM
Posts: 234 Brisvegas, Australia
Alchemi
Viscosity needed is to an extent determined by local temperature, check out any newer glove box book - our hyundai diesel lists 10/30 for milder climates but 10/40 for hotter climates and some really thin stuff if you go below 35f - the tolerances on that particular engine are insane compared to our old stuff, measured in thousands of a mm and really tight, its a 17.3:1 25psi boost deal though
Dom are you still in Nevada? its generally hot there? maybe a 30 for winter and a 40 for summer?
If your running smoke free currently use the thinnest (within reason) that keeps your oil pressure where you like it
Maybe go have a look see over at bobistheoilguy
[Re: B5 Bee]
#2379125
09/30/17 12:13 AM
09/30/17 12:13 AM
Posts: 191 WI
mopar873
WI
[Re: B5 Bee]
#2379147
09/30/17 01:06 AM
09/30/17 01:06 AM
Posts: 6,017 Salem
Grizzly
Moparts Proctologist
Salem
Snake Oil.
Throw a jug of STP in while you're at it?
Google "Amsoil Refinery" and this is what comes up:
Mo' Farts
Moderated by "tbagger".
[Re: Thumperdart]
#2379149
09/30/17 01:08 AM
09/30/17 01:08 AM
Posts: 6,017 Salem
Grizzly
Salem
Shell or Exxon Mobil. Oil is not rocket science: they know what they are doing. Everything else on the shelf is their "seconds". I'd take the crap on the shelf at Tractor Supply or Walmart before falling for that Amsoil, Penzoil, Quaker State garbage.
Mo' Farts
[Re: Grizzly]
#2379156
09/30/17 01:30 AM
09/30/17 01:30 AM
BradH
Snake Oil.
That's a Photoshop job on the pic you posted, in case you weren't posting that as a joke. Their blending operations are in the U.S.
[Re: B5 Bee]
#2379160
09/30/17 01:35 AM
09/30/17 01:35 AM
BradH
10W-30 Yeah, try the 10w30 Dominator series. Religion, politics, and oil are three topics I usually make a point of avoiding.
[Re: BradH]
#2379163
09/30/17 01:40 AM
09/30/17 01:40 AM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Good old school Brad Penn user here
[Re: Thumperdart]
#2379201
09/30/17 10:02 AM
09/30/17 10:02 AM
crabman173
crabman173
When we did the Amsoil Mopar Engine Masters we had to use Amsoil--we went with a flat tappet cam using pretty high spring pressures IIRC like 175 seat and 450 ish open and...after break in--and all the dyno pulls we had to tear down for " tech" Those lobes were beautiful!!!! I have never seen any better we broke it in without the inners but my first and only experience with the stuff was amazing I like Brad Penn OK but now LUCAS stuff is available for about half the price and has over 3000 PPM of the good stuff--I have not had anything but beautiful normal break ins with any of the fortified oils on the market but when I can score a six pack of qts for under $30 at my engine parts wholesaler I am a happy camper Try that with Brad stuff or any of the others We have also used a ton of the LUCAS Zinc additive in 30 wt non detergent with fantastic results zero failures--we do this as it is so easy to source for customers all over the country-- I think oil is a very over rated talking point --if some is in there you will be fine --on a roller--and on flat tappets I think you really should keep some decent ZDDP oil all the time Rher Morrison always says 10W30 in anything they build and drag on I like 20W50 and if it cost me a HP or 2 who cares
[Re: nss guy]
#2379211
09/30/17 10:25 AM
09/30/17 10:25 AM
Posts: 5,895 Florida
Locomotion
Hopefully locomotion will chime, he is the amsoil guru My opinion is that a 10w-30 is a good all-around viscosity, which Amsoil has in their Dominator & Z-Rod lines. But I always wondered if the Dominator series may have less detergents or a different additive package because it is marketed as more of a "race" oil. 15w-40......maybe, but IMO 20w-50 is unnecessary, unless you need to boost pressure and/or have extra wear or run bearing clearances on the larger side. A good filter and regular oil changes are also important to long engine life with frequency determined by how hard and how often you "abuse" it. There are other good oils out there, but I always felt that Amsoil offers an extra level of protection, wear and mileage, as seen through personal experience & other sources. Unfortunately, earlier this year I was informed that Amsoil is getting out of the drag racing market, which includes my association with them. Marketing decisions can be difficult to understand, but they are what they are.
