Page 2 of 3 1 2 3
Re: Removal of Lower Control Arm Bushing - Any tricks ? [Re: 70blackfish] #470849
09/20/09 04:09 PM
09/20/09 04:09 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
///light the rubber on fire
I like that. Job security!
Re: Removal of Lower Control Arm Bushing - Any tricks ???? [Re: anlauto] #470850
12/18/10 10:55 AM
12/18/10 10:55 AM
Long Island NY
ErikR Offline
ErikR  Offline
Long Island NY
Removed the center rubber and sleeve then took a diamond shaped chisel, knocked the top overhang lip in, then drove the chisel down the inside a little. Used a screwdriver and the chisel/drift to collapse the bushing and out it came...
MikeR
YEP....That's exactly how I do it....Ive got it down to about 20 mins for a pair. You need a good press and an air chisel
PITA- took the better part of yesterday to remove both bushings using a damaged cold chisel and air chisel.
Mike / Alan, can you post a pic or list the size chisel you used to get them out? Mike looks like you got them out intact - mine were completely mangled since I could not keep the metal folding over - it just chipped off in small pieces.
I probably messed up the inner surfaces as well
Re: Removal of Lower Control Arm Bushing - Any tricks ? [Re: 70blackfish] #470851
12/18/10 05:14 PM
12/18/10 05:14 PM
IMGTX Offline
IMGTX  Offline
thats the way i do it too///light the rubber on fire
Aww now your just braggin.
I have always done it like A-12 describes.
No hammer too small no bushing to hard.
Re: Removal of Lower Control Arm Bushing - Any tricks ???? [Re: RaceCarRegistry] #470852
12/20/10 11:19 PM
12/20/10 11:19 PM
St Louis, MO 63026
convx4 Offline
convx4  Offline
St Louis, MO 63026
I made a tool that I could use to push out the center post from the bushing with a gear puller. This was a length of pipe that slid down on the center post and was held on with the nut. On the pipe I welded two nuts 180 apart this was for the gear puller to grab on to. Turned the lead screw on the puller to force out the center post, once apart. Then use a BFH and chisel to remove the outer metal shell. A cutoff wheel on the center post removes the inner sleeve. Then put the new bushing in the freezer over night and use a press to in stall the new bushing and center post. I will try to post a picture later.
Re: Removal of Lower Control Arm Bushing - Any tricks ???? [Re: ErikR] #470853
12/20/10 11:59 PM
12/20/10 11:59 PM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
MikeR
Sorry I didn't see this post until a few minutes ago. I used a 3/8" or slightly larger diamond tipped/shape chisel to cut and compress (mangle) the metal bushing like this:
Re: Removal of Lower Control Arm Bushing - Any tricks ???? [Re: A12] #470854
12/21/10 01:55 PM
12/21/10 01:55 PM
Long Island NY
ErikR Offline
ErikR  Offline
Long Island NY
Thanks Mike, that helps alot!
I was using a flat cold chisel with a real messed up blade - chips and what not - it was the only hardened steel chisel I had but it just shredded the bushing and did not let the bushing fold in on itself.
Stuipd me - on the next car I will try a nice new diamond tip and see how it goes.
Re: Removal of Lower Control Arm Bushing - Any tricks ???? [Re: convx4] #470855
12/21/10 02:02 PM
12/21/10 02:02 PM
Long Island NY
ErikR Offline
ErikR  Offline
Long Island NY
Beil - sounds like you were smart an made the tool youself.
I used a tool kit from Mancini - the LCA shaft came out easy enough but that outer bushing was what killed me.
Either a new chisel next time or hopefully I'll have a welder and can tack a washer on the outer bushing to press it out.
Re: Removal of Lower Control Arm Bushing - Any tricks ???? [Re: ErikR] #2373687
09/20/17 12:30 AM
09/20/17 12:30 AM
Sherwood Park, Alberta, Canada
Lighthorseman Offline
Originally Posted By ErikR
PITA- took the better part of yesterday to remove both bushings using a damaged cold chisel and air chisel...mine were completely mangled since I could not keep the metal folding over - it just chipped off in small pieces.
I probably messed up the inner surfaces as well...
Well, I know this thread has been stagnant for a while, but I have just done the same - I used a hammer, chisels, and some old school muscle to get mine out. Thanks to the trick with using a Dremel tool to make that initial incision, the rest went reasonably quickly.
Here's my question, though...when I dug out my polyeurethane bushings, I noted that the Energy Suspension kit I have does NOT include the metal sleeves I just worked so hard to remove.
Does anyone know of a source for just the sleeves, or will I have to get a complete set of bushings, (such as MOOG, etc) pull the rubber out, and replace it with the poly?
Re: Removal of Lower Control Arm Bushing - Any tricks ???? [Re: RaceCarRegistry] #2373729
09/20/17 01:38 AM
09/20/17 01:38 AM
Albany, NY
67SATisfaction Offline
The member whose name is actually Art
Albany, NY
Just in case...
