Re: Question about different diameter 360 flexplates
[Re: Badge]
#2370802
09/14/17 04:37 PM
09/14/17 04:37 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
On an LA the stock type flex plate has to match the torque converter bolt pattern and the crank bolt pattern
[Re: Badge]
#2370821
09/14/17 05:18 PM
09/14/17 05:18 PM
RapidRobert
the 10 inch plate is for a 904, the 11" plate/converter is for a 727. You'd have to use the setup to match whichever transmission you are using. the 360 was offered with both.
[Re: RapidRobert]
#2370922
09/14/17 08:50 PM
09/14/17 08:50 PM
Posts: 25,914 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The 727 used both the 10" and 11" flexplate, as long as the flexplate matches the converter and the converter weight is correct for the 360 you're good to go.
[Re: Badge]
#2370975
09/14/17 10:36 PM
09/14/17 10:36 PM
Supercuda
About to go away
About to go away
up yours
Balance weight should be on the stock converter and all LA 360's use the same weight.
