Re: which 426 alum.Hemi Heads to get?
[Re: 6PKRTSE]
#2378332
09/28/17 03:35 PM
09/28/17 03:35 PM
Posts: 13,411 Marion, South Carolina [><]
an8sec70cuda
I have the regular ole Mopar Performance Crate Hemi heads on my 528". They flowed around 426 as cast on our flow bench but it still made 853/697 with only 10.5:1 on pump gas, so I am happy enough with them for now. ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) Same on my 572" hemi. Just the regular old MP (pre Edelbrock castings) aluminum heads CNC ported by MCH. Making somewhere in the neighborhood of 850 hp N/A at 11:1 on pump gas.
[Re: DoubleD]
#2378366
09/28/17 04:30 PM
09/28/17 04:30 PM
Posts: 511 Temperance, MI
68 HEMI GTS
Temperance, MI
here are the eddy head specific pistons - these are 13-1 customs Who makes those? I'm gonna need a set for my eddy heads!
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780# 69 Roadrunner 511 six pack 10.92 drive to track street car
[Re: rickseeman]
#2378475
09/28/17 08:36 PM
09/28/17 08:36 PM
Posts: 12,421 Taxes & Virus's R-US, NY
Dragula
Correct me if I am wrong but the only Edelbrock hemi head needing special piston notching is the latest edelbrock head with the big intake - the exhaust has a different guide angle requiring the special notch. The earlier edelbrock head sold through Mopar Performance ( with conventional valve train oiling ) does NOT need the special exhaust notch. Just because the valve angle is different doesn't mean that you need different pistons, or that it's going to cause you problems, etc. This isn't the 60's. Back then people would shave the heads and deck the block to get more compression. This would give you more compression but would decrease the piston to valve clearance. Most engines that people put together now are strokers. With a stroker you can get all the compression you want. Strokers take a lot less dome on the piston. Your street/strip application will probably be for pump gas and not have much dome. My guess is if you check your valve to piston clearance you will find you have a mile. When using Victor Jr's you do have to check the intake valve to bore clearance if you are using a small bore. Tell that to my buddy with +$2600 in two sets of pistons already, bet he throws one at you!
[Re: DoubleD]
#2378551
09/28/17 11:31 PM
09/28/17 11:31 PM
Posts: 1,651 Armada MICH.
DUSTER_340
Armada MICH.
here are the eddy head specific pistons - these are 13-1 customs DoubleD would you mind sharing whose pistons those are and the model number. I have those same heads and will be in the market for pistons. TIA
[Re: DUSTER_340]
#2378704
09/29/17 10:16 AM
09/29/17 10:16 AM
Posts: 2,299 NE Ohio
DoubleD
NE Ohio
here are the eddy head specific pistons - these are 13-1 customs DoubleD would you mind sharing whose pistons those are and the model number. I have those same heads and will be in the market for pistons. TIA The pistons are full customs designed by Best Machine - built by CP Pistons
[Re: DoubleD]
#2380210
10/01/17 09:34 PM
10/01/17 09:34 PM
68 HEMI GTS
Temperance, MI
I'll be looking forward to seeing the results on that one! What's the cam specs?
[Re: Lost in life]
#2380501
10/02/17 11:58 AM
10/02/17 11:58 AM
an8sec70cuda
Could you guys detail the builds of the engines that are making 750+ HP with the Eddy or mopar heads? Much appreciated. Thanks in advance. 572" hemi, KB block, MP heads cnc'd by MCH 11:1 CR for pump gas, Callies crank, Oliver steel rods, Diamond pistons 276°/284° at .050", .672"/.651" lift solid roller. Very mild lobes to be easy on parts. DLI roller rockers, Barton single 4500 intake, 1200 cfm dominator Has run 9.54 at 140.4 mph at 3800+ lbs. on just the motor and pump gas. Somewhere in the 850 hp ballpark.
[Re: Lost in life]
#2383539
10/07/17 07:29 PM
10/07/17 07:29 PM
DoubleD
NE Ohio
Not to be crass...but approximate cost for that build? Speed cost money son - how fast you wanna go! All I will say it is worth every dollar I spent - Best Machine used nothing but the best parts even on the small parts - I discussed what I wanted with Chuck before starting - it was a simple request a 572 with 800HP run on 110 fuel - using the the big valve eddy heads - 2 AFB's and the new Mega Block I had - I left everything else up to him - He delivered a big torque and durable HEMI - it could make more HP with a different intake and bigger carbs I am pretty sure of that - but I wanted in-line AFB's for NSS class racing. Overall I would say Best Machine delivered above my expectations
