Question on mounting tires HELP
#236744
02/26/09 12:08 PM
02/26/09 12:08 PM
Posts: 408 Manhattan, IL
SixPackRT
Manhattan, IL
Does anyone have any ideas on geting beads to seat on both sides of the rim for putting tires on the rims for the first time. I have the tires on the rim, I just need to get both beads to seat to fill the tire up with air. P215/75's on a 6" rim. Thanks for the help. Scott
70 Coronet RT 440+6 64 Dodge 330 - Future Hemi Clone 17 Challenger Hellcat - Green Go Driver 86 Buick T-Type Turbo V-6
Re: Question on mounting tires HELP
[Re: SixPackRT]
#236749
02/26/09 12:25 PM
02/26/09 12:25 PM
Posts: 9,316 SoCal
68HemiB
SoCal
Various methods spring to mind from my previous life. See if any of these apply in your situation:
1. Regardless of other things you do, pull the core from the valve stem. This will allow air to pass through the stem the quickest. Once the beads seat, you can get the core back in while the air is escaping (just be careful not to launch the core across the shop).
2. Tighten a strap or band of some kind around the tread surface, which can force the beads apart somewhat. Tire shops have straps designed for this, but you can use a ratcheting hold-down strap to do the same thing. This is probably to easiest professional trick to do at home.
3. Tire shops sometimes use a lubricated doughnut placed between the outer tire bead and the rim. It restricts the air flow escaping from this gap, and will "squirt out" once more air is trapped inside the tire. I can't immediately think of a home version of this, but maybe someone has one lying around, or you could borrow/rent one from a shop (or just pay them to seat the tire...).
4. Commercial machines often have a mechanism to blast air at the lower tire bead. This builds up a high pressure area, sometimes trapping a bigger pocket of air inside the tire. I have no idea how one might do this at home, but throw it out there anyway.
5. If you have the ability to break a bead once seated, there is also an extreme measure of tubing the tire for a few days, and them removing the inner tube once the sidewalls and beads have been spread out.
Down to just a blue car now.
[Re: 68HemiB]
#236750
02/26/09 12:38 PM
02/26/09 12:38 PM
Posts: 7,371 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
Great advice. Just doing that will probably fix your problem. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: MoparforLife]
#236754
02/26/09 01:06 PM
02/26/09 01:06 PM
Challenger 1
Cincinnati, Ohio
Starting fluid and a match.
Used to use gasoline before I got the cheetah. It works good too, just gotta know what your doing. ![](/ubbthreads/images/graemlins/whistling.gif)
[Re: burdar]
#236755
02/26/09 01:17 PM
02/26/09 01:17 PM
Challenger 1
Cincinnati, Ohio
Sorry I'm the third guy to suggest that.
[Re: Challenger 1]
#236756
02/26/09 01:22 PM
02/26/09 01:22 PM
I've done the ratcheting hold-down strap and the piece of rope with a broom stick, both methods work quite well to get the beads to the outside edge of the rim where air can't escape. Also. . . for small tractor tires and wheel barrows and other small tires I have used the ole' shot of starting fluid, or carb cleaner, and lighter trick. It will instantly pop the bead on both sides of the rim simultaneously.*** ***This is highly dangerous method and should not be performed by anyone except me*** If you happen to blow yourself up while trying this hillbilly method don't blame me you were warned!!! ![](http://www.runemasterstudios.com/graemlins/images/goodnight.gif)
#236757
02/26/09 02:22 PM
02/26/09 02:22 PM
SixPackRT
Manhattan, IL
Thanks guys. Pulled the valve and put a strap aroung the outside, Twisted it around a bit and got it to seat. Holding the rim in one spot was a PITA. Was going to try the starting fluid trick, but never doing it before I was a little afraid. Thanks for all the help, you guys are the best. ![](/ubbthreads/images/graemlins/thumbs.gif) Scott
#236760
02/26/09 03:28 PM
02/26/09 03:28 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Sometimes you can hold them upright light they would be on the car and drop ot on the ground over and over. I've changed tires for a living a few years back. Some pop right on, others are a pain. I never tried the butane thing, but may just to have some fun ![](/ubbthreads/images/graemlins/biggrin.gif)
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
