Re: Amd door glass fitment problems
[Re: Dave Hall]
#2392254
10/24/17 11:49 AM
10/24/17 11:49 AM
Posts: 18,160 Mass
DAYCLONA
Mass
Let me see here? AMD makes CONVERTIBLE 1968 CHARGER glass? B body side glass is interchangeable among most 2dr models, AMD evidently sent him B body vert glass by mistake
[Re: Dave Hall]
#2392258
10/24/17 11:53 AM
10/24/17 11:53 AM
Posts: 15,996 RI Deep in the rust belt
chargervert
Let me see here? AMD makes CONVERTIBLE 1968 CHARGER glass? Sweet, I could use new glass for my Charger convertible!
70 Charger R/T SE 472 Hemi
70 Charger R/T convertible
70 Charger R/T V Code Sixpack
69 Charger R/T SE Sunroofcar
68 Charger 383
68 Charger 318
71 Charger R/T
70 Challenger convertible
71 Challenger convertible
71 Cuda 340
09 Challenger R/T Classic
[Re: Thread Ender1]
#2392837
10/25/17 11:51 AM
10/25/17 11:51 AM
Posts: 670 Los Osos, Ca
CKessel
Los Osos, Ca
Welcome to the world of restoration parts that don't fit. I did door glass on a 67 Camaro at work. The curvature of the glass on both doors didn't match the quarter glasses and therefore didn't seal against the moulding/seal combo on the from edge of the quarter glass yielding leaks. On a 65 Chevy wagon, the rr quarter glass was off almost 2" in its curvature. They ended up getting one from DVAP out of another car. Fit perfect.
Carl Kessel
[Re: demon]
#2393079
10/25/17 09:19 PM
10/25/17 09:19 PM
Posts: 18,160 Mass
DAYCLONA
Mass
There are so many adjustments on the side glass. Looks to me like you have the vent window frame leaning back which causes the gap shown. The vent frame has multiple adjusting points and needs to be right in order for everything else to fit. Also the up stop at the rear of the door glass on a 69-70 is on the rear vertical track and may be adjusted too low. I have installed AMD side glass with no fitment problems, so before everyone jumps on the "repro parts don't fit" bandwagon, first check the adjustment. Adjust the door glass first, and then the quarter glass to match, but that said, both need minor adjustments until everything jives and either glass can be rolled up individually and seal to everything. Adjusting side glass is something that is hard to explain and experience makes it a lot easier. They sent the OP CONVERTIBLE glass instead of HARDTOP glass, that's why it's important to lay the old glass over the repro glass to confirm fit and finish before wasting time on an install
