Page 5 of 9 1 2 3 4 5 6 7 8 9
Re: Project VIP to drag week 2017 [Re: jyrki] #2368686
09/11/17 08:43 AM
09/11/17 08:43 AM
Norway (old world)
Oyvind Mopar Offline
Norway (old world)
Please check your valveguide clearance carefully. More hp means more heat means more material growth..... means need for bigger clearance. Hope it works out for you, good luck!!
Re: Project VIP to drag week 2017 [Re: jyrki] #2368780
09/11/17 12:41 PM
09/11/17 12:41 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
It's easy to sit here and "Monday morning quarterback" this situation...... But what came to my mind was that perhaps this is a by-product of whatever the previous valvetrain issue that was causing the retainer and lock problems(unless new valves have been installed since that all happened).
Re: Project VIP to drag week 2017 [Re: jyrki] #2368784
09/11/17 01:01 PM
09/11/17 01:01 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
8.08! They got it back together.
Re: Project VIP to drag week 2017 [Re: jyrki] #2368793
09/11/17 01:18 PM
09/11/17 01:18 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
Whats the motor combo seems i missed that somewhere sorry
Re: Project VIP to drag week 2017 [Re: jyrki] #2368795
09/11/17 01:20 PM
09/11/17 01:20 PM
So. Burlington, Vt.
So. Burlington, Vt.
That's fantastic!!
Re: Project VIP to drag week 2017 [Re: jyrki] #2368798
09/11/17 01:36 PM
09/11/17 01:36 PM
IL
furious70 Offline
furious70  Offline
IL
it's a turbo big block, but I've lost track of what this incarnation is. It's been turbo'ed for close to a decade I think.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Project VIP to drag week 2017 [Re: jyrki] #2368799
09/11/17 01:37 PM
09/11/17 01:37 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Jyrki, I'm very happy to see it running. Good luck the rest of the way.
Doug
Re: Project VIP to drag week 2017 [Re: jyrki] #2368846
09/11/17 03:00 PM
09/11/17 03:00 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Really glad to hear the car is back together. I think it is a brewer head combo, and when I heard he broke a valve.... well it didn't seem likely he would get it back into one piece.
Re: Project VIP to drag week 2017 [Re: jyrki] #2369211
09/12/17 02:31 AM
09/12/17 02:31 AM
Finalnd, Perkele
jyrki Offline OP
jyrki  Offline OP
Finalnd, Perkele
Thanks all! Even though we have had some bad luck, we have also had good. For example, we went to Cordova on saturday and broke it there. Had we come there on sunday, we would not have had time to repair the problem. I do not know what is the reason, maybe just old parts? But, I had spare parts and with the support of a local Layne machine shop we could get the job done. The other turbo was also hurt because some particles run through it, and it's temporarily fixed now, just turning the turbine down in a lathe. Therefore, we weren't hoping for much since we only are running with about 1.5 turbo now. So, the result was a pleasent surprise, especially bcause we had nelected tightening the throttel cable support; the throttle was only 75% up to 5.5 seconds after which it started to slip and was zero at the traps. We had and have our share of problems moving to gateway, the fan quit working and we were overheating. So, took some time to get there to the hotel, also some electrical and leak problems. They can be fixed, but it takes time and we have a lot of else to do.But most likely we will be able to make it to gateway in the morning!
Plynouth VIP '67 TT IC EFI
Re: Project VIP to drag week 2017 [Re: jyrki] #2369232
09/12/17 04:16 AM
09/12/17 04:16 AM
Hamburg / Germany
Den300 Offline
Den300  Offline
Hamburg / Germany
Jyrki, hope you all have enough Lapin Kulta and dont fall asleep behind the wheel ;-)
You guys doing an awesome Job and I love to see your fat landyacht running!
Cheers
Dennis
Hamburg/Germany
69 Chrysler 300
446cui Dual Quad
12.64 @ 110.7
Re: Project VIP to drag week 2017 [Re: jyrki] #2369252
09/12/17 08:22 AM
09/12/17 08:22 AM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Best of luck.
Watching and rooting for you
Re: Project VIP to drag week 2017 [Re: jyrki] #2369330
09/12/17 12:13 PM
09/12/17 12:13 PM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
Awesome car!up
Best of luck
72 Plymouth Roadrunner 11.08@123.25
Re: Project VIP to drag week 2017 [Re: Roughbird72] #2369337
09/12/17 12:21 PM
09/12/17 12:21 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Good luck! Following you on Facebook!
'63 Dodge 330
11.19 @ 121 mph
Re: Project VIP to drag week 2017 [Re: jyrki] #2369353
09/12/17 12:49 PM
09/12/17 12:49 PM
So. Burlington, Vt.
So. Burlington, Vt.
The 8.08 looked awesome from that big barge!!!
Hopefully the worst of it is behind you.
Re: Project VIP to drag week 2017 [Re: jyrki] #2369358
09/12/17 12:53 PM
09/12/17 12:53 PM
IL
furious70 Offline
furious70  Offline
IL
and you definitely got love from the tower commentating the live feed!
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Project VIP to drag week 2017 [Re: jyrki] #2369446
09/12/17 03:15 PM
09/12/17 03:15 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
8.07! man its fun to watch that car go
Re: Project VIP to drag week 2017 [Re: CTD5.9] #2369821
09/13/17 12:50 AM
09/13/17 12:50 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Fantastic! Good luck on the remainder.
Sheldon
Re: Project VIP to drag week 2017 [Re: jyrki] #2369998
09/13/17 12:57 PM
09/13/17 12:57 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
Looks like the VIP is out of competition, dropped a valve. Sad to see, that thing is awesome.
Re: Project VIP to drag week 2017 [Re: jyrki] #2370020
09/13/17 01:22 PM
09/13/17 01:22 PM
Tulsa, Oklahoma
340Cuda Online content
340Cuda  Online Content
Tulsa, Oklahoma
Sad to see the VIP out.
We were able to go to St. Louis yesterday to watch. The car is even more impressive in person as far as performance and appearance.
Bill
Re: Project VIP to drag week 2017 [Re: jyrki] #2370066
09/13/17 02:21 PM
09/13/17 02:21 PM
So. Burlington, Vt.
So. Burlington, Vt.
Sucks for you guys...... But you gained some fans for sure.
Impressive effort from you guys right from the start. up
