Need a recommendation for shocks #236641
02/26/09 09:10 AM
02/26/09 09:10 AM
the boonies
aarcuda Offline OP
aarcuda  Offline OP
the boonies
Front shocks right now are some really tight konis (actually made for a 65 gto but they fit). they are really tight and they hold the road great. I really like them for running down the roads.
But as they are really tight, i launch flat and have pretty much no lift in the front. my 60' times suck at 1.83 and i want to improve that.
But its a dual purpose car and I really like those back roads so cornering is still important.
Is there an adjustable shock (thats not to hard to adjust) that i can use on my STOCK bodied sb cuda that I could adjust quickly for the track and then readjust for the rest of my travels?
I need to be a bit quicker.
Re: Need a recommendation for shocks [Re: aarcuda] #236642
02/26/09 09:33 AM
02/26/09 09:33 AM
Vacherie, Louisiana
SuperStocker Offline
super gas
super gas
Vacherie, Louisiana
double-adjustables from Strange
Re: Need a recommendation for shocks [Re: aarcuda] #236643
02/26/09 09:40 AM
02/26/09 09:40 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I will assume that the koni's are a non-adjustable,
what you need is a good adjustable that is re-buildable
so you can change the valving in so you can get the
road and track correct with the turn of the knob.
Problem is, thats hard to do, to get a road race shock
and a drag shock... but take a look at Afco's, Qa1
thats a couple
Re: Need a recommendation for shocks [Re: aarcuda] #236644
02/26/09 12:20 PM
02/26/09 12:20 PM
Orlando Florida
blown572dart Offline
Orlando Florida
Santhuff
Best customer service you find.Call Mike @ MR2.
Re: Need a recommendation for shocks [Re: MR_P_BODY] #236645
02/26/09 12:25 PM
02/26/09 12:25 PM
the boonies
aarcuda Offline OP
aarcuda  Offline OP
the boonies
I just looked at the double adjust QA-1's, the stocker stars or whatever they are called and MAN, those looks like awesome shocks.
EXPENSIVE, but fully adjustable. I talked to the guys at QA-1 motorsports and they convinced me that these are the shocks I need. they are the Brawndo of shocks, it appears.
But man, are they expensive.
So before I break into my piggy bank, whats the word on the street about these?
Are they worth it? do they last? I know they are rebuildable but what do they charge for that? i wouldnt consider them if I had to spend $200 every 2 years to freshen them up OR if they wear out so fast that my preferred setting was always changing to adjust for wear. I'd like to set em at a street setting and a race setting, know what that setting was so I could click click click them back and forth without having to make constant adjustments for wear. (i guess i could ask them but real world experience is better than salesman puffing)
mind you, the car sees 3000 miles a year maybe
oh ya, and i also looked at the Strange double adjustables and they look great too. and a little cheaper. Are these as good or better? it might be a better choice for me. wonder how their customer service is today??
Re: Need a recommendation for shocks [Re: aarcuda] #236646
02/26/09 12:45 PM
02/26/09 12:45 PM
I put the single adj stockers on my car wish I put the double adj. QA1 makes nice stuff.
Mike
Re: Need a recommendation for shocks #236647
02/26/09 01:27 PM
02/26/09 01:27 PM
the boonies
aarcuda Offline OP
aarcuda  Offline OP
the boonies
wow, found the the double adj strange shocks at a place called autofabracecars for $224 a piece. thats cheaper than the $249.95 everyone else is selling them for.
btw, just to report, I had a very nice and informative discussion about the shocks with one of the tech guys at Strange just now. VERY good customer service report.
Re: Need a recommendation for shocks [Re: aarcuda] #236648
02/26/09 06:26 PM
02/26/09 06:26 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Calvert ft. shocks.......Best shocks I`ve run for the price at a bit over $100.00.
Re: Need a recommendation for shocks [Re: Thumperdart] #236649
02/26/09 06:37 PM
02/26/09 06:37 PM
100% with Dom! For the money,the Calvert's are UNBEATABLE. Best front shocks I've ever used on a dual-purpose car. Work GREAT!
Re: Need a recommendation for shocks #236650
02/26/09 10:58 PM
02/26/09 10:58 PM
the boonies
aarcuda Offline OP
aarcuda  Offline OP
the boonies
i'll check them out. thanks for the suggestion
