Post deleted by Defbob
[Re: jamesc]
#237059
02/27/09 04:32 PM
02/27/09 04:32 PM
Re: Dual line Milidon oiling system
#237060
02/27/09 04:38 PM
02/27/09 04:38 PM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
I've been running the Milidon external for 6 or more years with any any issues nor have I ever replaced the green gasket. I do check to make sure the allen headed fasteners are tight when I have the oil filter off.
The negative reports make me nervous but I haven't had any problems...(yet)
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
[Re: WadeMetzinger]
#237063
02/27/09 06:41 PM
02/27/09 06:41 PM
Quicktree
by the time you figure out the gasket had blown you made be looking at a wall? how lucky do you feel?
[Re: Quicktree]
#237064
02/27/09 06:57 PM
02/27/09 06:57 PM
Posts: 1,141 Phoenix,Az.
hemicop
Phoenix,Az.
OKAY, you guys have me spooked now! I've ordered a Hemi from RBRE & they're in the process now of starting to piece it together. At my request they're outfitting it with a Milodon system since I didn't have any problems with my previous one. SOOO with all these alleged problems, what do you guys recommend. the thing's going in a Dart with an engineplate & stock front suspension, so space IS kind of an issue.
[Re: EJ440]
#237069
02/28/09 01:12 AM
02/28/09 01:12 AM
Posts: 1,165 Central Ohio, USA
Bigbeep
Central Ohio, USA
Mine blew the oil filter off and I went in to the wall!! coming back together now after 3years
System One filters
[Re: EJ440]
#237071
02/28/09 01:29 AM
02/28/09 01:29 AM
Bigbeep
Central Ohio, USA
Got one on the way . This was about the the 8th pass with this new motor.
You won't be disappointed. They are easy to pull apart and inspect also. I could detect the the fibers from rags used when I adjust the valves and wipe things off at the track and chips of paint off of the valve springs when torn down for inspection. Especially nice on fresh builds as well. Beep
