Post deleted by Defbob [Re: jamesc] #237059
02/27/09 04:32 PM
02/27/09 04:32 PM
Re: Dual line Milidon oiling system #237060
02/27/09 04:38 PM
02/27/09 04:38 PM
Tulsa, Ok
WadeMetzinger Offline
Tulsa, Ok
I've been running the Milidon external for 6 or more years with any any issues nor have I ever replaced the green gasket. I do check to make sure the allen headed fasteners are tight when I have the oil filter off.
The negative reports make me nervous but I haven't had any problems...(yet)
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: Dual line Milidon oiling system #237061
02/27/09 05:34 PM
02/27/09 05:34 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
We are now making billet external pumps. Take a look.
http://www.440source.com/oilpumps.htm
Nice options out there.
I've been running the billet oil pump cover with the hardened steel plate. No issues. its a shame they don't make them anymore, its a nice part.
Wish I would have picked up one when they were available..One thing about the Indy cover, milodon, or Muscle motors cover, being aluminum they were faster than you would ever expect. I guess when it gets pretty grooved up, it can be surfaced/planed etc.
I bet the stainless would were next to none compare to the aluminum counter part.
Re: Dual line Milidon oiling system #237062
02/27/09 06:21 PM
02/27/09 06:21 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
yea Dave that's what i figured. i sent them email asking if they were going to make another batch but from the posts here i guess not. i never liked the idea of running the pump gears against aluminum and only use the milodon pump for it's external entry, i prefer iron pumps.
Re: Dual line Milidon oiling system [Re: WadeMetzinger] #237063
02/27/09 06:41 PM
02/27/09 06:41 PM
Q
Quicktree Offline
Quicktree  Offline
Q
by the time you figure out the gasket had blown you made be looking at a wall? how lucky do you feel?
Re: Dual line Milidon oiling system [Re: Quicktree] #237064
02/27/09 06:57 PM
02/27/09 06:57 PM
Phoenix,Az.
hemicop Offline
hemicop  Offline
Phoenix,Az.
OKAY, you guys have me spooked now! I've ordered a Hemi from RBRE & they're in the process now of starting to piece it together. At my request they're outfitting it with a Milodon system since I didn't have any problems with my previous one.
SOOO with all these alleged problems, what do you guys recommend. the thing's going in a Dart with an engineplate & stock front suspension, so space IS kind of an issue.
Re: Dual line Milidon oiling system [Re: hemicop] #237065
02/27/09 07:11 PM
02/27/09 07:11 PM
Cab_Burge Offline OP
I was told that RBRE has thier own system that is fool proof, according to Bob Mazzolini Call RBRE and ask them about thier system and see if you may like it better.
Re: Dual line Milidon oiling system [Re: Cab_Burge] #237066
02/27/09 07:13 PM
02/27/09 07:13 PM
Phoenix,Az.
hemicop Offline
hemicop  Offline
Phoenix,Az.
Okay, thanks. He onlt mentioned it in passing so I thought it was unavailible or something......
Re: Dual line Milidon oiling system [Re: RAT PATROL] #237067
02/28/09 01:01 AM
02/28/09 01:01 AM
E
EJ440 Offline
EJ440  Offline
E
Mine blew the oil filter off and I went in to the wall!! coming back together now after 3years
Re: Dual line Milidon oiling system [Re: EJ440] #237068
02/28/09 01:11 AM
02/28/09 01:11 AM
E
EJ440 Offline
EJ440  Offline
E
before
Re: Dual line Milidon oiling system [Re: EJ440] #237069
02/28/09 01:12 AM
02/28/09 01:12 AM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
System One filters
Re: Dual line Milidon oiling system [Re: Bigbeep] #237070
02/28/09 01:20 AM
02/28/09 01:20 AM
E
EJ440 Offline
EJ440  Offline
E
Got one on the way . This was about the the 8th pass with this new motor.
Re: Dual line Milidon oiling system [Re: EJ440] #237071
02/28/09 01:29 AM
02/28/09 01:29 AM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
You won't be disappointed. They are easy to pull apart and inspect also. I could detect the the fibers from rags used when I adjust the valves and wipe things off at the track and chips of paint off of the valve springs when torn down for inspection. Especially nice on fresh builds as well. Beep
Re: Dual line Milidon oiling system [Re: Bigbeep] #237072
02/28/09 09:37 AM
02/28/09 09:37 AM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
I have a vintage Milodon system that has a replacement green gasket and isn't the gasket made out of kevlar?? Milodon says because of how slick it is it has the potential to drip, but they also emphasize making sure the two bolt are torqued down properly.
Re: Dual line Milidon oiling system [Re: Defbob] #237073
02/28/09 11:37 AM
02/28/09 11:37 AM
Sherwood park, Alberta.
go green Offline
go green  Offline
I battled with the Milodon system for years .
I works good when it works .
Spinning the engine over and not have oil pressure is acceptable.
I now have a Plueger oil pump .RCD sells them for $720.
CNC Machined from billet 7075-T6 aluminum and hard anodized for wear resistance.
Computer designed passages, chambers and porting provide exact requirements with proper timing and flow.
Heat treated chrome-moly Gerotor gears.
Complete systems engineered for funny cars and dragsters each with stainless steel swept bend tubing and fittings.
Systems available with barbed fittings for slip-on rubber hose or with AN fittings for braided hose.
All pump fittings have been computer designed and machined to provide maximum flow at minimum weight. Standard AN fittings are not used because of their stepped interiors which restrict flow.
Each pump is flow tested and pressure checked
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
