Hood hinge 69 A body #2365325
09/04/17 06:03 PM
09/04/17 06:03 PM
Elizabethtown, KY
6T9Hemi Offline OP
6T9Hemi  Offline OP
Elizabethtown, KY
How do you get the hood hinge off a 69 A body?
1969 340 4 Speed Swinger R4,
black vinyl, white butt stripe, 3:91
Re: Hood hinge 69 A body [Re: 6T9Hemi] #2365329
09/04/17 06:16 PM
09/04/17 06:16 PM
Eastern,NC
68GTS383 Offline
68GTS383  Offline
Eastern,NC
You will have to pull the Fender to have access to the clips that hold it on
Re: Hood hinge 69 A body [Re: 6T9Hemi] #2365334
09/04/17 06:32 PM
09/04/17 06:32 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
pull, really really hard grin
there are clips on the pivot pin and spring end under the fender top then it pretty much falls right off.
accessable if you take the splash shield out but much easier with the fender off.
Re: Hood hinge 69 A body [Re: nomore65BelvJim] #2365343
09/04/17 06:56 PM
09/04/17 06:56 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I took one off a car in the wrecking yard that was missing the door, but the fender was still on. Slow going, but I got it off.
Installation with no straight on access to drive the retainers back on might be rather difficult. Might be able to use a socket and some wood as a prybar to leverage them in place.
RestoRick sells the correct diameter retainer push clips.
Re: Hood hinge 69 A body [Re: Neil] #2365459
09/04/17 10:03 PM
09/04/17 10:03 PM
Middletown , Ohio
DonnieLawson Offline
Middletown , Ohio
here's whats under that fender
Re: Hood hinge 69 A body [Re: 6T9Hemi] #2365607
09/05/17 02:09 AM
09/05/17 02:09 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
I tried the hardware store push clips. They were not nearly strong enough. Popped them off the first time I tried to close the hood. Spend the money for good clips.
Re: Hood hinge 69 A body [Re: Jim_Lusk] #2365710
09/05/17 11:44 AM
09/05/17 11:44 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Read on the for a bodies only forum about using a collar shaft on those in addition to the clips. If the hinges get stiff they can start to walk off the pins.
Re: Hood hinge 69 A body [Re: DonnieLawson] #2366215
09/06/17 02:26 AM
09/06/17 02:26 AM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Mine doesn't look nearly that good shock
Re: Hood hinge 69 A body [Re: Jim_Lusk] #2366276
09/06/17 10:12 AM
09/06/17 10:12 AM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
In a pinch I tried fuel line size hose clamps - the good ones, not offshore junk. Been on there for years.
