T&D rocker arms
#2370812
09/14/17 05:01 PM
09/14/17 05:01 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
What is your guyses experience with actual rocker ratio versus advertised.. I'm hearing with T&D .the ratio can be slightly higher than advertised.. has anyone experience this..
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
Re: T&D rocker arms
[Re: WHITEDART]
#2370846
09/14/17 05:57 PM
09/14/17 05:57 PM
Posts: 43,372 Bend,OR USA
Cab_Burge
I've seen .030 max lift difference at the retainers with both T&D and Harland Sharp 1.5 and 1.6 ratio single shaft systems ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) Not the same results with a set of Jesel 1.55 paired shaft system The new owner at Harland sharp told me that they add some ratio to most of their sets to allow for deflection in the valve trains, which is usually mainly due to the cheaper pushrods is what I have found ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) I only buy the good ones now for all of my race motors
Re: T&D rocker arms
[Re: Cab_Burge]
#2370858
09/14/17 06:36 PM
09/14/17 06:36 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Most of what I use are the paired style TD rockers and I have checked them at the retainer and the paired ones were damn near dead on.. my cam was a little off but that was all.. I do use a single shaft set also that were a bit off.. thy showed 1.53 ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
Re: T&D rocker arms
[Re: MR_P_BODY]
#2370880
09/14/17 07:09 PM
09/14/17 07:09 PM
WHITEDART
bean town ....Ca
I know sometimes geometry and push rod deflection can play into the numbers.. I appreciate the feedback from everybody.. I'm making a rocker arm change and was trying to do some pre-planning
Re: T&D rocker arms
[Re: MR_P_BODY]
#2370894
09/14/17 07:49 PM
09/14/17 07:49 PM
WHITEDART
bean town ....Ca
Cam has always been ground for a 1.8.. and have been running a 1.6. And I'm now going to step up to a 1.85. This change is going to require different Springs.. but I think I will hold off on the springs until I get the Rockers. When I ordered them they said 3 to 4 weeks., I anticipate having them in a couple weeks
Re: T&D rocker arms
[Re: WHITEDART]
#2371412
09/15/17 08:55 PM
09/15/17 08:55 PM
Posts: 498 El Dorado Ca
65signet
El Dorado Ca
I know cheap rockers say 1.5 or 1.6 but they really are 1.4
1965 Plymouth Barracuda 273 M/SA 1970 Plymouth Duster 360/904 10.60s with J heads
Re: T&D rocker arms
[Re: 65signet]
#2371419
09/15/17 09:09 PM
09/15/17 09:09 PM
Cab_Burge
I know cheap rockers say 1.5 or 1.6 but they really are 1.4 I've checked a lot of different adjustable rocker arms, stock and after market ductile iron as well as aluminum, some have more ratio and some have less ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) The stock 426 Hemi rockers where the worst, I saw over .100 variance lift at the retainers It pays to check all of them ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
Re: T&D rocker arms
[Re: WHITEDART]
#2371675
09/16/17 12:35 PM
09/16/17 12:35 PM
Posts: 326 Alberta
Wookie316
Alberta
I have a set of T&D on my Indy EZ heads. Very nice.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
Re: T&D rocker arms
[Re: WHITEDART]
#2371947
09/16/17 11:39 PM
09/16/17 11:39 PM
Posts: 561 USA
B3RE
USA
I know sometimes geometry and push rod deflection can play into the numbers.. I appreciate the feedback from everybody.. I'm making a rocker arm change and was trying to do some pre-planning If the geometry is not right, it doesn't matter what the max lift at the valve is. It won't be an accurate indicator of the true ratio of the rocker arm. For every degree of crankshaft rotation during the lift cycle, the cam is designed to move the rocker a specific amount. When the geometry is off, it doesn't follow the design of the cam lobe, and accurately relay that info to the valve. So what if it's dead nuts at full lift if it's losing everywhere else.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
Re: T&D rocker arms
[Re: B3RE]
#2372833
09/18/17 05:00 PM
09/18/17 05:00 PM
Posts: 4,595 Motor City
6PKRTSE
Motor City
I have the Barton (T&D's) 1.6 rocker system on my 2ND Gen Hemi & they all seem to be spot on when we checked them all.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
