Old stinky bad gas - help me get it out of the tank #2368988
09/11/17 08:02 PM
09/11/17 08:02 PM
East Bay, N. Cal.
calmopar Offline OP
calmopar  Offline OP
East Bay, N. Cal.
What's going to work? How about taking a high-flow electric fuel pump, plumbing it in before the gas filter, and having it dump through a tube into a bucket? how fast would that go? What would you do? I have to get some bad gas out of three cars - stat.
Trying to enjoy life!
Re: Old stinky bad gas - help me get it out of the tank [Re: calmopar] #2368997
09/11/17 08:16 PM
09/11/17 08:16 PM
On The Boat, On The Lake, Wa. ...
amxautox Online content
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Online Content
electric inline fuel pump with long hose on one end, shorter hose on the other end, or 2 long hoses, pump's inlet hose in tank inlet, outlet hose in jerry can, pump it into a 5 gal gas can, dump it on the berry bushes or weeds you want to kill.
or leave the cars in the bad part of town, they'll drill a hole in gas tank, and no more gas, you'll just have to remove the tank to fix the hole.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Old stinky bad gas - help me get it out of the tank [Re: calmopar] #2369007
09/11/17 08:24 PM
09/11/17 08:24 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
Do you have enough containers for it all?
If its a few gallons per vehicle i'd just siphon it off.
Goes pretty quick with a decent sized hose.
Re: Old stinky bad gas - help me get it out of the tank [Re: nomore65BelvJim] #2369022
09/11/17 09:08 PM
09/11/17 09:08 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I usually just disconnect the hose before the fuel pump and let gravity do the work. Put a 1 gallon ice cream bucket under there to catch it and use a vise-grip pliers for a shut off.
If the lines are blocked or broken then just run a hose down the tank inlet and siphon it out.
You can get a hose with a bulb to prime it at most Auto parts, or Hard Ware stores.
Dump it into a bigger container and repeat.
The filter should be after the pump, unless you have the modern electric pump in tank kind of set-up?
I have mechanical Aptitude.
I can screw up anything.
Re: Old stinky bad gas - help me get it out of the tank [Re: calmopar] #2369037
09/11/17 09:32 PM
09/11/17 09:32 PM
P
Porter67 Offline
Porter67  Offline
P
There are many ways Ive done it.
You can easily put 3 feet of rubber line on the front steel line and turn your compressor down to 5 psi and with your normal air blower and a red shop rag you can have it drained by pressure in a matter of minutes.
However one thing your going to miss by just draining it is the jelled up bad stuff in the tank if its really old, that sticks to the inside and then your buying the clear plastic filters by the 3 pack.
If its that bad, but you didnt mention how old it was.
Ive had 3-4 year old gas that reaked but I just diluted with new gas and ran out the old but kept a good clear filter on it.
Going back to if it has gotten really bad, drain it and drop it or drop it as it is, its not hard, two straps, a 2x12 on a floor jack or simply rest it on your knees.
Anyway you do it, its a nasty few hours work but when done your good to go.
But again, if its 3-4 years old, id consider dilute it and run it out, ive never had an issue with a pre filter.
Re: Old stinky bad gas - help me get it out of the tank [Re: calmopar] #2369042
09/11/17 09:46 PM
09/11/17 09:46 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Depending on how old the residue is, it might be a good idea to run some good additive through it for a while afterwards as the varnish sometimes works it's way into engine and can cause issues. Valve guides can gum up and cause major problems with pushrods etc. Seen it happen on a 383 once but was told it is more common in old mower equipment that sat a while.
Re: Old stinky bad gas - help me get it out of the tank [Re: buildanother] #2369049
09/11/17 09:59 PM
09/11/17 09:59 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Just wondering, what's the deal?
What kind of cars, how much gas we talkin' about, and not my business, but why? cause it stinks? you got a leak or something. It shouldn't be stinking up the place.
I've used 4 or 5 year old gas diluted with twice the amount of fresh myself without out issue. Never tried to save those tanks though.
Re: Old stinky bad gas - help me get it out of the tank [Re: calmopar] #2369063
09/11/17 10:26 PM
09/11/17 10:26 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Ask Scott Smith, he has experience with bad gas. grin
Re: Old stinky bad gas - help me get it out of the tank [Re: calmopar] #2369077
09/11/17 10:57 PM
09/11/17 10:57 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Cost you about 6 bucks...
Harbor Freight...
Re: Old stinky bad gas - help me get it out of the tank [Re: RSNOMO] #2369087
09/11/17 11:21 PM
09/11/17 11:21 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Yeah, That's the ticket.
Re: Old stinky bad gas - help me get it out of the tank [Re: calmopar] #2369149
09/12/17 12:57 AM
09/12/17 12:57 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I'd pull the tank and have it boiled and sealed (or replaced), and I's also get a new pick up, fuel pump, filter, and rebuild or at least drain the carb and clean it. If you don't you might be chasing bad fuel gremlins forever, I hear it A LOT from my customers who've tried to cut corners.
.02
Re: Old stinky bad gas - help me get it out of the tank [Re: calmopar] #2369166
09/12/17 01:26 AM
09/12/17 01:26 AM
P
Porter67 Offline
Porter67  Offline
P
Of course your gonna hear that, your a carb guy, they dont come to you for foot problems do they? Bugs, maybe!
