Are all 26" Radiator Fan Shrouds the same? #2376415
09/25/17 01:06 PM
09/25/17 01:06 PM
Corpus Christi, TX
shanker Offline OP
shanker  Offline OP
Corpus Christi, TX
I'm looking for a fan shroud for a 74 Ramcharger (Factory 440 truck with A/C) so the radiator inlet/outlet are both on the passenger side like in the attached pic of a radiator out of a 440 powered motor home.
Will any 26" radiator fan shroud work?
The Federal Government has not yet learned that you cannot legislate morality 1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23 1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55 1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91 1975 Duster 360 VS29L5 Daily Driver
Re: Are all 26" Radiator Fan Shrouds the same? [Re: shanker] #2376585
09/25/17 04:58 PM
09/25/17 04:58 PM
North East USA
BIGGERED Offline
Reasonable Title
BIGGERED  Offline
Reasonable Title
North East USA
Take a look at the attached.
I have not digested but you may probably find the detail you need?
Red
74-77 DT LD Cooling Part No.jpg74-77 DT LD Radiators Pic.jpg74-77 DT LD Radiators.jpg
