My Magnafuel 275 has died #2367759
09/09/17 02:26 AM
09/09/17 02:26 AM
W. Kentucky
justinp61 Offline OP
W. Kentucky
I took the Dart to T&T tonight to try out my CRT trans brake, found out my local track doesn't like trans brakes and radials. It ran 6.45 @ 108.10 foot braking with a 1.45 60' off the trailer. The second pass I left off the brake but was in second and ran 6.52 @ 108.49 with a 1.53 60'. The next two passes it spun leaving off the brake at 3500 and 2500 rpm's. I decided to make one more foot brake pass before loading up, it popped and died before the 594' cone running 6.49 @ 90 mph with a 1.40 60'. I looked at the gauges when it laid down and had no fuel pressure. Looking at the incremental's it was .122 faster at 330' than the first (6.45) pass so I'm thinking it would've been in the mid low 6.30's if the pump hadn't died.
So I need a new pump, something that can run continuously as I drive on the street a lot and can feed how ever many HP it takes to run 3350# 108 or so mph in the 1/8.
What do you guys recommend?
Re: My Magnafuel 275 has died [Re: justinp61] #2367763
09/09/17 02:40 AM
09/09/17 02:40 AM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
I ran the Mallory 140 on the street & strip. Trouble free for yrs.
Re: My Magnafuel 275 has died [Re: justinp61] #2367769
09/09/17 04:00 AM
09/09/17 04:00 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i've had a lot of luck with the Magnafuel. both my racecar & my streetcar run the 275. both have never had an issue. whats actually wrong with the pump?
Re: My Magnafuel 275 has died [Re: justinp61] #2367772
09/09/17 04:53 AM
09/09/17 04:53 AM
Sydney,Australia
tex013 Online content
tex013  Online Content
Sydney,Australia
Been running a Aeromotive pump daily and racing the last 4 years (?) maybe . Quiet and no dramas . The one below a 1000 series . Oh i also fitted their return regulator at the same time . Went from a Holley hp150
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: My Magnafuel 275 has died [Re: justinp61] #2367782
09/09/17 09:04 AM
09/09/17 09:04 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Holley black with return
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: My Magnafuel 275 has died [Re: rebel] #2367853
09/09/17 11:50 AM
09/09/17 11:50 AM
W. Kentucky
W. Kentucky
I don't have it off yet but it appears the motor is locked up.
Re: My Magnafuel 275 has died [Re: justinp61] #2367869
09/09/17 12:38 PM
09/09/17 12:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
It sounds like it was fat also being that
you went quicker when the pump was dying..
so after you get a pump try leaning it down
EDIT
I was running a pair of 140s on my stuff
before I swapped to injection but 1 of them
would work for you(Mallory 140)
wave
Re: My Magnafuel 275 has died [Re: justinp61] #2367870
09/09/17 12:39 PM
09/09/17 12:39 PM
tboomer Online work
tboomer  Online Work
Justin...Maybe you will get lucky. A few weeks back that Holley HP 150 locked up on me. Took it apart and cleaned up the gear assembly and it works just fine! I did install an Aeromotive S/S 11203 pump that works great! It may be a bit noisy for the street. Good luck!
Re: My Magnafuel 275 has died [Re: justinp61] #2367881
09/09/17 01:03 PM
09/09/17 01:03 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
In the past, Magnafuel has been excellent to deal with for parts and service.
I'd call them before buying a new pump.
Re: My Magnafuel 275 has died [Re: fast68plymouth] #2367906
09/09/17 01:59 PM
09/09/17 01:59 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
They still are and mine was rebuilt a while back and their service was awesome and easy to deal with............ thumbs
Re: My Magnafuel 275 has died [Re: fast68plymouth] #2367921
09/09/17 03:04 PM
09/09/17 03:04 PM
iagree upTthey will fix it and turn it around back to you fast and probably way cheaper than you can replace it work twocents scope1-800-321-7761 or direct support 1-719-532-1897 scope
Do you have a pre filter between the pump and gas tank? If not maybe a tiny bit of debris locked it up scope Good luck either way up
Re: My Magnafuel 275 has died [Re: justinp61] #2367938
09/09/17 03:49 PM
09/09/17 03:49 PM
W. Kentucky
W. Kentucky
Thanks guys.
I put seals in it about two months ago. Maybe I can get it off the car and apart this afternoon. Waiting on my brother to come by and help me push it in the shop.
Re: My Magnafuel 275 has died [Re: justinp61] #2367946
09/09/17 04:26 PM
09/09/17 04:26 PM
ccarson Offline
ccarson  Offline
Look at Product Engineering
Re: My Magnafuel 275 has died [Re: justinp61] #2368170
09/10/17 07:07 AM
09/10/17 07:07 AM
western PA
stevet340 Offline
stevet340  Offline
western PA
More than likely the small bearing nearest the fuel inlet and outlet froze up. I've seen 2 magnafuel pumps do this in the past 3 days... The bearing shouldn't cost more than $5-$10.
Re: My Magnafuel 275 has died [Re: justinp61] #2368294
09/10/17 01:39 PM
09/10/17 01:39 PM
Monrovia, So-Cal, USA
racerhog Offline
racerhog  Offline
Get another pump... Work on the tune-up and the power management for whatever track your running.... Spinning ant winning..... I agree... Sounds too fat..
Bob(Cowboy)Hogan
Monrovia So-Cal
Re: My Magnafuel 275 has died [Re: stevet340] #2368469
09/10/17 08:59 PM
09/10/17 08:59 PM
W. Kentucky
W. Kentucky
DING DING DING.........We have a winner!
Guys if your Magnafuel pump starts leaking replace the bottom bearing when you do new seals. It could save you some grief.
Re: My Magnafuel 275 has died [Re: justinp61] #2368559
09/10/17 11:32 PM
09/10/17 11:32 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Mine never leaked it just froze solid and got hot..........good info for next time........ beer
Re: My Magnafuel 275 has died [Re: justinp61] #2368712
09/11/17 10:35 AM
09/11/17 10:35 AM
W. Kentucky
W. Kentucky
The bearings in my pump are metric and made in Indonesia and Singapore. I guess nothing is made here anymore. Sad.
Re: My Magnafuel 275 has died [Re: justinp61] #2368718
09/11/17 10:54 AM
09/11/17 10:54 AM
an8sec70cuda Offline
If you still decide to get another one, the Aeromotive 11203 is a real good little pump. I ran one for a long time on my car running mid 9s at 3800 lbs...just a simple deadhead system w/ -8 line.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: My Magnafuel 275 has died [Re: justinp61] #2368785
09/11/17 01:02 PM
09/11/17 01:02 PM
Renton Washington
Triple Threat Offline
Renton Washington
My magnafuel 300 did the exact same thing. I sent mine back to MF and they fixed it up for me.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
