filters #2361718
08/29/17 02:09 PM
08/29/17 02:09 PM
Spring Valley ,Ca.
moparsquid Offline OP
Spring Valley ,Ca.
hello, im running a cross ram set up with two small air filters but they seem to be chocking the performance of the motor they are the typical auto parts store brand 3x6 paper element is there a better choice like K&N thanks
Re: filters [Re: moparsquid] #2361749
08/29/17 02:40 PM
08/29/17 02:40 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Not a fan of K&N. Do some research and you will see that K&N lets too much dirt through. Their performance claims are in absolutely perfect conditions. In the real world you're lucky to see 2 to 3 hp gains. Not worth the minuscule gain of hp. I say if there is any restriction in air intake, it is the size of the filter, not the filter itself.
Facts are stubborn things.
Re: filters [Re: moparsquid] #2361811
08/29/17 05:34 PM
08/29/17 05:34 PM
dogdays Offline
dogdays  Offline
Do some back-to-back runs with filters and without. Have a friend time you, because the extra intake roar without filters will fool the butt dyno.
R.
Re: filters [Re: dogdays] #2361874
08/29/17 07:19 PM
08/29/17 07:19 PM
Spring Valley ,Ca.
Spring Valley ,Ca.
thanks and I totally agree
Re: filters [Re: moparsquid] #2361907
08/29/17 08:14 PM
08/29/17 08:14 PM
My I ask what is makeing you think the filters are restricting performance? One (at least) of the filter companies has a formula for the amt of filtering square inches of filter area you need for a given displacement (& RPM iirc) (It'd be a ballpark # I would assume) I looked for it but could not find the name. Yes avoid K&N. A good paper wix is fine.
Re: filters [Re: RapidRobert] #2362275
08/30/17 12:33 PM
08/30/17 12:33 PM
Spring Valley ,Ca.
Spring Valley ,Ca.
the small round ones im using seemed to have a bit more response when removed it may also have been a sound thing and assumed a drop in performance was noted as previously stated thanks but id like a better one all the same
Re: filters [Re: moparsquid] #2362509
08/30/17 08:40 PM
08/30/17 08:40 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Depends what you are aiming to do, but basically your gut analysis is correct; small air filters become restrictions.
How big is needed depends on a few things:
1. Volumetric Flow That is the volume of air the engine wants to consume over time. Any screen is a restriction and the higher the velocity of the air, a higher percentage gets blocked.
2. Mass Flow If there is a pressure drop across the air cleaner, then the air will be less dense. When the mass flow of air is changed, the fuel needs will change.
3. Pressure in the Fuel Bowls Yea. Really. The air needs to be directed so it goes past the bowl vents without creating extra pressure or suction. Well, some carbs take advantage of that on purpose - usually above the venturi, but that's getting off track.
Summary. Use a filter with enough area to provide enough flow for your engine.
Use a base and lid so the airflow is not disturbing the bowl vents. If using some sort of ram-air (scoop) or the hood clearance is an issue, then make up something like shown in this bowl vent discussion.
Air flow requirement = (CID/2)x (rpm/1728) x VE
from Urich & Fisher Holley Carburetors and Manifolds
Take the air flow required in cubic feet per minute (CFM) and then calculate how big your filter area needs to be.
Figure a clean paper element will flow 4 to 5 cfm per square inch (at 1.5" of H2O, which is a very small pressure drop)
from Vizard Performance with Economy p.24
Oiled cotton gauze filter may protect less from very fine stuff but is good for the last drop of efficiency in a racing motor. It's also better if the element is in situations where it will get wet, muddy or the like. Vizard's test only showed it to be slightly more more flow per inch than the best paper element he tested when both were new.
Maybe some ballpark examples would help.
A 400 cid engine with 100% VE will flow around 700 cfm at 6000 rpm.
Lets take the best paper element and figure it flows 5 cfm/sq inch at 1.5 "H20.
700 cfm divided by 5 cfm/sq in = 140 square inches.
Lets assume theres room for a 3" tall air cleaner.
140 sq inches divided by 3 inches = 46.7 inches
If the engine is getting a single round air cleaner, then the diameter will equal the circumfrance divided by PI.
46.7 inches divided by 3.14 = 14.8" diameter
In reality a 14" diameter cleaner is going to work well. Even a little smaller (like 12") is not going to be noticed unless racing. Obviously a higher rpm or more efficient engine will want more at its Hp peak.
Using same example but 2 round air cleaners.
46.7 " / 2 = 23.4"
23.4 / PI = 7.5" diameter
Finally, lets use the same example but there's only room for 2.5" tall air cleaners.
140 sq in / 2.5 in = 56 inches
56 /2 air cleaners = 28"
28 in / PI = 8.9"
Re: filters [Re: Mattax] #2362938
08/31/17 04:56 PM
08/31/17 04:56 PM
Lakeland FL
floridian Offline
floridian  Offline
Lakeland FL
46.7 " / 2 = 23.4"
28 in / PI = 8.9"
Think I will have a beer after this... My head hurts and my eyes are blurry.... LOL
Re: filters [Re: moparsquid] #2363042
08/31/17 08:29 PM
08/31/17 08:29 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i give, why are K&N on the bad list?
as a runner with a six pack my only other option is to pay through the nose for a repro or worse yet, a NOS.
Re: filters [Re: moparsquid] #2363047
08/31/17 08:52 PM
08/31/17 08:52 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
there is only one way to increase flow thru a given area, less restriction, which means less fine particulate filtration.
http://www.nicoclub.com/archives/kn-vs-oem-filter.html
http://www.bobistheoilguy.com/airfilter/airtest3.htm
More of it out there. If you look at the K&N site for info they are very careful how they present their test data.
Don't be the exception.
Re: filters [Re: moparsquid] #2363134
08/31/17 11:14 PM
08/31/17 11:14 PM
Missouri
Big_E Offline
Big_E  Offline
Missouri
Re: filters [Re: moparsquid] #2363321
09/01/17 10:27 AM
09/01/17 10:27 AM
Port Huron, Michigan
MI_Custumz Offline
MI_Custumz  Offline
Has anyone contacted Wix to see if they would make a filter? Doesn't have to be exact looking, just fit since it's either an expensive repop, OEM, or K&N.
Re: filters [Re: Big_E] #2363330
09/01/17 10:42 AM
09/01/17 10:42 AM
jersey
Spaceman Spiff Offline
jersey
Originally Posted By Big_E
That article is for stock type vehicles.
What about those of us with High HP engines that need a lot of airflow?
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: filters [Re: moparsquid] #2363375
09/01/17 11:41 AM
09/01/17 11:41 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
If you have a hood scoop, you could stack two filters if space allows,
Permatex the two together for easier handling.
What we do...Joe
Re: filters [Re: Spaceman Spiff] #2363914
09/02/17 05:41 AM
09/02/17 05:41 AM
Missouri
Big_E Offline
Big_E  Offline
Missouri
Still holds true. Filtration or HP. What do the big boys use? I've seen no filters on the strip to stock looking and K&N style on the high banks.
