Which Wix filter to run? #2373851
09/20/17 12:17 PM
09/20/17 12:17 PM
North Central, Indiana
Roughbird72 Offline OP
I have been running the FL1-HPs on my Plymouth for awhile and have purchased Wix filters because of cost,I have 51515 and 51515R filters. I know the microns and flow rates are different between the two, but I'm looking for some input. shruggy
My car usually gets an oil change once a year. I doubt I put more than 300 street miles on it and maybe 30-40 passes down the track a year.
72 Plymouth Roadrunner 11.08@123.25
Re: Which Wix filter to run? [Re: Roughbird72] #2373879
09/20/17 01:18 PM
09/20/17 01:18 PM
Port Huron, Michigan
MI_Custumz Offline
MI_Custumz  Offline
Street driven, I'd run 51515.
Re: Which Wix filter to run? [Re: Roughbird72] #2373880
09/20/17 01:33 PM
09/20/17 01:33 PM
I'd go with the 51515 (lowest microns-20 iirc) for the best filtering.
Re: Which Wix filter to run? [Re: Roughbird72] #2373887
09/20/17 01:47 PM
09/20/17 01:47 PM
an8sec70cuda Offline
I've always used the normal 51515.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Which Wix filter to run? [Re: Roughbird72] #2373912
09/20/17 02:58 PM
09/20/17 02:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The 51515R is the racing filter and it flows
more but doent have the filtration of the 51515
which I use all the time now
wave
Re: Which Wix filter to run? [Re: Roughbird72] #2373944
09/20/17 03:52 PM
09/20/17 03:52 PM
Thanks Guys! up
The 51515 has a burst pressure of 290#, so cold start ups at 90# shouldn't be an issue.
Re: Which Wix filter to run? [Re: Roughbird72] #2374235
09/20/17 11:54 PM
09/20/17 11:54 PM
OHIO THE HEART OF IT ALL
64hemi330sedan Offline
I use the 51515xp on my street car/ n/ss car. it has a thicker case. but the same filtration as a regular 51515.
Re: Which Wix filter to run? [Re: Roughbird72] #2374264
09/21/17 12:28 AM
09/21/17 12:28 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
51515
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Which Wix filter to run? [Re: Roughbird72] #2374280
09/21/17 12:44 AM
09/21/17 12:44 AM
Tucson AZ,
MadMopars Offline
MadMopars  Offline
Tucson AZ,
Although I have yet to take advantage of it, I just came across the Wix filter discount thread linked below. Since you posted up a Wix discussion, I figured I would bring it up for other members like myself who may be unaware of the savings potential. Certainly worth taking a look at if you already haven't.
up -Trent
WIX Discount for Moparts Members - Link
[img]https://s9.postimg.cc/6fbjxzfvv/48-2016-_Drag-_Weekend-_Best-_Burnouts-lpr.jpg[/img]
73 GTX *440*727*8 3/4*
69 DART GT *440*4 SPEED*DANA*
73 ROAD RUNNER *451*4 SPEED*DANA*
64 F100 *383*4 SPEED*9"*
75 DODGE D300 *440*4 SPEED*DANA*
99 DODGE RAM 3500 4X4 DUALLY... ON 38"s
Re: Which Wix filter to run? [Re: MadMopars] #2374379
09/21/17 10:01 AM
09/21/17 10:01 AM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
That discount works great, although its been about 6 or so months since Ive used it.
Re: Which Wix filter to run? [Re: Roughbird72] #2374413
09/21/17 11:18 AM
09/21/17 11:18 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
When I was looking for the 51515 I had a tough time finding them. I went to Carquest and the guy said Carquest filters are re-branded Wix and the 51515 is part of the Carquest p/n.
Re: Which Wix filter to run? [Re: Roughbird72] #2374422
09/21/17 11:33 AM
09/21/17 11:33 AM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
Napa gold 1515 is also a wix. Been using those on the roadrunner.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: Which Wix filter to run? [Re: MadMopars] #2374429
09/21/17 11:40 AM
09/21/17 11:40 AM
up -Trent
Rock Auto $4.06
Re: Which Wix filter to run? [Re: Roughbird72] #2374432
09/21/17 11:46 AM
09/21/17 11:46 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I've had at least 4 bad wix filters in the past few years... so check your oil pressure when you put one on and be ready to turn the engine off fast.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Which Wix filter to run? [Re: Silver70] #2374459
09/21/17 12:40 PM
09/21/17 12:40 PM
I always crank til I get oil pressure,before turning on the fuel.
Re: Which Wix filter to run? [Re: Roughbird72] #2374469
09/21/17 01:01 PM
09/21/17 01:01 PM
gregsdart Offline
gregsdart  Offline
For a street motor where reliability is excelent due to the parts used, i would go 51515. Race, 51515r to catch debris should you have a failure and metal floting around. With the higher flowing media, the r filter doesn't bypass the oil nearly as quickly, lncreasing the chance to catch the junk.
Re: Which Wix filter to run? [Re: gregsdart] #2374957
09/22/17 12:09 PM
09/22/17 12:09 PM
moparx Offline
moparx  Offline
of the 30+ years i have ran wix filters, i have had several where the threads were bad. i have a 3/4-16 "form" tap which, as the name suggests, "roll forms" the threads with no metal removal. those i have fixed easily, and i have a plated 3/4-16 bolt i use to check the threads on every filter i use because i fill each filter before installation. the only other defect i have come across using these filters is once in a while, for whatever reason, the filter comes without a gasket. those, i return. the 51515 fits my whole fleet, including my FWD minivan with the 3.3 engine, so i buy these by the case.
beer
