T&D rocker arms #2370812
09/14/17 05:01 PM
09/14/17 05:01 PM
bean town ....Ca
W
WHITEDART Offline OP
W
bean town ....Ca
What is your guyses experience with actual rocker ratio versus advertised.. I'm hearing with T&D .the ratio can be slightly higher than advertised.. has anyone experience this..
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: T&D rocker arms [Re: WHITEDART] #2370822
09/14/17 05:27 PM
09/14/17 05:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
My 1.5 and 1.6 were almost dead on to spec
wave
Re: T&D rocker arms [Re: WHITEDART] #2370828
09/14/17 05:44 PM
09/14/17 05:44 PM
Nevada
merpar Offline
merpar  Offline
Nevada
Nobody makes better rockers. Nobody!
Re: T&D rocker arms [Re: WHITEDART] #2370842
09/14/17 05:54 PM
09/14/17 05:54 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Jesel does
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: T&D rocker arms [Re: WHITEDART] #2370846
09/14/17 05:57 PM
09/14/17 05:57 PM
I've seen .030 max lift difference at the retainers with both T&D and Harland Sharp 1.5 and 1.6 ratio single shaft systems shruggy
Not the same results with a set of Jesel 1.55 paired shaft system shruggy
The new owner at Harland sharp told me that they add some ratio to most of their sets to allow for deflection in the valve trains, which is usually mainly due to the cheaper pushrods is what I have found work shruggy
I only buy the good ones now for all of my race motors up
Re: T&D rocker arms [Re: Cab_Burge] #2370858
09/14/17 06:36 PM
09/14/17 06:36 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Most of what I use are the paired style TD
rockers and I have checked them at the retainer
and the paired ones were damn near dead on..
my cam was a little off but that was all.. I
do use a single shaft set also that were a bit
off.. thy showed 1.53
wave
Re: T&D rocker arms [Re: B3422W5] #2370860
09/14/17 06:39 PM
09/14/17 06:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Originally Posted By B3422W5
Jesel does
To me... they are equal
wave
Re: T&D rocker arms [Re: MR_P_BODY] #2370880
09/14/17 07:09 PM
09/14/17 07:09 PM
bean town ....Ca
W
W
bean town ....Ca
I know sometimes geometry and push rod deflection can play into the numbers.. I appreciate the feedback from everybody.. I'm making a rocker arm change and was trying to do some pre-planning
Re: T&D rocker arms [Re: WHITEDART] #2370889
09/14/17 07:37 PM
09/14/17 07:37 PM
AndyF Offline
AndyF  Offline
Jesel and T&D rocker arms tend to deliver the advertised ratio when using roller cam springs. Some other vendors don't. I've seen 1.70 rocker arms turn into 1.60 rocker arms when confronted by a roller cam spring.
Re: T&D rocker arms [Re: WHITEDART] #2370890
09/14/17 07:38 PM
09/14/17 07:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Whats your plan of attack
wave
Re: T&D rocker arms [Re: MR_P_BODY] #2370894
09/14/17 07:49 PM
09/14/17 07:49 PM
bean town ....Ca
W
W
bean town ....Ca
Cam has always been ground for a 1.8.. and have been running a 1.6. And I'm now going to step up to a 1.85. This change is going to require different Springs.. but I think I will hold off on the springs until I get the Rockers. When I ordered them they said 3 to 4 weeks., I anticipate having them in a couple weeks
Re: T&D rocker arms [Re: WHITEDART] #2370895
09/14/17 07:51 PM
09/14/17 07:51 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
I think the only way they would be off is if the adjuster is hanging way out which is bad for oiling and everything else. If you follow T&D's instructions and buy the correct pushrods they should be dead on.
With heavy valve spring pressure you should always go with a bolt in stand and Paired Shaft Rockers (5/8" shaft).
The single shaft rockers have to much movement with valve spring pressures over 600lbs.
I would recommend anything with a solid roller cams should always run Paired Shaft Rockers (5/8" shaft)
Re: T&D rocker arms [Re: WHITEDART] #2370907
09/14/17 08:11 PM
09/14/17 08:11 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
I just bought a set of Jesel 1.85 for my W 9 heads i talked to both T&D and Jesel both were out like 4 5 wks and pricey but you get what you pay for
Re: T&D rocker arms [Re: WHITEDART] #2371022
09/15/17 12:10 AM
09/15/17 12:10 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Mine are very close with actual spring pressure. However my bed plate is raised .060" over the desired 90 degree@50% lift rule.
Doug
Re: T&D rocker arms [Re: WHITEDART] #2371412
09/15/17 08:55 PM
09/15/17 08:55 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
I know cheap rockers say 1.5 or 1.6 but they really are 1.4
1965 Plymouth Barracuda 273 M/SA
1970 Plymouth Duster 360/904 10.60s with J heads
Re: T&D rocker arms [Re: 65signet] #2371419
09/15/17 09:09 PM
09/15/17 09:09 PM
I've checked a lot of different adjustable rocker arms, stock and after market ductile iron as well as aluminum, some have more ratio and some have less shruggy
The stock 426 Hemi rockers where the worst, I saw over .100 variance lift at the retainers shock
It pays to check all of them up
Re: T&D rocker arms [Re: B3422W5] #2371669
09/16/17 12:14 PM
09/16/17 12:14 PM
America
WedgeFED Offline
WedgeFED  Offline
America
Jesel does
This is funny. It depends if you live on the west coast or east coast.
Re: T&D rocker arms [Re: WHITEDART] #2371675
09/16/17 12:35 PM
09/16/17 12:35 PM
Alberta
Wookie316 Offline
Wookie316  Offline
Alberta
I have a set of T&D on my Indy EZ heads. Very nice.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
Re: T&D rocker arms [Re: WHITEDART] #2371947
09/16/17 11:39 PM
09/16/17 11:39 PM
USA
B3RE Offline
B3RE  Offline
USA
I know sometimes
If the geometry is not right, it doesn't matter what the max lift at the valve is. It won't be an accurate indicator of the true ratio of the rocker arm. For every degree of crankshaft rotation during the lift cycle, the cam is designed to move the rocker a specific amount. When the geometry is off, it doesn't follow the design of the cam lobe, and accurately relay that info to the valve. So what if it's dead nuts at full lift if it's losing everywhere else.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
Re: T&D rocker arms [Re: B3RE] #2372833
09/18/17 05:00 PM
09/18/17 05:00 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have the Barton (T&D's) 1.6 rocker system on my 2ND Gen Hemi & they all seem to be spot on when we checked them all.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
