Re: Timing Recurve
[Re: jeebis44]
#2365670
09/05/17 10:31 AM
09/05/17 10:31 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
If you can find a copy this is the ticket
The Doctor's Step By Step Guide to Optimizing Your Ignition
I have a copy here and it' pretty useful for what you want.
Re: Timing Recurve
[Re: jeebis44]
#2365743
09/05/17 12:52 PM
09/05/17 12:52 PM
RapidRobert
set the initial with the "vac gauge method". If the starter kicks back when hot, reduce the initial amt (1) deg & retry OR keep it where it is at & wire in a momentary NC contact switch & push it then start cranking then release it while you are cranking. Purchase the FBO $22 plate & select the slots to get 31 total (initial+slots). toss the heavy spring with the elongated loop on one end & sub in a mr gasket 925B or transdapt #4450 or a MP light spring in its place for a baseline start. dial in the springs then dial in the can.
Re: Timing Recurve
[Re: jeebis44]
#2365978
09/05/17 07:44 PM
09/05/17 07:44 PM
RapidRobert
OK Vac Gauge method is simply dialing in the initial to make max vac. hot idling in neutral correct? in gear (auto) with ebrake on (which is what the eng will see/be at stoplight to stoplight) or neutral for a stick, keep advancing the timing till you reach max vacuum (all the while constantly reducing the idle speed back to its lowest normal speed that it will function at), then turn the dist housing back the other way till the VACUUM drops exactly (1) in hg & readjust the idle speed if needed & at that point your INITIAL amount is set/correct. & you want the dist springs to start advancing no less that 1-200 RPM above your idle speed, so if you idle at 800 you want the springs to start advancing at ~1000. higher is OK (but hurts performance/economy/runs hotter) but not less than 1000.
