4471829 Bellhousing number. #2358053
08/22/17 11:57 AM
08/22/17 11:57 AM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
Who's was this trans & bell? I do believe someone here posted this image....I was curious to see if they still have the set up laying around.
My four OD833 transmissions fits all my other three OD style bellhousings and a Lakewood....but none of my OD833 trany's fit this one newer style bell.
Lower Driverside doesn't bolt up
Moparlee
Re: 4471829 Bellhousing number. [Re: Robbins] #2358055
08/22/17 12:00 PM
08/22/17 12:00 PM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
I'm probably going to have someone weld that hole up and redrill and tap so truly takes all Mopar 833 trans....or did Mopar change how the OD833 bolted up in the end there?
Moparlee
Re: 4471829 Bellhousing number. [Re: Robbins] #2358070
08/22/17 12:32 PM
08/22/17 12:32 PM
Carlisle, AR.
mdwyer Offline
mdwyer  Offline
Carlisle, AR.
That is mine. I still do have it, but is tucked away deep in the shop. Will take a few days to get it back out. It came from a early 90's D100. I was more curious about the hydraulic setup but may not be able to use it in a B/E body car.
mike
1970 Challenger T/A
1970 Roadrunner RM21 Vcode
1971 Gtx
1971 Satellite
1971 Charger 500 GB5 383 A54 car
1972 Satellite
1997 Dodge 1500 hunting rig
2014 Ram 2500 Mega Cab
Re: 4471829 Bellhousing number. [Re: Robbins] #2358074
08/22/17 12:42 PM
08/22/17 12:42 PM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
So that OD833 was factory in a 90 or you bolted up to that bellhousing?
Thanks for the feed back.
Moparlee
Re: 4471829 Bellhousing number. [Re: Robbins] #2358359
08/22/17 11:05 PM
08/22/17 11:05 PM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
I like that this bell is 143 tooth flywheel.
Moparlee
Re: 4471829 Bellhousing number. [Re: Robbins] #2361636
08/29/17 12:03 PM
08/29/17 12:03 PM
scratchnfotraction Offline
that 90 d100 could of had the a535 5 speed behind a v6
I got my duel pattern hydro bell from a 88 d100 v6 a535 5 speed
I do not have a 833/OD833 to fit to it but the 435 4 speed fit and it had the a535 5 speed which replaced the 833/OD833 4 speeds.
the NV4500 5 speed hydro bell is NV4500 specific
although I will have to see if it will fit the 435 4 speed I have now that both are on the shop floor.
Re: 4471829 Bellhousing number. [Re: scratchnfotraction] #2361658
08/29/17 12:37 PM
08/29/17 12:37 PM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
Thanks scratching.....I'll get the NV4500 bell one of these days and I would like to get a 4500 trans too of course and the N535, also thinking of getting the AX-15 bell and trans set up also.
Moparlee
Re: 4471829 Bellhousing number. [Re: mdwyer] #2361659
08/29/17 12:38 PM
08/29/17 12:38 PM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
mike
I hope you can shed some light for us....one post he was saying that he took off a 833....so I'm wondering if there is part number change or.....would greatly appreciate the feed back when you get a chance.
Moparlee
Re: 4471829 Bellhousing number. [Re: Robbins] #2361812
08/29/17 05:38 PM
08/29/17 05:38 PM
Carlisle, AR.
mdwyer Offline
mdwyer  Offline
Carlisle, AR.
we had pulled the assembly (bell housing, transmission, and hyd. clutch setup out of a 1990 D100 with a 318. It appeared that it had never been out. I run a lot of the 833OD in my muscle cars for mileage and hoped this setup would work but it got shoved off to the barn and is buried under a mountain of other parts.
mike
1970 Challenger T/A
1971 Gtx
1971 Satellite
1972 Satellite
Re: 4471829 Bellhousing number. [Re: mdwyer] #2361814
08/29/17 05:40 PM
08/29/17 05:40 PM
Carlisle, AR.
mdwyer Offline
mdwyer  Offline
Carlisle, AR.
I have yet to pull the bell housing off the transmission to look for a casting number.
mike
1970 Challenger T/A
1971 Gtx
1971 Satellite
1972 Satellite
Re: 4471829 Bellhousing number. [Re: mdwyer] #2366627
09/06/17 09:03 PM
09/06/17 09:03 PM
dogdays Offline
dogdays  Offline
Rather than try to weld up a cast iron bellhousing I would find a grade 2 (no marks on the bolt head) bolt and Loctite it in place, then use a transfer punch to put the center of the new hole where it belongs, drill with a drill press, tap and you're there.
R.
Re: 4471829 Bellhousing number. [Re: dogdays] #2366638
09/06/17 09:39 PM
09/06/17 09:39 PM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
R.
It's a cast aluminum bell, but still......thanks for the feed back.
Moparlee
Re: 4471829 Bellhousing number. [Re: Robbins] #2366651
09/06/17 10:04 PM
09/06/17 10:04 PM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
Here is few pictures.
Moparlee
