fuel pump push rod #2375276
09/22/17 11:16 PM
09/22/17 11:16 PM
MA
BH27G1B Offline OP
BH27G1B  Offline OP
MA
I decided to check my fuel pump push rod while I'm replacing the fuel pump on a 70 440+6. It looked ok, but since I had a new Mancini push rod, I decided to install the new rod. It went it part way, but is tight, and won't come back out. Is it normal to be that tight a fit? Thanks
Re: fuel pump push rod [Re: BH27G1B] #2375285
09/22/17 11:28 PM
09/22/17 11:28 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
It's supposed to fit nice and slippery like with some oil on it.
Re: fuel pump push rod [Re: BH27G1B] #2375313
09/23/17 12:48 AM
09/23/17 12:48 AM
Not good down
Remove it and reuse the old known good one, they don't normally wear out up
Re: fuel pump push rod [Re: BH27G1B] #2375321
09/23/17 01:02 AM
09/23/17 01:02 AM
MA
BH27G1B Offline OP
BH27G1B  Offline OP
MA
Yes, I ground down a long needle nose pliers to fit in the opening and hope to get it out shortly....... Thanks!
Re: fuel pump push rod [Re: BH27G1B] #2375444
09/23/17 12:09 PM
09/23/17 12:09 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Ah yes....... The BB fuel pump pushrod.
Another one of those parts that was never an issue for like 35 years.
Then at some point....... Became a semi-problematic part.
Re: fuel pump push rod [Re: BH27G1B] #2375448
09/23/17 12:17 PM
09/23/17 12:17 PM
MA
BH27G1B Offline OP
BH27G1B  Offline OP
MA
I just found out from Mancini that their push rod is 1 to 2 thousandths oversize from stock. Maybe some push rod bores are worn.
Re: fuel pump push rod [Re: BH27G1B] #2375461
09/23/17 01:01 PM
09/23/17 01:01 PM
central P.A.
HEMIDOG 70 Offline
HEMIDOG 70  Offline
central P.A.
Don't bother with the new rod use the old one or buy an old one. There were a batch of unhardened or just plain junk steel ones around. I will post a pic of the junk M.P. rod that was in my hemi. I found a few old ones from the 60's in a local parts store that is what I'm running now. A member here McCannix did have some new old stock rods he was selling. They would be good ones.
Re: fuel pump push rod [Re: HEMIDOG 70] #2375472
09/23/17 01:14 PM
09/23/17 01:14 PM
No opinion on the fitment but for sure get an NOS one or one that you know is good metal.
Re: fuel pump push rod [Re: BH27G1B] #2375474
09/23/17 01:16 PM
09/23/17 01:16 PM
MA
BH27G1B Offline OP
BH27G1B  Offline OP
MA
Thanks guys, I'm going to use my old one, once I get this one out!
Re: fuel pump push rod [Re: BH27G1B] #2375487
09/23/17 01:35 PM
09/23/17 01:35 PM
So. Burlington, Vt.
So. Burlington, Vt.
The MP ones were junk.
I had one wear out on the dyno.
The problem is, they often rough up the eccentric on the cam when they fail...... Then you're kinda screwed.
If the Mancini ones are truly .001-.002 oversized....that would fall into my "that's just dumb" file.
If they thought there was a need for an oversized one...... It should be an "option", not the only way it comes.
And there should be some paperwork, or notice on the packaging stating its oversized.
As stated, the best bet is often to find a nice used factory one.
Re: fuel pump push rod [Re: fast68plymouth] #2375497
09/23/17 01:47 PM
09/23/17 01:47 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Still have a few left from an old Chrysler warehouse depot.
Several well known engine builders like to use these.
Even $ less than the Mancini ones
PM me for details if you like
Re: fuel pump push rod [Re: BH27G1B] #2375526
09/23/17 02:31 PM
09/23/17 02:31 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I want one!
Re: fuel pump push rod [Re: BH27G1B] #2375732
09/23/17 10:04 PM
09/23/17 10:04 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I got one from him like 2 years ago.Still going strong.He was reasonable and shipped quick.One good member and seller.rocky
Chrysler Firepower
Re: fuel pump push rod [Re: BH27G1B] #2375761
09/23/17 11:47 PM
09/23/17 11:47 PM
MA
BH27G1B Offline OP
BH27G1B  Offline OP
MA
Today, I removed the Mancini push rod, cleaned and greased up my original rod, installed the new pump, cranked the motor to fill the carbs, then fired her up and adjusted the float levels. Good to go now. Thanks for all your input!
Re: fuel pump push rod [Re: BH27G1B] #2375764
09/23/17 11:55 PM
09/23/17 11:55 PM
MA
BH27G1B Offline OP
BH27G1B  Offline OP
MA
Since I looked my original push rod over well, and found it to be good. I decided to use it, but I will keep the NOS rods Terry has ( as long as they last ) in mind for any future need.
Re: fuel pump push rod [Re: BH27G1B] #2376104
09/24/17 09:38 PM
09/24/17 09:38 PM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
I keep the push rod in the photo below in my Road box. Is there a way that I can check it to see if it's one of tbe good ones? I find it hard to believe that the Mancini piece might not be good. Looks like the Mancini piece has an MP part number. Thanks in advance. up
Common sense is a flower that does not grow in everybody's garden
Re: fuel pump push rod [Re: BH27G1B] #2376137
09/24/17 10:16 PM
09/24/17 10:16 PM
A727Tflite Offline
A727Tflite  Offline
First thing I would be worried about is the obvious rust on the pushrod. As for good or bad - unless you have it checked for hardness and size - you just don't know.
Re: fuel pump push rod [Re: A727Tflite] #2376138
09/24/17 10:17 PM
09/24/17 10:17 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
That's what she said
Don't be the exception.
Re: fuel pump push rod [Re: BH27G1B] #2376146
09/24/17 10:31 PM
09/24/17 10:31 PM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
The one I have is sealed in plastic. I figure that if I ever need it, that I could hit with it a scotch Brite pad and be good to go. Determining hardness, we'll I don't have something readily available to determine that. Hopefully I'll have another one soon. Interesting topic. I'm learning a great deal.
Re: fuel pump push rod [Re: Supercuda] #2376148
09/24/17 10:35 PM
09/24/17 10:35 PM
MA
BH27G1B Offline OP
BH27G1B  Offline OP
MA
LOL ^^ I was told by a Mancini employee that if I felt that the fit was too tight to take some emery cloth, and work it down to a desired size............
