727 expert help needed
#2365071
09/04/17 11:41 AM
09/04/17 11:41 AM
Posts: 6,435 Abilene, Texas
fastmark
Abilene, Texas
I have an 84 model 727 from a one ton with a 360. It is the short tail shaft. Is that a lock up model or not? I need to put something together for a 340 a body combo and he wants a 727. I have plenty of early BB cores to rob internals and a tail shaft. Also. How do you ID a lock up besides the numbers on the case?
Re: 727 expert help needed
[Re: fastmark]
#2365073
09/04/17 11:50 AM
09/04/17 11:50 AM
RapidRobert
I think the LU has a machined smooth tip on the end of the input shaft as opposed to it being splined all the way out to the end.
[Re: fastmark]
#2365177
09/04/17 02:02 PM
09/04/17 02:02 PM
RapidRobert
it would. if there is another electrical plugin terminal there other than the across the board 3 pin reverse lights/NSS ground plug in terminal that they all have then yes it is a LU.
[Re: RapidRobert]
#2365179
09/04/17 02:10 PM
09/04/17 02:10 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
it would. if there is another electrical plugin terminal there other than the across the board 3 pin reverse lights/NSS ground plug in terminal that they all have then yes it is a LU. Plenty of lockup 727 that do NOT have the electric unlock provision. Pull the pan and see if the lock up plumbing in there or run the part number, only guaranteed way to tell. Picture one Lock up plumbing (NOTE, NO ELECTRONICS) Picture two - no extra connector, note input shaft
[Re: dynamite]
#2366521
09/06/17 06:03 PM
09/06/17 06:03 PM
Posts: 26,000 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The 84 converter will not have a drain plug if it is a lock up as the verter from a non lock up will.. The converter drain plug disappeared on January 10, 1977 and was never used again....lockup or not.
[Re: fastmark]
#2367133
09/07/17 07:15 PM
09/07/17 07:15 PM
John_Kunkel
Rio Linda, CA
That won't help. It's still hooked up the the motor.
