Re: Removal of Lower Control Arm Bushing - Any tricks ?
[Re: 70blackfish]
#470849
09/20/09 04:09 PM
09/20/09 04:09 PM
Posts: 1,822 Colorado
denfireguy
Colorado
///light the rubber on fire
I like that. Job security!
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
Re: Removal of Lower Control Arm Bushing - Any tricks ????
[Re: anlauto]
#470850
12/18/10 10:55 AM
12/18/10 10:55 AM
Posts: 1,202 Long Island NY
ErikR
Long Island NY
Removed the center rubber and sleeve then took a diamond shaped chisel, knocked the top overhang lip in, then drove the chisel down the inside a little. Used a screwdriver and the chisel/drift to collapse the bushing and out it came...
MikeR
YEP....That's exactly how I do it....Ive got it down to about 20 mins for a pair. You need a good press and an air chisel
PITA- took the better part of yesterday to remove both bushings using a damaged cold chisel and air chisel.
Mike / Alan, can you post a pic or list the size chisel you used to get them out? Mike looks like you got them out intact - mine were completely mangled since I could not keep the metal folding over - it just chipped off in small pieces.
I probably messed up the inner surfaces as well
[Re: RaceCarRegistry]
#470852
12/20/10 11:19 PM
12/20/10 11:19 PM
Posts: 710 St Louis, MO 63026
convx4
St Louis, MO 63026
I made a tool that I could use to push out the center post from the bushing with a gear puller. This was a length of pipe that slid down on the center post and was held on with the nut. On the pipe I welded two nuts 180 apart this was for the gear puller to grab on to. Turned the lead screw on the puller to force out the center post, once apart. Then use a BFH and chisel to remove the outer metal shell. A cutoff wheel on the center post removes the inner sleeve. Then put the new bushing in the freezer over night and use a press to in stall the new bushing and center post. I will try to post a picture later.
[Re: ErikR]
#470853
12/20/10 11:59 PM
12/20/10 11:59 PM
Posts: 21,538 N.E. OHIO, USA
A12
N.E. OHIO, USA
MikeR
Sorry I didn't see this post until a few minutes ago. I used a 3/8" or slightly larger diamond tipped/shape chisel to cut and compress (mangle) the metal bushing like this:
[Re: ErikR]
#2373687
09/20/17 12:30 AM
09/20/17 12:30 AM
Posts: 41 Sherwood Park, Alberta, Canada
Lighthorseman
PITA- took the better part of yesterday to remove both bushings using a damaged cold chisel and air chisel...mine were completely mangled since I could not keep the metal folding over - it just chipped off in small pieces.
I probably messed up the inner surfaces as well...
Well, I know this thread has been stagnant for a while, but I have just done the same - I used a hammer, chisels, and some old school muscle to get mine out. Thanks to the trick with using a Dremel tool to make that initial incision, the rest went reasonably quickly. Here's my question, though...when I dug out my polyeurethane bushings, I noted that the Energy Suspension kit I have does NOT include the metal sleeves I just worked so hard to remove. Does anyone know of a source for just the sleeves, or will I have to get a complete set of bushings, (such as MOOG, etc) pull the rubber out, and replace it with the poly?
#2373729
09/20/17 01:38 AM
09/20/17 01:38 AM
Posts: 7,545 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
Just in case...
First check if the poly bushings are sized to fit without the steel sleeve.
I've seen this on another car when switching from OEM rubber to poly.
Don't know where to get just the steel sleeve. - Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
#2374752
09/21/17 10:14 PM
09/21/17 10:14 PM
Posts: 1,145 ontario calif
ns1aar
ontario calif
Use a drill and bit to drill into the bushing until it loosens the inner sleeve then just push out the rubber and inner sleeve. Outers still require force
NS1AAR
#2375311
09/23/17 01:42 AM
09/23/17 01:42 AM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I press out the rubber/inner shell then use a large tap. Put a washer in to protect the tap, use a vise to hold the tap, screw control arm on and press out... easiest way I found. I can't remember the tap size offhand, but got one on ebay brand new for like 15 shipped. One removed, just cut the shell off and do the other side.
I used to do other ways mentioned in the thread... but saw a post here a few year back and tried it this way and won't consider any other way now.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: Silver70]
#2375350
09/23/17 06:00 AM
09/23/17 06:00 AM
Posts: 5,365 Rancho Cordova, California (Sa...
hemi71x
I used to do other ways mentioned in the thread... but saw a post here a few year back and tried it this way and won't consider any other way now. 1 3/8 inch.http://www.forabodiesonly.com/mopar/thre...tration.180315/Read this from another forum.
RF-4C Phantom 69-370 Zweibrucken, Germany
[Re: hemi71x]
#2375361
09/23/17 09:29 AM
09/23/17 09:29 AM
Posts: 2,754 Conway, SC
T2R9
Conway, SC
I used to do other ways mentioned in the thread... but saw a post here a few year back and tried it this way and won't consider any other way now. 1 3/8 inch.http://www.forabodiesonly.com/mopar/thre...tration.180315/Read this from another forum. Makes it very easy.
[Re: T2R9]
#2375637
09/23/17 07:58 PM
09/23/17 07:58 PM
Posts: 1,250 North Carolina
469runner
North Carolina
I used to do other ways mentioned in the thread... but saw a post here a few year back and tried it this way and won't consider any other way now. 1 3/8 inch.http://www.forabodiesonly.com/mopar/thre...tration.180315/Read this from another forum. Makes it very easy. In fact this is how the factory recommends them to be removed.
#2375657
09/23/17 08:33 PM
09/23/17 08:33 PM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
Similar to the large tap, this tool expands inside the bushing and snags it. Then you inch it out with a threaded rod. Takes only a few minutes. Link. But I bought their multi tool kit years ago and didn't pay that much for the one tool.
