Transmission Dipstick 727
#2364192
09/02/17 06:57 PM
09/02/17 06:57 PM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
What brand are you guys using ??
I was in a pinch ( need to get the car running ),,,and picked up a locking dipstick at the local speed shop... brand is ALLSTAR ??
No luck,,,fit is terrible,,,does not line up at all with the bellhousing OMG.....whoever welded the mounting tab on this stick needs some new glasses.....
I usually use CRT,,,but needed something in a hurry,,,
What other brands do you guys like ??
Will call John @ CRT after the holiday's,,,arrrgghhhh
Re: Transmission Dipstick 727
[Re: 69CHARGERMD]
#2364197
09/02/17 07:03 PM
09/02/17 07:03 PM
Posts: 25,801 Rio Linda, CA
John_Kunkel
Rio Linda, CA
fit is terrible,,,does not line up at all with the bellhousing OMG.....whoever welded the mounting tab on this stick needs some new glasses..... BB and SB mounting tabs are different...are you sure the tube is for your block?
[Re: 69CHARGERMD]
#2364204
09/02/17 07:25 PM
09/02/17 07:25 PM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
The BB part number is : 69121
If that's what you have and it doesn't fit right..... Perhaps it's a SB part that's packaged wrong.
[Re: 69CHARGERMD]
#2364321
09/03/17 12:19 AM
09/03/17 12:19 AM
Posts: 1,099 Massillon, Ohio
cudatom
Massillon, Ohio
I've used both the Lokar and one from Mancini. Like the mancini one best. Sat a little higher and was able to get it out w/o burning my knuckles.
Ok
[Re: 69CHARGERMD]
#2364345
09/03/17 12:52 AM
09/03/17 12:52 AM
Posts: 1,074 Manitoba Canada
67autocross
Manitoba Canada
I just tried a TCI locking dipstick....fit perfectly.
A new iron curtain drawn across the 49th parallel
[Re: 69CHARGERMD]
#2364641
09/03/17 03:28 PM
09/03/17 03:28 PM
69CHARGERMD
KENTUCKY
Thanks everyone,,,, I have used CRT ( Cope ) before on the race car,,,no issues,,, Will give John a call on Tuesday,,,, I found a "stock" one to use for now,,,,but not crazy about the fit at the trans,,,has a small rubber "O" ring,,,hopefully no leaks,,,,
[Re: 69CHARGERMD]
#2365689
09/05/17 11:05 AM
09/05/17 11:05 AM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
Lokar flexible braided steel trans dipstick here.
