Re: Slack in 440 timing chain
[Re: SlickRS23]
#2366648
09/06/17 09:59 PM
09/06/17 09:59 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
That's not terrible. It can be reused. What you really want to check is how much change there is in crank motion, by looking at your timing marks when you bump it end to end against the cam. That will be your valvetrain motion and ignition timing change. 6-8 degrees is about max. Less is always better.
[image][/image]
[Re: SlickRS23]
#2366797
09/07/17 03:30 AM
09/07/17 03:30 AM
Posts: 43,305 Bend,OR USA
Cab_Burge
I shoot for .250 slop each way (in and out from center )maximum on the slack side with everything in place on street motors, if it exceeds that I replace it
