Dual line Milidon oiling system #237039
02/26/09 04:11 PM
02/26/09 04:11 PM
Cab_Burge Offline OP
I thought that I would share a little informatiom about those darn dual line Milidon oiling systems I spent the better part of 9 hours making one work, the system had one bad new line, the long one, a bad pump cover that has a internal air leak and a bad connection on the pick up in the oil pan(the customer had assembled the pick up, the new one piece non swiviling steel one pick up, in the pan before I got involved on the project) Luckily the customer had a old system that always worked that was on the bench so we could swap parts around to identify the bad new parts What a waste of time trouble shooting new parts I hope this helps some of you in the future, don't buy the Milidon stuff, use some other brand instead
Re: Dual line Milidon oiling system [Re: Cab_Burge] #237040
02/26/09 04:13 PM
02/26/09 04:13 PM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
Cab, one of the TWIN Rathburg's is about to slap you right about now man!
I have used the Milodon setup without issue before. And I also used the INDY setup. I'd prefer the INDY setup if I had to do it again.
Wes
Re: Dual line Milidon oiling system [Re: EvilB1Dart] #237041
02/26/09 04:16 PM
02/26/09 04:16 PM
Q
Quicktree Offline
Quicktree  Offline
Q
how did you address the leaking green gasket issue?
Re: Dual line Milidon oiling system [Re: Quicktree] #237042
02/26/09 04:29 PM
02/26/09 04:29 PM
Kentucky
sc301v Offline
sc301v  Offline
Kentucky
Not to hijack the thread,but does a indy plate work on a dual milodon pump very well instead of using the cast milodon plate.
Re: Dual line Milidon oiling system [Re: Cab_Burge] #237043
02/26/09 06:31 PM
02/26/09 06:31 PM
Oregon,USA
RAT PATROL Offline
RAT PATROL  Offline
Oregon,USA
I have one on mine. I have blown the filter off it once, blown the green gasket once, what next? Does make for a thrill ride though.
Re: Dual line Milidon oiling system [Re: Quicktree] #237044
02/26/09 07:59 PM
02/26/09 07:59 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
do away with the POS
http://www.moparts.org/Tech/Archive/bb/12.html
Re: Dual line Milidon oiling system [Re: Quicktree] #237045
02/26/09 09:20 PM
02/26/09 09:20 PM
In The Hills
jughed Offline
jughed  Offline
In The Hills
the Muscle Motors pump cover cured the problem very nicely. no more PITA green gasket leaks. money well spent!!!
http://musclemotorsracing.com/m/index.php?option=com_content&task=view&id=47&Itemid=5
Re: Dual line Milidon oiling system [Re: jughed] #237046
02/26/09 09:35 PM
02/26/09 09:35 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
I wanted one of the ones Ted makes, but he no longer makes them I waited too long to order one. they were much nicer than the Muscle Motor's one
Re: Dual line Milidon oiling system [Re: Defbob] #237047
02/26/09 11:47 PM
02/26/09 11:47 PM
jamesc Offline
jamesc  Offline
was that the one with the hardened steel plate on it?
Re: Dual line Milidon oiling system [Re: jughed] #237048
02/26/09 11:50 PM
02/26/09 11:50 PM
jamesc Offline
jamesc  Offline
Mike do you know what size fitting is in the back of that? is it a -12?
Re: Dual line Milidon oiling system [Re: jamesc] #237049
02/27/09 12:15 AM
02/27/09 12:15 AM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
Is it these that are no longer available?
http://eclecticinnovation.com/pumpcover.html
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Dual line Milidon oiling system [Re: Hemi Allstate] #237050
02/27/09 12:38 AM
02/27/09 12:38 AM
jamesc Offline
jamesc  Offline
that's the one i was talking about
Re: Dual line Milidon oiling system [Re: jamesc] #237051
02/27/09 08:10 AM
02/27/09 08:10 AM
In The Hills
jughed Offline
jughed  Offline
In The Hills
james, it is a 12.
Re: Dual line Milidon oiling system [Re: Hemi Allstate] #237052
02/27/09 08:22 AM
02/27/09 08:22 AM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
That's the one. I was told by a friend of his that he stopped making them.
Re: Dual line Milidon oiling system [Re: Cab_Burge] #237053
02/27/09 09:52 AM
02/27/09 09:52 AM
Peoples republic of clackamas ...
atoetly Offline
atoetly  Offline
Cab I took other peoples advise and removed the filter adaptor and drilled and taped for AN fittings and a remote oil filter. With my new front suspension I will now be able to run a dual line system and the new block as the provisions to run a line right to the block.
Re: Dual line Milidon oiling system [Re: atoetly] #237054
02/27/09 10:03 AM
02/27/09 10:03 AM
Eagleville Tn.
rtstreet Offline
rtstreet  Offline
Eagleville Tn.
i had problems with the milodon loosing prime.
Re: Dual line Milidon oiling system [Re: rtstreet] #237055
02/27/09 10:45 AM
02/27/09 10:45 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I use a Milodon duel line setup and never have had a problem. I use a static pickup in the bottom of the 12 quart pan. I also use a blueprinted hi volume melling pump with the Milodon bottom plate and cover and filter adapter. I use the good original milodon gasket between the pump cover and oil filter adapter. I've always had instant oil pressure on startup, even after an oil and filter change. Dave
Re: Dual line Milidon oiling system [Re: quickd100] #237056
02/27/09 01:19 PM
02/27/09 01:19 PM
Carson City, NV
440sourcedotcom Offline
Carson City, NV
We are now making billet external pumps. Take a look.
http://www.440source.com/oilpumps.htm
Post deleted by Defbob [Re: 440sourcedotcom] #237057
02/27/09 02:52 PM
02/27/09 02:52 PM
Re: Dual line Milidon oiling system #237058
02/27/09 03:51 PM
02/27/09 03:51 PM
jamesc Offline
jamesc  Offline
how is the steel plate sealed to the cover and is it certain they're not going to be made anymore?
