1964 D100 Hot rod truck
#2369530
09/12/17 05:47 PM
09/12/17 05:47 PM
Posts: 425 Eastern Ontario
shaker340
Eastern Ontario
For my fellow Moparts members, I am near done this truck. More to follow as I finish up some tuning and cosmetic details. Its got a 440 with 727, 3:23 8 3/4 rear, a seven inch drop in front and axle flip in the rear.
Mike
2008 Challenger SRT8 1940 Chrysler Royal coupe
Re: 1964 D100 Hot rod truck
[Re: basketcase]
#2369928
09/13/17 10:18 AM
09/13/17 10:18 AM
shaker340
Eastern Ontario
Poorboy, the front end is a mustang style kit from Rod Weimer. Its a 5 inch drop with 2 inch drop spindles.
Mike
[Re: shaker340]
#2369930
09/13/17 10:30 AM
09/13/17 10:30 AM
shaker340
Eastern Ontario
A few more pics of the truck. Note the fuel tank is moved from the cab into the box. I also removed the entire inner liner and built a new frame and floor. I made the tubs to fit the inside of the box sides. The box is a 1966. I preferred the tail lights than what was on a 64.
[Re: earlymopar]
#2369976
09/13/17 12:23 PM
09/13/17 12:23 PM
shaker340
Eastern Ontario
The carpet trim was made by exline custom auto. They make parts for these sweptline trucks. I have molded carpet in mine.
Mike
[Re: shaker340]
#2370098
09/13/17 03:03 PM
09/13/17 03:03 PM
shaker340
Eastern Ontario
stumpy, yes its the orange panel lying in the bed. It will have some Aluminum diamond plate on it as well as two handles. The floor of the bed and backside of tailgate will be covered in the Aluminum diamond plate too.
Mike
[Re: earlymopar]
#2370153
09/13/17 04:28 PM
09/13/17 04:28 PM
Posts: 2,684 Des Moines IA
Soopernaut
Des Moines IA
Nice work and great looking truck. I'm curious about the edge trim on your floor (looks good btw). What are those off of or where did you get them? I have a 65 series 1 (also 4-head light) and it doesn't have edge trim on the OEM rubber mat so I've been thinking of making my own.
- EM They were a factory option but it is difficult to find good used ones. As mentioned, Kenny Exline makes aftermarket ones.
1970 Dodge d100/eventually going on a 77 D100 frame
[Re: shaker340]
#2392843
10/25/17 12:06 PM
10/25/17 12:06 PM
Posts: 1,629 OH
Red383
OH
The carpet trim was made by exline custom auto. They make parts for these sweptline trucks. I have molded carpet in mine.Mike Where did you get your molded carpet? How did it fit? Sweet truck! Thanks
[Re: Triggerfish]
#2393353
10/26/17 01:41 PM
10/26/17 01:41 PM
shaker340
Eastern Ontario
Triggerfish, thanks for compliments. Yours looks great too. Mine was not a heater delete, I relocated them, take a closer look at the engine bay beside the air cleaner, there are two holes for the heater core. I moved the heater box to be a center mounted, as it looks better on the inside of the cab too.
All of the electronic ignition stuff is under the dash and the starter relay stuff is down low on the frame. I wanted very clean clutter free firewall look.
I used Rod Weimer mustang 2, and it works very nice. Good instructions to install, so was not difficult. A little massaging to make everything work but worth it.
Mike
[Re: shaker340]
#3004614
01/12/22 03:45 PM
01/12/22 03:45 PM
Posts: 1 Sacramento, Ca
422Cuda
Sacramento, Ca
Mike Hey Mike, this front clip looks great and it doesn’t seem like you had to butcher the frame up like the other swaps. Do you have pics of the install process? And what did you have to do to the frame to get it to fit? I just bought my first Swepty and am looking to upgrade the front suspension. Any help alone greatly appreciated. Thanks, Matt
[Re: 422Cuda]
#3006757
01/19/22 12:19 PM
01/19/22 12:19 PM
shaker340
Eastern Ontario
Matt, sorry for late reply, I am not on Moparts too much lately. No cutting of the frame, but you will need to box a section of the frame in. See attached.
Mike
[Re: shaker340]
#3012989
02/07/22 11:38 AM
02/07/22 11:38 AM
Posts: 34,880 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
remember when no one did sweptline trucks, now there are bazillions of them .. mine was done 20 years ago now
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
