Transbrake...How Much Gain Using It?
#237074
02/26/09 04:12 PM
02/26/09 04:12 PM
Posts: 1,539 Columbia Station, OH
MrBelvedere
Mr Zipper Lips
Mr Zipper Lips
Hey guys, I've been tossing around the idea of using the transbrake in the Belvedere. Can anyone give me an idea how much I can expect to drop ET wise, 60ft also? Best ET to date is 10.69 at 126mph Best 60ft has been a 1.49 but usually is 1.51- 1.52. Been footbraking it, leaving anywhere between 2500-2800rpm. Car has the following 470 Indy Ez's Flat tappet .687 lift (gross) 1050 AED Carb 727 w/brake JW 5500 converter (was set up for my combo) Dana 60 4.10's on a spool 29x9.0 Hoosiers Cal-tracs with monoleaf Rancho 9000's 6 point rollbar Car weighs 3700 or so with driver Thanks guys
Re: Transbrake...How Much Gain Using It?
[Re: MrBelvedere]
#237076
02/26/09 04:17 PM
02/26/09 04:17 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Well if you bring the engine up to the peak torque on the launch vs the 2800 you might see 1.45 or even lower in the 60'... if you hook it up
[Re: MR_P_BODY]
#237077
02/26/09 04:25 PM
02/26/09 04:25 PM
Posts: 6,295 U.S.
moparniac
U.S.
so they are stock 440 port indy ez's??? how much porting. just curious.
thx
Mopar Performance
[Re: MrBelvedere]
#237078
02/26/09 04:38 PM
02/26/09 04:38 PM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
My old Duster, 2700lb, 452, 906 head, .590 MP cam, 4.10 gear, 727, went 1.48 60' leaving at 2000rpm off the foot, ET 10.20. With a transbrake it went 1.38 60' leaving at 3200rpm, ET 10.10. .10 gain in ET was all from the 60' gain.
[Re: B5 Bee]
#237079
02/26/09 04:57 PM
02/26/09 04:57 PM
Posts: 8,165 Left Coast
BobR
Left Coast
But this isn't always the case. Trans brakes are more for quicker/consistant leaves than they are for ET reduction.
[Re: BobR]
#237080
02/26/09 05:13 PM
02/26/09 05:13 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
I didn't see any gains from it but I did have a number of other issues that I eventualy sorted out and got it back to running 11.0's.
I guess I really won't know for sure untill next year when I can get some passes in the log book under similar weather conditions.
[Re: WILD BILL]
#237081
02/26/09 05:40 PM
02/26/09 05:40 PM
Posts: 842 Baltimore,MD
Bill_LBSR
Baltimore,MD
All depends if the car can handle the launch with a trans brake. Some peoples cars slow down with a trans brake. You may have to adjust the suspension on the car to take full advantage of the trans brake.
LBSR
[Re: WILD BILL]
#237082
02/26/09 05:41 PM
02/26/09 05:41 PM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
Huge in factor! Love letting go of the button and feeling like I was just rear-ended by a semi
[Re: Bigcube]
#237083
02/26/09 06:30 PM
02/26/09 06:30 PM
Posts: 513 Springboro, Ohio
Hollywood
Springboro, Ohio
The first time I used mine, I thought I broke the whole driveline. But it was still going! It hits really hard and will bring the wheels up if you can hook up and have enough power. Just make sure your rear end and transmission is up to it.
[Re: Hollywood]
#237084
02/26/09 06:40 PM
02/26/09 06:40 PM
WILD BILL
BROOK PARK, OH
I did break my entire driveline
[Re: MrBelvedere]
#237085
02/26/09 06:46 PM
02/26/09 06:46 PM
Posts: 2,412 Weatherford, Texas
RapidusMaximus
Weatherford, Texas
Don't know if will pick up ET but it will absolutely change the "personality" of the launch and be harder on driveline parts...my personal opinion is if you're bracket racing in a delay box class is that its a must (obviously)...but I wouldn't do it just to try and pick up ET...IMHO...
1968 Plymouth GTX 1974 Dodge P/U Long Bed Stepside 318 2019 Ram 2500 6.4, auto, 4WD
[Re: WILD BILL]
#237086
02/26/09 07:14 PM
02/26/09 07:14 PM
Posts: 2,771 Cedar Lake IN
CRT
Cedar Lake IN
ya sure did
[Re: Bill_LBSR]
#237089
02/27/09 09:36 AM
02/27/09 09:36 AM
Posts: 589 Indiana
YbNoRmAL
mopar addict
mopar addict
Indiana
That's it right there, you just don't put one in and not expect to tune the rest of the car.
[Re: MrBelvedere]
#237090
02/27/09 09:38 AM
02/27/09 09:38 AM
Posts: 176 Sterling Heights, MI
John_T_Brown
A trans brake is not about E.T. reduction it’s about consistency. It takes one more variable out of the human condition. When you couple the brake with a two step you leave at the exact same RPM every time assuming the car is not spinning the tire. If the car has carburetor issues (accelerator pump and/or transitional fuel circuit problems) you will be able to mask these conditions with a brake because you will leave the line with the power enrichment system already on. Remember, consistency will always win a race if your dial-in is set correctly.
If it ain't broke fix it anyway!
[Re: John_T_Brown]
#237091
02/27/09 09:47 AM
02/27/09 09:47 AM
WILD BILL
BROOK PARK, OH
That's pretty much why I put one in. I was getting my best passes when I could hit 3K footbrakeing. Problem was it was just on the edge of rolling out of the beams. When it did rolll it would through me all out of whack.
Now, it's so much nicer
[Re: WILD BILL]
#237092
02/27/09 10:07 AM
02/27/09 10:07 AM
MR_P_BODY
I tried to foot brake a couple of times, for me I would roll above 2200 rpm and when I hit the pedal the torque would slap the converter too hard and break the tires loose. If I go up on the converter it plants the tire
