Re: fuel pump push rod
[Re: BH27G1B]
#2375313
09/23/17 01:48 AM
09/23/17 01:48 AM
Posts: 43,223 Bend,OR USA
Cab_Burge
Not good Remove it and reuse the old known good one, they don't normally wear out
[Re: BH27G1B]
#2375444
09/23/17 01:09 PM
09/23/17 01:09 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Ah yes....... The BB fuel pump pushrod.
Another one of those parts that was never an issue for like 35 years.
Then at some point....... Became a semi-problematic part.
[Re: HEMIDOG 70]
#2375472
09/23/17 02:14 PM
09/23/17 02:14 PM
RapidRobert
No opinion on the fitment but for sure get an NOS one or one that you know is good metal.
[Re: BH27G1B]
#2375487
09/23/17 02:35 PM
09/23/17 02:35 PM
fast68plymouth
So. Burlington, Vt.
The MP ones were junk. I had one wear out on the dyno.
The problem is, they often rough up the eccentric on the cam when they fail...... Then you're kinda screwed.
If the Mancini ones are truly .001-.002 oversized....that would fall into my "that's just dumb" file. If they thought there was a need for an oversized one...... It should be an "option", not the only way it comes. And there should be some paperwork, or notice on the packaging stating its oversized.
As stated, the best bet is often to find a nice used factory one.
[Re: BH27G1B]
#2375732
09/23/17 11:04 PM
09/23/17 11:04 PM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
I got one from him like 2 years ago.Still going strong.He was reasonable and shipped quick.One good member and seller.rocky
Chrysler Firepower
[Re: BH27G1B]
#2376104
09/24/17 10:38 PM
09/24/17 10:38 PM
Posts: 2,415 Connecticut
Ron_M
Connecticut
I keep the push rod in the photo below in my Road box. Is there a way that I can check it to see if it's one of tbe good ones? I find it hard to believe that the Mancini piece might not be good. Looks like the Mancini piece has an MP part number. Thanks in advance.
Common sense is a flower that does not grow in everybody's garden
[Re: A727Tflite]
#2376138
09/24/17 11:17 PM
09/24/17 11:17 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
unless you have it checked for hardness and size - you just don't know. That's what she said
[Re: BH27G1B]
#2376146
09/24/17 11:31 PM
09/24/17 11:31 PM
Ron_M
Connecticut
The one I have is sealed in plastic. I figure that if I ever need it, that I could hit with it a scotch Brite pad and be good to go. Determining hardness, we'll I don't have something readily available to determine that. Hopefully I'll have another one soon. Interesting topic. I'm learning a great deal.
[Re: Supercuda]
#2376148
09/24/17 11:35 PM
09/24/17 11:35 PM
Posts: 410 MA
BH27G1B
MA
unless you have it checked for hardness and size - you just don't know. That's what she said LOL ^^ I was told by a Mancini employee that if I felt that the fit was too tight to take some emery cloth, and work it down to a desired size............
