Balancing tires question............... #2378210
09/28/17 12:28 PM
09/28/17 12:28 PM
State of confusion
Thumperdart Offline OP
State of confusion
I know it's been beaten to death about balancing slicks but what about the Hoosier QTP's.............I'm getting new tires here soon and even though I didn't balance the 28x10.5 slicks and they seem fine, was curious if the Hoosiers are similar in that respect...........thankxxx......... thumbs
Re: Balancing tires question............... [Re: Thumperdart] #2378226
09/28/17 12:47 PM
09/28/17 12:47 PM
Sounds like a relevant question to me. I don't have an answer but here is a jump start for ya.
Re: Balancing tires question............... [Re: Thumperdart] #2378228
09/28/17 12:47 PM
09/28/17 12:47 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
If they are screwed to the rims it would be worth it, no reason not to? If not I wouldn't bother because they will probably move at least on the first hit anyways.
68 Barracuda Formula S 340
Re: Balancing tires question............... [Re: Thumperdart] #2378234
09/28/17 12:51 PM
09/28/17 12:51 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
you should at least bubble balance them - and use the tape on weights on the inside of the rim - I tried once to high speed spin balance a 14 x 32 slick - that was a scary experience!
Re: Balancing tires question............... [Re: DoubleD] #2378241
09/28/17 12:57 PM
09/28/17 12:57 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Although my car is not very fast I never balance my slicks
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Balancing tires question............... [Re: Thumperdart] #2378253
09/28/17 01:11 PM
09/28/17 01:11 PM
an8sec70cuda Offline
We used to run Hoosiers on the Camaro. Never balanced a set.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Balancing tires question............... [Re: Thumperdart] #2378259
09/28/17 01:23 PM
09/28/17 01:23 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Well I have performed an experiment to answer at least in my head this debate with a few tires. First off with slicks it is pointless, after one race day they are not balanced at all, both big and small slicks seem to show the same affect. Did the same thing with a set of ET Streets, same result. After a few burnouts the balance is off. Your mileage may vary....
Re: Balancing tires question............... [Re: Thumperdart] #2378300
09/28/17 02:42 PM
09/28/17 02:42 PM
I balance all the tires I mount myself on my old bubble balancer up
I had one set of Firestone that would shake horribly unbalanced , balancing them helped but they where way out of round whiney I bought those tires from Parnelli Jones race tires in L.A. and had them ship up to me.
Back then when you bought tires at the races all the tire companies balance every set on a bubble balancer, I'm sure they still do work
Re: Balancing tires question............... [Re: Thumperdart] #2378312
09/28/17 03:16 PM
09/28/17 03:16 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Yes they still do Cab. Been on the Mickey program for a few years and they bubble balance every tire..We take them off after a few runs and guess what smile
Re: Balancing tires question............... [Re: Thumperdart] #2378350
09/28/17 04:10 PM
09/28/17 04:10 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I have my Drag Radials Road force balanced, made a big difference not shaking the car.
Re: Balancing tires question............... [Re: CSK] #2378356
09/28/17 04:18 PM
09/28/17 04:18 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
We use my bubble balancer on every set of slicks we own after I had a bad vibration years ago and lost a race because of it. I also noticed my bolts on my cars never loosen up like they did before I balanced my slicks.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Balancing tires question............... [Re: pittsburghracer] #2378367
09/28/17 04:33 PM
09/28/17 04:33 PM
State of confusion
State of confusion
Ok, so may as well balance em then and they have 8 screws per side if that matters.........got some heavy street racing action coming up and AGAIN, one of maybe 3 all motor knife throwers in a NOS turbo battle field........... realcrazy biggrin Thankxxx guys........... beer
Re: Balancing tires question............... [Re: Thumperdart] #2378377
09/28/17 04:55 PM
09/28/17 04:55 PM
Hooking it up to start with and keeping it hooked up will outrun a lot of cars on the street, huh whistling devil
Re: Balancing tires question............... [Re: Cab_Burge] #2378386
09/28/17 05:20 PM
09/28/17 05:20 PM
State of confusion
State of confusion
That's the plan AGAIN.............LOL
Re: Balancing tires question............... [Re: Bad340fish] #2378494
09/28/17 09:34 PM
09/28/17 09:34 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
iagree Unless screwed down, if you hook hard the tire is going to move which will wreck the balance.
The bigger the tire, the more they will need balancing. The MT 295s on the Cuda now, needed over 4 ounces per tire. eek
No matter the car, you will be able to feel that much on each corner. Besides, that vibration has to have some affect, eventually.
Master, again and still
Re: Balancing tires question............... [Re: Thumperdart] #2378595
09/29/17 12:30 AM
09/29/17 12:30 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I always speed balance my slicks. Never tried force balancing them. Might find out if that is possible on our new equipment.
[image][/image]
Re: Balancing tires question............... [Re: sgcuda] #2378642
09/29/17 02:55 AM
09/29/17 02:55 AM
State of confusion
State of confusion
The MT's weren't balanced and the car seemed smooth enuff but I will have my friend Doug mount and balance em..........Thankxxx guys.....
Re: Balancing tires question............... [Re: Thumperdart] #2378756
09/29/17 12:04 PM
09/29/17 12:04 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I always balanced my tires. Run 'em 50 passes or so and balance them again. We used a slow speed spin balancer. In the past I used the old Snap On machine that you spun up by hand. That one worked great and I see they still sell a newer version but I haven't seen any of them around in a while. I pay attention to vibrations, etc., and balancing definitely made a difference. And it didn't cost me anything so it was a no brainer.