Re: Old stinky bad gas - help me get it out of the tank [Re: ScottSmith_Harms] #2369168
09/12/17 01:28 AM
09/12/17 01:28 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
.02
That's right way to do it.
The dirty way is an electric pump with fuel lines connected. Pump out as much as you can and then put in a can of Heet and some fresh gas.
I've offered to help before
Re: Old stinky bad gas - help me get it out of the tank [Re: ScottSmith_Harms] #2369197
09/12/17 02:19 AM
09/12/17 02:19 AM
.02
So, to get rid of some "old stinky fuel" you'd automatically have him spend several hundred dollars...before you even know how old the gas is?
Nice.
Re: Old stinky bad gas - help me get it out of the tank [Re: nomore65BelvJim] #2369201
09/12/17 02:22 AM
09/12/17 02:22 AM
Kirkland, Washington
Pacnorthcuda Offline
.02
Nice.
And the OP is talking THREE cars, not one!
Re: Old stinky bad gas - help me get it out of the tank [Re: calmopar] #2369204
09/12/17 02:24 AM
09/12/17 02:24 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Nice.
Replies like that sure make answering questions on Moparts a lot less enjoyable. No wonder so many well meaning and knowledgeable people have bailed from this place.
Re: Old stinky bad gas - help me get it out of the tank [Re: Pacnorthcuda] #2369206
09/12/17 02:26 AM
09/12/17 02:26 AM
.02
Nice.
Good point. So were talking a couple G's then. Even better.
Re: Old stinky bad gas - help me get it out of the tank [Re: calmopar] #2369209
09/12/17 02:30 AM
09/12/17 02:30 AM
East Bay, N. Cal.
calmopar Offline OP
calmopar  Offline OP
East Bay, N. Cal.
Thanks everyone. I agree with Scott that there is a right way to do this but right now I am just wanting to get the cars running enough to move them around. They're going going gone with any luck and they will all need work. For the fuel systems, it'll be from the the rooter to the tooter. The new owners can sort that out.
Thanks for the offer, Chris. Thing is, newly dealing with custody issues with my kids and working my job solo, I never know what 90 minutes of what day of what week I'll be free to work on things, and you've got a long drive to help me. I really do appreciate it! Meanwhile I found the fender tag for the 71 RR so if you want a closer look come on down.
So I get one car going and it sounds like it's running on 4 cylinders. That would be cool if it were a Plymouth Arrow, but it's a 383. So my old brain thinks cap, rotor, points, plugs, wires. That about right?
Thanks, Moparts!
Re: Old stinky bad gas - help me get it out of the tank [Re: calmopar] #2369248
09/12/17 07:41 AM
09/12/17 07:41 AM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
I recently screwed about for a couple of hours attempting to remove all fuel from my motorcycle tanks using bulb type siphon devices and letting the cycles run until tanks were empty. These devices sort of worked,,,but difficult to maintain siphon for last 1/2 gallon or so.
Never again to waste this much time. Had a supercharged Jag XJR one time where both in tank fuel pumps had failed,,,,tank had to be removed to replace them,,,,yes I know it's a Jag,, and the tank had some 15 gallons of fuel in it. A real pain in the [censored].
https://www.amazon.com/gp/product/B00QSPU0NS/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
Used this to refuel cycles with fresh gas from one of my cars. Yes likely cheaper to buy an electric pump,,,but like the idea of portability in a hard case that I can just throw in the trunk to help others or myself in an out of fuel emergency.
Re: Old stinky bad gas - help me get it out of the tank [Re: Sxrxrnr] #2369448
09/12/17 03:21 PM
09/12/17 03:21 PM
dogdays Offline
dogdays  Offline
My $500 F150 has two tanks and hasn't been driven a lot. Now both tanks have the pickup screens plugged with rust, I suppose.
So I am going to use my method, which is to snake a rubber fuel line down into the tank and pump out as much as I can using a cheap electric pump I bought years ago. I use an inline filter after the pump, the $3.96 one from Walmart.
Then I will remove the old tanks and replace with new tanks, around $100 each if you know where to shop. The fuel pickups and senders I'll try my best to keep as they are original and we all know how good the aftermarket replacements usually are!
Yes, the fuel stinks, but it'll still burn. I mix with new gas, about 3:1, new to old. It does stink up the neighborhood. I am secretly proud of that, because 98% of people won't know what that smell is. I use it in my carbureted vehicle and have never had a problem with it, even old 40:1 outboard engine fuel.
I know there won't be any consequences for most of you, but in most places disposing used petroleum products by pouring on the ground is illegal, as it can pollute groundwater. If it's not illegal where you live, it is still immoral and most likely fattening. The stuff you pour on the ground today may not hit the water supply until your grandchildren are drinking it.
A fun thing to do with old gasoline is to burn it. Used motor oil and hydraulic oil will burn surprisingly well. This is, of course, dangerous so I am saying this merely as a joke. You wouldn't want to expose your loved ones to flames shooting 5' out of the burn barrel, although it is quite an arresting sight.
R.
