Dual line Milidon oiling system
#237039
02/26/09 04:11 PM
02/26/09 04:11 PM
Posts: 43,292 Bend,OR USA
Cab_Burge
I thought that I would share a little informatiom about those darn dual line Milidon oiling systems ![](/ubbthreads/images/graemlins/rant.gif) I spent the better part of 9 hours making one work, the system had one bad new line, the long one, a bad pump cover that has a internal air leak ![](/ubbthreads/images/graemlins/shruggy.gif) and a bad connection on the pick up in the oil pan(the customer had assembled the pick up, the new one piece non swiviling steel one pick up, in the pan before I got involved on the project) ![](/ubbthreads/images/graemlins/rant.gif) Luckily the customer had a old system that always worked that was on the bench so we could swap parts around to identify the bad new parts ![](/ubbthreads/images/graemlins/boogie.gif) What a waste of time trouble shooting new parts ![](/ubbthreads/images/graemlins/maad.gif) I hope this helps some of you in the future, don't buy the Milidon stuff, use some other brand instead ![](/ubbthreads/images/graemlins/thumbs.gif) ![](/ubbthreads/images/graemlins/Twocents.gif)
Re: Dual line Milidon oiling system
[Re: Cab_Burge]
#237040
02/26/09 04:13 PM
02/26/09 04:13 PM
Posts: 6,341 Heaven
EvilB1Dart
Heaven
Cab, one of the TWIN Rathburg's is about to slap you right about now man! ![](/ubbthreads/images/graemlins/biggrin.gif) I have used the Milodon setup without issue before. And I also used the INDY setup. I'd prefer the INDY setup if I had to do it again. Wes
[Re: jamesc]
#237051
02/27/09 08:10 AM
02/27/09 08:10 AM
Posts: 1,229 In The Hills
jughed
In The Hills
Mike do you know what size fitting is in the back of that? is it a -12?
james, it is a 12. ![](/ubbthreads/images/graemlins/thumbs.gif)
Post deleted by Defbob
[Re: 440sourcedotcom]
#237057
02/27/09 02:52 PM
02/27/09 02:52 PM
