Page 2 of 3 1 2 3
Re: New product idea? [Re: RTSE4ME] #2366780
09/07/17 02:05 AM
09/07/17 02:05 AM
AndyF Offline OP
AndyF  Offline OP
Originally Posted By RTSE4ME
I would buy a set. You could put them on scales and would make corner balancing easier. Also you remove the tire.wheel variations.
Yeah I've seen the circle track guys do that with something similar. They have some fancy hub stands for smaller cars. Here is a link for guys who are into going around corners: https://grassrootsmotorsports.com/forum/...ta/59176/page1/
Re: New product idea? [Re: B3422W5] #2366829
09/07/17 08:30 AM
09/07/17 08:30 AM
jersey
Spaceman Spiff Offline
jersey
Originally Posted By B3422W5
Cant say as i can see the value. You have to jack the car around to get it to the exact correct height to line up the studs, then you cant do any brake or rear axle work.
Easier to just jack the car up and throw stands under it.
Thats just me.
You jack the car up, install them, then let the jack down. No need to line up. Same way you install a tire.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: New product idea? [Re: Spaceman Spiff] #2366843
09/07/17 10:19 AM
09/07/17 10:19 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Thats just me.
Yep... same way you install jackstands. At least with those you can do rearend and brake work.
Hey...... is this a nice toy? Sure. But to Mopar guys who whine about the extra cost of a forged crank over a cast crank in a race build.... lol( and thats the truth) i am surprised so many people think this deal being discussed is a must have. To me, i would spend my money elsewhere. Nice toy, but to 99% of us we can live perfectly well without it.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: New product idea? [Re: B3422W5] #2366852
09/07/17 10:51 AM
09/07/17 10:51 AM
langley b.c. canada
don miller Offline
don miller  Offline
langley b.c. canada
Not to hijack Andy's thread but is everybody missing whatelse is in Forest's picture-a way to visualise your instant center etc without doing any math? And Forest what's the story on that Dart?
Re: New product idea? [Re: AndyF] #2366880
09/07/17 11:49 AM
09/07/17 11:49 AM
Minnesota, USA
humpty Offline
humpty  Offline
Minnesota, USA
I'd buy a set. I can also see putting locking casters under them, maybe an add on base so you can move the car around. Love the handles on the blocks of wood too!
Re: New product idea? [Re: AndyF] #2366900
09/07/17 12:23 PM
09/07/17 12:23 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I think it is a great idea, nothing I hate more than trying to do something and having a #$%^ jack stand get in the way, for example transmission or header work.
68 Barracuda Formula S 340
Re: New product idea? [Re: AndyF] #2366904
09/07/17 12:29 PM
09/07/17 12:29 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I like them too, safer than jack stands and more room under the car.
Bill
Re: New product idea? [Re: AndyF] #2366905
09/07/17 12:31 PM
09/07/17 12:31 PM
New York
polyspheric Offline
polyspheric  Offline
New York
I like it.
I'd be looking at how to make them fit into a standard USPS flat-rate box, or 2 boxes.
If you're right over a weight limit, make some big holes, shipping is $$$.
Boffin Emeritus
Re: New product idea? [Re: AndyF] #2366924
09/07/17 01:15 PM
09/07/17 01:15 PM
AndyF Offline OP
AndyF  Offline OP
Sure, no problem cutting some big holes in the part to save weight. I could probably reduce the weight by 50% and still have plenty of strength by just cutting two triangles out of the center. They could also be made from aluminum although that requires TIG welding.
Re: New product idea? [Re: AndyF] #2366945
09/07/17 01:52 PM
09/07/17 01:52 PM
Sharpsburg Maryland
440farmer Offline
440farmer  Offline
Sharpsburg Maryland
Great Idea I'll cobble a set together for myself
Re: New product idea? [Re: humpty] #2366989
09/07/17 03:09 PM
09/07/17 03:09 PM
MD
RTSE4ME Online content
RTSE4ME  Online Content
MD
Casters are a good idea.I would like casters as an option.