First check if the poly bushings are sized to fit without the steel sleeve.
I've seen this on another car when switching from OEM rubber to poly.
Don't know where to get just the steel sleeve.
- Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: Removal of Lower Control Arm Bushing - Any tricks ???? [Re: RaceCarRegistry] #2373805
09/20/17 09:59 AM
09/20/17 09:59 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Those poly ones that I tried did not use the sleeves. They fit in the open arm just like they come and the pin slips back in. The ones I tried squeaked badly so I pulled mine back out. I was told later they needed to be greased. Keep in mind that if you or the guy before hacked up the smooth surface of either the pin or the lower arm, you need to smooth it out or you will wear out the bushing fast because it will turn slightly with the poly. I never use a torch or chisel on my arms and have removed hundreds of them. Of coarse I'm not a line mechanic trying to see how fast I can take them out to beat the book time either. I've seen some hacked up suspension parts in my day. I press the pin and rubber out first and then cut a groove in the inner sleeve till it gets thin enough to collapse the sleeve on itself gently with a hand chisel. You only have to go about half way down. A cutoff wheel takes the sleeve off the pin.
Re: Removal of Lower Control Arm Bushing - Any tricks ???? [Re: RaceCarRegistry] #2374752
09/21/17 10:14 PM
09/21/17 10:14 PM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
Use a drill and bit to drill into the bushing until it loosens the inner sleeve then just push out the rubber and inner sleeve. Outers still require force
NS1AAR
Re: Removal of Lower Control Arm Bushing - Any tricks ???? [Re: RaceCarRegistry] #2375180
09/22/17 07:53 PM
09/22/17 07:53 PM
Big Sky Country
MO_PA Offline
MO_PA  Offline
Big Sky Country
Once the rubber is out of the way I crank up my welder and put some weld beads inside quickly, I kinda go from end to end and round and round. Once it cools the bushing will fall out. I don't take much.
Re: Removal of Lower Control Arm Bushing - Any tricks ???? [Re: RaceCarRegistry] #2375251
09/22/17 11:11 PM
09/22/17 11:11 PM
AndyF Offline
AndyF  Offline
I put the lower control arm in a mill and then slowly walk and end mill into the bushing housing. You can cut the housing down until it is paper thin and then it just peels out of arm without causing any damage to anything.
Re: Removal of Lower Control Arm Bushing - Any tricks ???? [Re: RaceCarRegistry] #2375311
09/23/17 01:42 AM
09/23/17 01:42 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I press out the rubber/inner shell then use a large tap. Put a washer in to protect the tap, use a vise to hold the tap, screw control arm on and press out... easiest way I found. I can't remember the tap size offhand, but got one on ebay brand new for like 15 shipped. One removed, just cut the shell off and do the other side.
I used to do other ways mentioned in the thread... but saw a post here a few year back and tried it this way and won't consider any other way now.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Removal of Lower Control Arm Bushing - Any tricks ???? [Re: Silver70] #2375350
09/23/17 06:00 AM
09/23/17 06:00 AM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
1 3/8 inch.
http://www.forabodiesonly.com/mopar/thre...tration.180315/
Read this from another forum.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Removal of Lower Control Arm Bushing - Any tricks ???? [Re: hemi71x] #2375361
09/23/17 09:29 AM
09/23/17 09:29 AM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
1 3/8 inch.
iagree Makes it very easy.
Re: Removal of Lower Control Arm Bushing - Any tricks ???? [Re: RaceCarRegistry] #2375553
09/23/17 04:53 PM
09/23/17 04:53 PM
Niwot, CO Formerly denn...
dynorad Offline
dynorad  Offline
I have welded a washer to the flange and pressed them out with great success.
Re: Removal of Lower Control Arm Bushing - Any tricks ???? [Re: T2R9] #2375637
09/23/17 07:58 PM
09/23/17 07:58 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
1 3/8 inch.
In fact this is how the factory recommends them to be removed.
Re: Removal of Lower Control Arm Bushing - Any tricks ???? [Re: RaceCarRegistry] #2375657
09/23/17 08:33 PM
09/23/17 08:33 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Similar to the large tap, this tool expands inside the bushing and snags it. Then you inch it out with a threaded rod. Takes only a few minutes.
Link. But I bought their multi tool kit years ago and didn't pay that much for the one tool.
02 Front Suspension.L lower control arm14.bushing shell removal..jpg02 Front Suspension.L lower control arm10.bushing shell removal..jpg02 Front Suspension.L lower control arm15.bushing shell removal..jpg
Re: Removal of Lower Control Arm Bushing - Any tricks ???? [Re: kentj340] #2375846
09/24/17 10:23 AM
09/24/17 10:23 AM
Wausau Wi
Convertcuda Offline
Convertcuda  Offline
Wausau Wi
Any pictures of how to put them back in tricks?
Page 2 of 3 1 2 3
