Hi
I have run into a bit of a problem while mocking up my new 512 stroker engine.
I have a set of Crane 1.6 roller rockers to use on a set of Stealth heads,(good things) however the pushrod clearance is WAY off, like more than can be ground safely.
This is only on the inlet side, where there is already a pushrod relief machined into the head.
Stock pressed steel rockers fitted up look fine, with the pushrod pretty much central.
The length of the stock rocker ( rod tip to valve c/line) is more than the ratio roller (something wrong there?)
I cant use stock rockers cos of the rather large mechanical cam.
DO I just need different length rockers?
Anyone else found this issue?
(The Crane rockers sitting on stock heads look just fine pushrod clearance wise...)
Nick