Re: New product idea? [Re: RTSE4ME] #2367039
09/07/17 04:42 PM
09/07/17 04:42 PM
SE Washington
Forest Offline
Forest  Offline
SE Washington
How would bolting them to the rear go with a good posi or spool? Axles would have to be line up exactly the same?
Re: New product idea? [Re: Forest] #2367045
09/07/17 04:47 PM
09/07/17 04:47 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Hmm that is a good point, for a spool no problem just make sure you install them the same. I have yet to see a posi good enough that you couldn't muscle them around some and line them up.
Re: New product idea? [Re: RTSE4ME] #2367048
09/07/17 04:55 PM
09/07/17 04:55 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
No they are not, at least as pictured. Andy said and I agree, if another car say ran into the the car, it could rotate the wheels and allow it to roll off these stands, as nothing(?) is to prevent the wheel hubs from rotating. If you mount casters to the bottom, and do not significantly extend the base ( which the small base being the original benefit to most in the first place?), having a a moving car on casters with all its mass, only needs a caster to stick on something, a crack, a 1/4" nut, cable, etc, and the car could easily roll the wheel hubs and off the stands. Likely, probably not, would some one be under a rolling car, again not likely, but the "stuck" caster should be considered, IMO.
Re: New product idea? [Re: AndyF] #2367071
09/07/17 05:34 PM
09/07/17 05:34 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
AndyF: So preferred payment through Paypal, credit card, or money order??? LOL
Absolutely, this is an interesting tool, I think I would like a set in my garage...any pricing ideas, or too early to tell at this poing in time?
Re: New product idea? [Re: AndyF] #2367130
09/07/17 07:12 PM
09/07/17 07:12 PM
AndyF Offline OP
AndyF  Offline OP
Casters could be mounted on piece of tubing that bolted to the upright. That would be fairly easy to fabricate. I've never done that before but it might be interesting to do. If nothing else it would give me an easy way to push the car that I'm not working on out of the way.
I'm not sure on pricing. I know what people would want to pay for a pair but I'm not Harbor Freight. I build stuff by hand in low qty so it costs a lot more. Honestly, I probably can't make these things cheap enough to sell them. I got tired of people bitching about how much the motor dollies cost so I stopped making them which tells me that I probably shouldn't try making these. I do know someone who is better set up to make stuff like this so I'll pitch the idea over to him.
Re: New product idea? [Re: Bad340fish] #2367132
09/07/17 07:14 PM
09/07/17 07:14 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
For that kind of work I put the tall jack stands under the front K-frame bolts to get full access under the car. Suspension just dangles though so no alignment work or suspension clearance checking that way.
twocents
Re: New product idea? [Re: AndyF] #2367141
09/07/17 07:31 PM
09/07/17 07:31 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
would getting these pre-welding make the pricing or the shipping costs any cheaper?
Re: New product idea? [Re: AndyF] #2367143
09/07/17 07:35 PM
09/07/17 07:35 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Glad I got the last of the Mohicans before they went NS1.
Sometimes the best is worth a little extra.
I posted an AR motor dolly in one of the Fakebook mopar groups, just "hey check this out, what do you use? " and consensus was 1. an old tire or 2. weld up angle iron from an old bed frame 2. Steal a shopping cart and hack it up and you've got the same thing. Well allrighty then, I was definitely not going to debate those viewpoints LOL
After I got a hoist, I promised myself I wouldn't be purchasing anything else designed for working on the floor/ground.
Then I went and did some repairs at a wife's friend's house.
Guess what she gave me: A jack and a pair of jackstands.
Re: New product idea? [Re: ZIPPY] #2367167
09/07/17 09:06 PM
09/07/17 09:06 PM
NJ
cb1289 Offline
cb1289  Offline
NJ
Personally, I would like another one of your motor dollies. As a side note , what risk would you be exposing yourself to if someone injured themselves with these stands on the car. You might be held liable.
62 Dodge Dart Wagon 65 Plymouth Satellite
Page 2 of 3 1 2 3
