Re: Small block cam talk comp cam xe268h
[Re: RAY1969CARS]
#2371579
09/16/17 02:30 AM
09/16/17 02:30 AM
RapidRobert
In some apps it is desireable to set the preload down a certain amt from the lifter snap ring. Which ain't answering your Q but here is a BTT for ya.
[Re: RAY1969CARS]
#2371618
09/16/17 09:14 AM
09/16/17 09:14 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Because adjustable rockers are not NEEDED. It's one of those turd polishing things on a hydraulic cam that 99% of the time is unnecessary.
I'm sure Comp recommends a bunch of other stuff too, it's called add on sales.
[Re: RAY1969CARS]
#2372520
09/18/17 02:16 AM
09/18/17 02:16 AM
RapidRobert
My question is I have read about this cam on small block and some guys have used adjustable rocker arms and some haven't. I do have a set of 273 rockers Why are some guys not using adjustable rocker arms On the comp website it says it's recommended I would mockup with your regular non adjustables & see what the preload is. Knowledge is power. then you will be in an informed position to see if you need the 273 setup. Odds are in a mild app with any preload you will be fine.
[Re: RAY1969CARS]
#2372596
09/18/17 10:44 AM
09/18/17 10:44 AM
Supercuda
About to go away
About to go away
up yours
Here's comes the turd polishing.
Before you get too worked up about preload, go look at the preload specs in the FSM. It's pretty much "as long at there is some and it doesn't bottom out you are good".
On that mild a cam go with the FSM specs, which means you are most likely good to go.
[Re: RAY1969CARS]
#2373032
09/18/17 11:32 PM
09/18/17 11:32 PM
Challenger 1
Cincinnati, Ohio
So should I run a stock rockers or the 273 adjustable ??? Stock non adjustable rockers will work just as long as the push rods are the right length. I would use the adjustable 273 rockers, they are stronger and will allow you set the preload exactly where you want it. Easier than getting the right push rods especially if all 16 push rods at the same length don't work for all 16 with non adjustable rockers. What if one push rod needs to be longer or shorter than the rest when you check pre load? Then adjustable rockers come in handy.
[Re: RAY1969CARS]
#2373199
09/19/17 11:00 AM
09/19/17 11:00 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
As mentioned, with a mild cam like this, you really only need to have the correct lifter pre-load, which can vary quite a bit with stock type lifters, from about 0.020" to 0.080" (some lifters can take a bit more depends on brand.) Usually, I like to get custom length pushrods that give 0.040" lifter pre-load.
Here is what I use when deciding to not use the stock rocker arms: Higher valve spring pressures can push the pushrods through the stock rocker arms. So, when going over 0.500" lift with stiff valve springs, it is a "good idea" to upgrade the rocker arms. I quoted "good idea" because everyone is going to post their 292/0.509" cam works fine with stock rocker arms. Alot depends on the valve springs used (seat pressure and spring rate), and how aggressive the cam lobe profile is.
[Re: RAY1969CARS]
#2373203
09/19/17 11:02 AM
09/19/17 11:02 AM
Supercuda
About to go away
About to go away
up yours
.500" is pretty much my dividing line between farting about and being serious.
[Re: RAY1969CARS]
#2373533
09/19/17 08:24 PM
09/19/17 08:24 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
It only takes one pushrod through an old oem rocker at a really less than optimal time(where it kicks a lifter out and now you have 2 psi oil pressure to try and limp it home) and location for you to question when you would ever use them again in a "high performance" application.
The XE series of cams have much faster ramps than the oem cams the rockers designed for. If you have access to a new set of the old MP HD stamped rockers that's a different situation than using a set of 30 year old stockers with an unknown history.
If I had some 273 rockers on hand, I know what I'd use(but then, I've already had the pleasure of putting a pushrod through a rocker with my old school .480 lift cam, at midnight, when I'm 20 miles from home and the oil pressure gauge is barely up off the "0" peg).
[Re: fast68plymouth]
#2373544
09/19/17 08:45 PM
09/19/17 08:45 PM
Supercuda
About to go away
About to go away
up yours
As mentioned in another thread the "MP HD rockers" are nothing more than later model OEM rockers. As with ANY job, you replace wore out stuff if needed.
[Re: RAY1969CARS]
#2375746
09/23/17 11:47 PM
09/23/17 11:47 PM
Posts: 44 Youngstown
Vincenzo
Youngstown
I think comp has made all their hyd. Stuff on the same base circle for all makes to cut costs. Most likely smaller than factory Mopar. Last year I tried to order a cam based on the old card from a previous build, they told me the dash 3 suffix had changed to dash5. Why?,I said. Reply: that base circle is no longer used.
Woodruff Carburetor Specialties 330-799-9479
