Re: Max Wedge EZ or TF 270 ? [Re: Brewzer67] #2363887
09/02/17 02:37 AM
09/02/17 02:37 AM
Sydney,Australia
tex013 Online content
tex013  Online Content
Sydney,Australia
Originally Posted By Brewzer67
If it's any help I am running the 270's and had them ported by Larry Smith at flow2tech. They flowed 278@.700 on his bench and 284 on my local builders bench. The same bench flowed my 240's at a smidge under trick flows rated flow (330@.700 I think it was).
I can't speak to how well they perform yet as I am still dialing in the tune and haven't had them to the track yet. I can attest to the quality of the manufacturing though. And I can also say that the quality of customer service from trick flow is head and shoulders above what you will ever get from Indy. They were cool enough to swap out my 240's for the 270's 6 months after I had purchased the 240's and didn't even charge me a restocking fee despite the fact I had purchased them through a different distributor. Pretty solid customer service if you ask me.
Am i reading this right ? 278@.700 on the 270 . Less than TF240. Or wrong number ?
At least no need for offset rockers with the TF270
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Max Wedge EZ or TF 270 ? [Re: Tom Fox] #2363901
09/02/17 03:48 AM
09/02/17 03:48 AM
do you want the customer to hate you because the motor you put together doesn't run good, including back firing through the carbs. killing the motor due to reversion in the intake to head transition work
Do NOT do that tsk
Unless you buy one of the A&A 440 motor look alike cross ram intakes for the stock 440 headed motors twocents scope
Re: Max Wedge EZ or TF 270 ? [Re: Tom Fox] #2364027
09/02/17 01:26 PM
09/02/17 01:26 PM
AndyF Offline
AndyF  Offline
Originally Posted By Tom Fox
well can a source stealth head be opened up to work with a max intake ?
This question tells me that you don't have much experience with these parts. If that is the case then you either need to find someone you trust to help you out or just start by trying to bolt some things together so you can figure out how they go together.
You're questions are all over the map which is why you are getting replies that are all over the map. The answers you get on Moparts will be very confusing for someone who doesn't already have a really good understanding of how the engines go together.
For example, the EZ head and the TF 270 head use extended intake ports. The other heads you are asking about such as Stealth heads do not have extended intake ports. So you are not comparing apples to apples.
Re: Max Wedge EZ or TF 270 ? [Re: Tom Fox] #2364032
09/02/17 01:34 PM
09/02/17 01:34 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
One of best of the "down and dirty" ways for a budget friendly mw x-ram install is to use the stealth heads opened to mw size.
Re: Max Wedge EZ or TF 270 ? [Re: fast68plymouth] #2364130
09/02/17 04:18 PM
09/02/17 04:18 PM
florida/ Georgia
Tom Fox Offline OP
Tom Fox  Offline OP
florida/ Georgia
Thanks fast68, that's what I needed to see, & will do.and yes I have never been around a Max Wedge Engine before to know the exact head requirements.Tom
Re: Max Wedge EZ or TF 270 ? [Re: fast68plymouth] #2364173
09/02/17 06:23 PM
09/02/17 06:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
FAST... I have a question for ya...why take so
much off the bottom of the port... on my SB
stuff I tend to move the port up and it flows
very well
wave
Re: Max Wedge EZ or TF 270 ? [Re: Tom Fox] #2364180
09/02/17 06:40 PM
09/02/17 06:40 PM
So. Burlington, Vt.
So. Burlington, Vt.
That's where the ports are oriented on a stock mw head......... To make it so the stock manifold lines up with the head..... I just match it to stock.
If you overlay the mw gasket on top of the std gasket and line up the bolt holes you'll see that the mw port opening extends above and below the std port opening.
Same gasket on a factory mw head:
Re: Max Wedge EZ or TF 270 ? [Re: Tom Fox] #2364227
09/02/17 09:11 PM
09/02/17 09:11 PM
So. Burlington, Vt.
So. Burlington, Vt.
The Stealth head pictured above, after also being treated to a more flow friendly valve job, back cut valves, and the bowls blended........ Flowed 288@.550 lift, which is way more than an unmodified OE mw head.
Re: Max Wedge EZ or TF 270 ? [Re: Cab_Burge] #2364294
09/02/17 11:24 PM
09/02/17 11:24 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
Chrysler sold lots of 318ci engines with 360 4-bbl intake manifolds that didn't match. They seemed to run well.
