Re: OK! No more BS. Time to start working.
[Re: sgcuda]
#2368103
09/10/17 12:23 AM
09/10/17 12:23 AM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Looks like everything was in the pan, and when I pulled the crank around, the counterweights dragged up the nest. The only thing I noticed inside of the engine itself was some minor surface rust on the side of one of the rods near the big end. Easy clean up with some scotchbrite or steel wool. Going to attempt to clean up the pan for now. Just out of disgust, I'd probably like to replace it, but Milodon doesn't make the full length pans anymore, just the ones with the front notch. Mine was modified like that back in '89 for the pinto rack. I'd really like one of the old 10 qt. full length pans, if anyone has one they want to part with.
[image][/image]
[Re: sgcuda]
#2368126
09/10/17 01:45 AM
09/10/17 01:45 AM
Posts: 452 Monrovia, So-Cal, USA
racerhog
Man... The Wife hit that one out of the ball park.... What a keeper !!!!! Maybe have that one blasted and re-zink it... Just food for thought.
Bob(Cowboy)Hogan Monrovia So-Cal
[Re: sgcuda]
#2368150
09/10/17 03:07 AM
09/10/17 03:07 AM
sgcuda
There was a small little bump and weird click when I was pulling it around. Everything turns and sounds fine now. I will be getting under and into the block with some light on Sunday for better inspection. Since there were never any rockers on the motor and the ports were all taped up, I don't see any reason to pull the heads at this point. But I will be putting my boroscope down the spark plug holes to check, just the same. Going to scrub clean the block walls and oil everything up before final assembly.
[image][/image]
[Re: sgcuda]
#2368707
09/11/17 10:12 AM
09/11/17 10:12 AM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
LOL, too funny. You need some rat traps.
[Re: sgcuda]
#2370396
09/13/17 10:50 PM
09/13/17 10:50 PM
sgcuda
Got the motor back together. Must have pulled it around at leat a dozen times already. Finished up the oiling system. Got my D'Rale killer oil filter housing mounted up. Tightened all of the fittings. Finished socking down the oil pan and intake manifold after letting the silicone set up. Powered up the gauges and hit the priming rod with the drill. I can here the spray bars bleeding out. I don't know how much pressure it made because the gauge stops at 99 psi. I can feel the drill load big time. Stuffed some carb fuel inlet washers under the regulator spring cap. Spun it around again. Maxing at 96 psi, less load on drill. Going in good direction. Decided to pull the engine around in 90 degree intervals to check for lifter bleed off. Engine stops solid at first 90 degrees. Loosened intake bolts up, since I remember on a SBC putting too long an intake bolt in and locking up the pushrods. No difference. Valve covers come off tomorrow night. Here we go again. Stupid squirrels...... Oh, and the rear main seal leaks. Boy am I surprised.
[image][/image]
[Re: sgcuda]
#2372446
09/17/17 11:26 PM
09/17/17 11:26 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
[Re: MadMopars]
#2373166
09/19/17 08:40 AM
09/19/17 08:40 AM
sgcuda
Glad you got to fire the motor finally. So what's the plan? You going to paint the car before you put the motor in, get it running and then paint it later, or? Yes. Right now, I still have to finish the X bar on the passenger side, steering column mounting, mid plate tabs, battery tray and fuel tab brackets Then I am going to paint the frame with Rustoleum. My plan is to paint it before racing, but I don't know if I want to wait that long. Might just spray bomb some primer on it.
