Six pack start up #2367194
09/07/17 08:50 PM
09/07/17 08:50 PM
MA
BH27G1B Offline OP
BH27G1B  Offline OP
MA
Brand new Holley carbs on a 440+6 motor. Gave the center carb a little drink...wants to start, but is popping through the rear carb ?? Motor ran b4 the carb change..Nothing else touched... not enough fuel in the rear carb yet ??
Re: Six pack start up [Re: BH27G1B] #2367245
09/07/17 10:24 PM
09/07/17 10:24 PM
There are some sixpak gurus' on here & hopefully one of em will see this. Off hand I would give it a bit more gas & if no go then pull the plugs & see if they are bone dry or wet fouled.
Re: Six pack start up [Re: BH27G1B] #2367336
09/08/17 04:51 AM
09/08/17 04:51 AM
Missouri
Big_E Offline
Big_E  Offline
Missouri
Re: Six pack start up [Re: BH27G1B] #2367459
09/08/17 01:16 PM
09/08/17 01:16 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Originally Posted By BH27G1B
.................Gave the center carb a little drink...wants to start, but is popping through the rear carb ?? Motor ran b4 the carb change..Nothing else touched... not enough fuel in the rear carb yet ??
Well, for starters: try running it longer than 5 seconds. pity
Mo' Farts
Moderated by "tbagger".
Re: Six pack start up [Re: BH27G1B] #2367482
09/08/17 01:51 PM
09/08/17 01:51 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Before you even fire it up, you need to confirm the BASICS, that the installation is correct regarding linkage movement opening/cancellation, that the throttle blades in all 3 carbs open and close freely, no hang ups or stiff movement, hose routing for vacuum pods, vacuum advance, pcv, etc, etc, set and confirm initial fuel level in all 3 carbs before even attempting to start the motor and tuning the carbs air/fuel mixtures, curb idle, etc
Re: Six pack start up [Re: BH27G1B] #2367484
09/08/17 01:52 PM
09/08/17 01:52 PM
Go back through all the basics, spark plug wire location, carb. base gasket and so on up scope
The motor is telling you it ain't happy, it is crying for help work
Now get to work wrench grin
EDIT,try switching that carb. to the front and see if it is the carb. or the location work
Re: Six pack start up [Re: DAYCLONA] #2367528
09/08/17 03:41 PM
09/08/17 03:41 PM
MA
BH27G1B Offline OP
BH27G1B  Offline OP
MA
I was just thinking myself of cranking it over without fire to fill the bowls of all 3 carbs first. That's the hint that does the trick . I never had this issue before, and backfire never leads to anything good, it just happened this time. Thanks !
Re: Six pack start up [Re: BH27G1B] #2367530
09/08/17 03:47 PM
09/08/17 03:47 PM
MA
BH27G1B Offline OP
BH27G1B  Offline OP
MA
Thanks to everyone for the informative replies !! I should remember to fill and check the fuel level in all carbs from now on before I try starting.
