Re: Fired up after a long sleep. Sounded good, then...
[Re: stumpy]
#2370111
09/13/17 03:26 PM
09/13/17 03:26 PM
Challenger 1
Cincinnati, Ohio
Nothing worse than some yoyo that tightens the oil filter to the point you have to chisel it off to change oil. That will happen with no lube on the gasket...IMO.
[Re: amxautox]
#2370119
09/13/17 03:36 PM
09/13/17 03:36 PM
Posts: 96,658 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
And some people can't turn a filter 3/4 turn by hand. So, use a wrench as needed.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: amxautox]
#2370132
09/13/17 03:55 PM
09/13/17 03:55 PM
Challenger 1
Cincinnati, Ohio
And some people can't turn a filter 3/4 turn by hand. So, use a wrench as needed. Exactly. When someone says never a wrench needed I think of trucks, excuse me.
[Re: finn]
#2370144
09/13/17 04:13 PM
09/13/17 04:13 PM
Posts: 20,521 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
Double gasket will do that. Yup. Always check the old filter to make sure the gasket came off with it. I did that one time when the car was parked on a slight incline. I started it and hopped back out and noticed oil running out from right behind the front tire. Dove back in and shut it off. Big nessy mess to clean up, but didn't hurt the engine. I was taught to run a film of oil around the rubber sealing ring and hand screw it snug with one hand only.
[Re: Neil]
#2370208
09/13/17 05:30 PM
09/13/17 05:30 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
I was taught to use fresh oil on a new filter gasket. It's already there when I fill the filter. Never used the wrench to tighten 'em. Always needed one to remove 'em.
Only time I had a filter isues was... You guessed it the old gasket was still there. I only needed to do that once.
I have mechanical Aptitude. I can screw up anything.
[Re: calmopar]
#2370358
09/13/17 09:59 PM
09/13/17 09:59 PM
Posts: 8,395 Highland, MI.
Sunroofcuda
Highland, MI.
For automotive / light truck oil changes, I always hand tighten so they are SNUG - probably 3/4 turn after the gasket makes contact. I use a coating of drain oil to lubricate the new gasket. I've also experienced the dreaded double gasket debacle on my old (new) 96 Ram back when it was a couple years old. In the driveway of course. Started it up & heard a gurgling noise & oil streaming onto the ground - shut it off immediately. No problems - just a mess.
[Re: calmopar]
#2370623
09/14/17 12:00 PM
09/14/17 12:00 PM
Posts: 12,798 East Bay, N. Cal.
calmopar
East Bay, N. Cal.
Well my hand-tightening didn't quite work...i am not strong enough I suppose...another 4+ quarts on the ground. Arrgh! Got a K&N with the nut at the top and used a wrench to tighten it up - all is good now except for all the oil in the engine compartment.
I'll take some pics of the Dart - it's an interesting one. All black 69 GTS 383 auto stripe delete. Kind of a factory sleeper.
Trying to enjoy life!
[Re: calmopar]
#2370719
09/14/17 01:50 PM
09/14/17 01:50 PM
Posts: 2,855 Pattison Texas
CSK
Pattison Texas
sounds like the oil pump relief valve is stuck, need to pull it out & clean it out.
[Re: CSK]
#2370859
09/14/17 06:38 PM
09/14/17 06:38 PM
Posts: 3,044 N.W. Florida
Fat_Mike
N.W. Florida
sounds like the oil pump relief valve is stuck, need to pull it out & clean it out. Yeah, something ain't right. I'm not getting into the wrench/no wrench or manufacturers instructions debate, but you don't need to be Hercules to tighten an oil filter sufficiently. If it's dumping oil like that after a good hand tightening, something else is going on. Don't let it ruin your motor! Do you have an oil pressure gauge?
[Re: Porter67]
#2370867
09/14/17 06:52 PM
09/14/17 06:52 PM
bboogieart
Lost and Spaced
Thank god us as a group here are not responsible for world peace. Id just like to see more pics of that dart! Me 2
