Fitech installed, misfire off idle?
#2367262
09/08/17 12:18 AM
09/08/17 12:18 AM
Posts: 1,306 Laveen, Arizona
GTSDart340
Laveen, Arizona
Finally got around to fixing my RPM noise code. Installed a shielded coaxial cable as the coil wire. Now I need to address a misfire (stumble?) Off idle. I have the idle pretty smooth, but the second I touch the gas, it stumbles, and sometimes takes a few seconds to catch up. I'm running a goefi 4 600 hp, with timing control, a digital 6al msd box and an msd distributor, no vacuum advance and locked out. It's on a fairly stock 360 with a 71 340 intake. It's got a slightly better than stock cam and headers. Thanks!
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
Re: Fitech installed, misfire off idle?
[Re: GTSDart340]
#2367521
09/08/17 04:23 PM
09/08/17 04:23 PM
Posts: 25,791 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Your hand-held controller has "Accel Pump" adjustments for various operating temperatures
