Re: New product idea?
[Re: RTSE4ME]
#2366780
09/07/17 02:05 AM
09/07/17 02:05 AM
Posts: 31,112 Oregon
AndyF
I would buy a set. You could put them on scales and would make corner balancing easier. Also you remove the tire.wheel variations. Yeah I've seen the circle track guys do that with something similar. They have some fancy hub stands for smaller cars. Here is a link for guys who are into going around corners: https://grassrootsmotorsports.com/forum/...ta/59176/page1/
[Re: B3422W5]
#2366829
09/07/17 08:30 AM
09/07/17 08:30 AM
Posts: 3,696 jersey
Spaceman Spiff
jersey
Cant say as i can see the value. You have to jack the car around to get it to the exact correct height to line up the studs, then you cant do any brake or rear axle work. Easier to just jack the car up and throw stands under it. Thats just me. You jack the car up, install them, then let the jack down. No need to line up. Same way you install a tire.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: Spaceman Spiff]
#2366843
09/07/17 10:19 AM
09/07/17 10:19 AM
Posts: 11,733 Portage,michigan
B3422W5
Portage,michigan
Cant say as i can see the value. You have to jack the car around to get it to the exact correct height to line up the studs, then you cant do any brake or rear axle work. Easier to just jack the car up and throw stands under it. Thats just me. You jack the car up, install them, then let the jack down. No need to line up. Same way you install a tire. Yep... same way you install jackstands. At least with those you can do rearend and brake work. Hey...... is this a nice toy? Sure. But to Mopar guys who whine about the extra cost of a forged crank over a cast crank in a race build.... lol( and thats the truth) i am surprised so many people think this deal being discussed is a must have. To me, i would spend my money elsewhere. Nice toy, but to 99% of us we can live perfectly well without it.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car Best so far, 10.32 1/4 1.41 best 60 foot 6.56 at 104.17
[Re: B3422W5]
#2366852
09/07/17 10:51 AM
09/07/17 10:51 AM
Posts: 81 langley b.c. canada
don miller
langley b.c. canada
Not to hijack Andy's thread but is everybody missing whatelse is in Forest's picture-a way to visualise your instant center etc without doing any math? And Forest what's the story on that Dart?
[Re: AndyF]
#2366900
09/07/17 12:23 PM
09/07/17 12:23 PM
Posts: 8,038 Tulsa OK
Bad340fish
Tulsa OK
I think it is a great idea, nothing I hate more than trying to do something and having a #$%^ jack stand get in the way, for example transmission or header work.
68 Barracuda Formula S 340
[Re: AndyF]
#2366905
09/07/17 12:31 PM
09/07/17 12:31 PM
Posts: 4,213 New York
polyspheric
New York
I like it. I'd be looking at how to make them fit into a standard USPS flat-rate box, or 2 boxes. If you're right over a weight limit, make some big holes, shipping is $$$.
Boffin Emeritus
[Re: humpty]
#2366989
09/07/17 03:09 PM
09/07/17 03:09 PM
Posts: 2,065 MD
RTSE4ME
MD
I'd buy a set. I can also see putting locking casters under them, maybe an add on base so you can move the car around. Love the handles on the blocks of wood too! Casters are a good idea.I would like casters as an option.
[Re: Forest]
#2367045
09/07/17 04:47 PM
09/07/17 04:47 PM
Bad340fish
Tulsa OK
How would bolting them to the rear go with a good posi or spool? Axles would have to be line up exactly the same? Hmm that is a good point, for a spool no problem just make sure you install them the same. I have yet to see a posi good enough that you couldn't muscle them around some and line them up.
[Re: RTSE4ME]
#2367048
09/07/17 04:55 PM
09/07/17 04:55 PM
Posts: 22,806 Bitopia
jcc
Bitopia
I'd buy a set. I can also see putting locking casters under them, maybe an add on base so you can move the car around. Love the handles on the blocks of wood too! Casters are a good idea.I would like casters as an option. No they are not, at least as pictured. Andy said and I agree, if another car say ran into the the car, it could rotate the wheels and allow it to roll off these stands, as nothing(?) is to prevent the wheel hubs from rotating. If you mount casters to the bottom, and do not significantly extend the base ( which the small base being the original benefit to most in the first place?), having a a moving car on casters with all its mass, only needs a caster to stick on something, a crack, a 1/4" nut, cable, etc, and the car could easily roll the wheel hubs and off the stands. Likely, probably not, would some one be under a rolling car, again not likely, but the "stuck" caster should be considered, IMO.
[Re: AndyF]
#2367071
09/07/17 05:34 PM
09/07/17 05:34 PM
Posts: 1,770 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
AndyF: So preferred payment through Paypal, credit card, or money order??? LOL
Absolutely, this is an interesting tool, I think I would like a set in my garage...any pricing ideas, or too early to tell at this poing in time?
[Re: AndyF]
#2367130
09/07/17 07:12 PM
09/07/17 07:12 PM
AndyF
Casters could be mounted on piece of tubing that bolted to the upright. That would be fairly easy to fabricate. I've never done that before but it might be interesting to do. If nothing else it would give me an easy way to push the car that I'm not working on out of the way.
I'm not sure on pricing. I know what people would want to pay for a pair but I'm not Harbor Freight. I build stuff by hand in low qty so it costs a lot more. Honestly, I probably can't make these things cheap enough to sell them. I got tired of people bitching about how much the motor dollies cost so I stopped making them which tells me that I probably shouldn't try making these. I do know someone who is better set up to make stuff like this so I'll pitch the idea over to him.
[Re: AndyF]
#2367143
09/07/17 07:35 PM
09/07/17 07:35 PM
Posts: 17,926 S.E. Michigan
ZIPPY
S.E. Michigan
I got tired of people bitching about how much the motor dollies cost so I stopped making them Glad I got the last of the Mohicans before they went NS1. Sometimes the best is worth a little extra. I posted an AR motor dolly in one of the Fakebook mopar groups, just "hey check this out, what do you use? " and consensus was 1. an old tire or 2. weld up angle iron from an old bed frame 2. Steal a shopping cart and hack it up and you've got the same thing. Well allrighty then, I was definitely not going to debate those viewpoints LOL After I got a hoist, I promised myself I wouldn't be purchasing anything else designed for working on the floor/ground. Then I went and did some repairs at a wife's friend's house. Guess what she gave me: A jack and a pair of jackstands.
[Re: ZIPPY]
#2367167
09/07/17 09:06 PM
09/07/17 09:06 PM
Posts: 145 NJ
cb1289
NJ
Personally, I would like another one of your motor dollies. As a side note , what risk would you be exposing yourself to if someone injured themselves with these stands on the car. You might be held liable.
62 Dodge Dart Wagon
65 Plymouth Satellite
