4471829 Bellhousing number.
#2358053
08/22/17 11:57 AM
08/22/17 11:57 AM
Posts: 4,920 Joplin, MO USA
Robbins
Joplin, MO USA
Who's was this trans & bell? I do believe someone here posted this image....I was curious to see if they still have the set up laying around.
My four OD833 transmissions fits all my other three OD style bellhousings and a Lakewood....but none of my OD833 trany's fit this one newer style bell.
Lower Driverside doesn't bolt up
Moparlee
Re: 4471829 Bellhousing number.
[Re: Robbins]
#2358055
08/22/17 12:00 PM
08/22/17 12:00 PM
Robbins
Joplin, MO USA
I'm probably going to have someone weld that hole up and redrill and tap so truly takes all Mopar 833 trans....or did Mopar change how the OD833 bolted up in the end there?
Moparlee
[Re: Robbins]
#2358070
08/22/17 12:32 PM
08/22/17 12:32 PM
Posts: 209 Carlisle, AR.
mdwyer
Carlisle, AR.
That is mine. I still do have it, but is tucked away deep in the shop. Will take a few days to get it back out. It came from a early 90's D100. I was more curious about the hydraulic setup but may not be able to use it in a B/E body car.
mike
1970 Challenger T/A 1970 Roadrunner RM21 Vcode 1971 Gtx 1971 Satellite 1971 Charger 500 GB5 383 A54 car 1972 Satellite 1997 Dodge 1500 hunting rig 2014 Ram 2500 Mega Cab
[Re: Robbins]
#2358074
08/22/17 12:42 PM
08/22/17 12:42 PM
Robbins
Joplin, MO USA
So that OD833 was factory in a 90 or you bolted up to that bellhousing?
Thanks for the feed back.
Moparlee
[Re: scratchnfotraction]
#2361658
08/29/17 12:37 PM
08/29/17 12:37 PM
Robbins
Joplin, MO USA
Thanks scratching.....I'll get the NV4500 bell one of these days and I would like to get a 4500 trans too of course and the N535, also thinking of getting the AX-15 bell and trans set up also.
Moparlee
[Re: mdwyer]
#2361659
08/29/17 12:38 PM
08/29/17 12:38 PM
Robbins
Joplin, MO USA
mike I hope you can shed some light for us....one post he was saying that he took off a 833....so I'm wondering if there is part number change or.....would greatly appreciate the feed back when you get a chance.
Moparlee
[Re: Robbins]
#2361812
08/29/17 05:38 PM
08/29/17 05:38 PM
mdwyer
Carlisle, AR.
we had pulled the assembly (bell housing, transmission, and hyd. clutch setup out of a 1990 D100 with a 318. It appeared that it had never been out. I run a lot of the 833OD in my muscle cars for mileage and hoped this setup would work but it got shoved off to the barn and is buried under a mountain of other parts.
mike
[Re: mdwyer]
#2361814
08/29/17 05:40 PM
08/29/17 05:40 PM
mdwyer
Carlisle, AR.
I have yet to pull the bell housing off the transmission to look for a casting number.
mike
[Re: dogdays]
#2366638
09/06/17 09:39 PM
09/06/17 09:39 PM
Robbins
Joplin, MO USA
Rather than try to weld up a cast iron bellhousing I would find a grade 2 (no marks on the bolt head) bolt and Loctite it in place, then use a transfer punch to put the center of the new hole where it belongs, drill with a drill press, tap and you're there. R. It's a cast aluminum bell, but still......thanks for the feed back.
Moparlee