Re: Max Wedge EZ or TF 270 ? [Re: @#$%&*!] #2364331
09/03/17 12:33 AM
09/03/17 12:33 AM
Some of the late 1970s up to the late 1980 Hi Po 318(if you can call them that) had the 360 heads, intakes and carbs. shruggy
Why Ma Mopar did that along with selling the Hi Po 360 at the same time is anybody guess confused work
Re: Max Wedge EZ or TF 270 ? [Re: tex013] #2364878
09/03/17 11:07 PM
09/03/17 11:07 PM
WI
Brewzer67 Offline
Brewzer67  Offline
WI
Sorry, that's a typo. It should be 378 and 384. That would suck if I paid for all that porting only to have less flow!
Re: Max Wedge EZ or TF 270 ? [Re: Brewzer67] #2364958
09/04/17 01:22 AM
09/04/17 01:22 AM
Sydney,Australia
Sydney,Australia
Tex
New best MPH 130.32
Re: Max Wedge EZ or TF 270 ? [Re: Tom Fox] #2365950
09/05/17 06:50 PM
09/05/17 06:50 PM
St Louis, MO, USA
srunge55 Offline
srunge55  Offline
St Louis, MO, USA
I'm pretty confused about the TF 270 heads on a low deck. After reading Andy's article my understanding is the 270's made about 700 HP with the stock Indy Low Deck intake (400-3) and more power with a ported standard port intake (750 HP). This is a small difference over the TF 240s. I'm now questioning my plans to use the 270 heads and anxiously waiting for Andy to test the ported 400-3 intake (per the article). Andy are you still planning to retest the 400-3 after Wilson ports it?
Thanks,
Steve
Re: Max Wedge EZ or TF 270 ? [Re: Tom Fox] #2365956
09/05/17 06:59 PM
09/05/17 06:59 PM
AndyF Offline
AndyF  Offline
Yes, I'll re-run the 470 engine with the TF 270 heads once I get a new oil pump. I've been waiting a couple of months for a new pump. I have the intake back from Wilson and it looks great. I think the 270 heads will be worth about 50 hp on my engine over the 240 heads. The trick is that you need a really good intake manifold to get the heads to work.
Re: Max Wedge EZ or TF 270 ? [Re: fast68plymouth] #2365971
09/05/17 07:34 PM
09/05/17 07:34 PM
Sydney,Australia
Sydney,Australia
Dwayne ,
in seeing this would it be practical to use a max wedge gasket on the source cnc heads . I use Felpro 1216 gasket and have to open them up to suit , I even had to open the pan up . I know height will be off . Or have you used Indy gasket 400- G1-210 from Hughes ?
I cut to at least 2.35 x 1.25 and may need a little more .
Sorry for the highjack .
Tex
New best MPH 130.32
Re: Max Wedge EZ or TF 270 ? [Re: Tom Fox] #2366100
09/05/17 10:55 PM
09/05/17 10:55 PM
So. Burlington, Vt.
So. Burlington, Vt.
Tex, the "if it were me" answer is, I would open up a valley pan gasket to the size I needed, and I'd reuse it as many times as I could.
I would just keep replacing the paper gaskets after manifold R&R.
Andy's bat wing system might be easier to rework for your application.
Hughes has their own gaskets that are made to be opened up to facilitate ports in between std and mw size.
Re: Max Wedge EZ or TF 270 ? [Re: fast68plymouth] #2366161
09/06/17 12:22 AM
09/06/17 12:22 AM
Sydney,Australia
Sydney,Australia
thanks Dwayne
Tex
New best MPH 130.32
Re: Max Wedge EZ or TF 270 ? [Re: Tom Fox] #2366367
09/06/17 01:15 PM
09/06/17 01:15 PM
So. Burlington, Vt.
So. Burlington, Vt.
The issue you're having is why I like to leave std port openings actually "std" size on heads without raised runners(heads that will use the valley pan gasket).
It's also another reason I prefer to use raised runner heads if possible....... Just to get away from the valley pan gasket!!
Re: Max Wedge EZ or TF 270 ? [Re: Tom Fox] #2366576
09/06/17 07:31 PM
09/06/17 07:31 PM
AndyF Offline
AndyF  Offline
Batwings to the rescue! That is the whole reason I developed the batwing concept. It allows you to fiddle around with the side gaskets but still have a nice solid area to seal to the valley plate. But it is a lot more expensive and it adds some hassle factor to the engine build.
Re: Max Wedge EZ or TF 270 ? [Re: AndyF] #2366578
09/06/17 07:36 PM
09/06/17 07:36 PM
Sydney,Australia
Sydney,Australia
Thanks Andy , have looked at them and feel that will be where I go later this year . Try the expense from down here , exchange and freight .
But I think may be best solution . I had a homemade plate but it did start to weep at head face .
Or fit that modman up eek
Tex
New best MPH 130.32
