leaking valve covers
#2363159
09/01/17 12:00 AM
09/01/17 12:00 AM
Posts: 49 mn.
taxidermy man
mn.
Ok, so I have a RB 440 that has been rebuilt using stock heads,cannot get the covers to seal,at first I had some Indy cast aluminum covers I got at a swap meet with Moroso blue rubber gaskets, oil basically ran out of the lower rear corners,I thought that maybe these covers weren't compatible with stock cast iron heads, then I put some old Direct connection alum. covers on with cork gaskets...no difference. When I took these covers off I laid a straight edge on the valve cover rails of the heads, they are not flat front to back at all,if you lay the straight edge flat on one end, it is up a big 3/8" on the other, both heads are like this, is this normal? Just put stock stamped steel covers on with new Felpro gaskets and took it for a drive, oil is literally pouring out of the lower edge of both covers creating quite a smoke show with the headers. Sorry for the long winded post, any thoughts? Thanks. Mark
Re: leaking valve covers
[Re: taxidermy man]
#2363182
09/01/17 12:43 AM
09/01/17 12:43 AM
RapidRobert
Mark that ain't long winded at all! confirm that the VC bolts you are using ain't bottoming out. What sealant are you using?
[Re: taxidermy man]
#2363199
09/01/17 01:16 AM
09/01/17 01:16 AM
Posts: 3,076 Michigan
A727Tflite
Bolts in your case won't make a difference if the head is not cast flat. I have a set of maxwedge heads on my engine in the same situation. I took two sets of brand new Fel Pro cork gaskets and RTV'd them together then laid a heavy flat weight on them over night. Installed them (two gaskets per side) and that fixed me right up. I don't use sealant between the gasket and head or gasket and cover.
[Re: taxidermy man]
#2363205
09/01/17 01:22 AM
09/01/17 01:22 AM
A727Tflite
I also let the assembly set over night and cinched the bolts a few times before lighting engine. Then again after a couple warmup's and cool downs. And that was on the 4 bolt maxwedge heads. 6 bolt should seal better. Good luck. Hope you get it sealed up.
[Re: taxidermy man]
#2363225
09/01/17 02:06 AM
09/01/17 02:06 AM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
I don't care what gasket you use how do you compensate for 3/8" ?
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: taxidermy man]
#2363397
09/01/17 12:16 PM
09/01/17 12:16 PM
Posts: 1,317 Ohio
jlatessa
Ohio
I go against the usual method of sealing the gasket to the cover. With stock Iron heads, the oil doesn't have an efficient way to drain like aftermarket Al. heads, allowing oil to pool against the gasketing area, promoting leaks.
I like sealing the gasket to the head using Permatex no.2, I coat the gasket and the head mating surfaces, the attach the cover overnight with enough pressure to ensure a good seal but avoid cover deformation.
The next day, I smear the No. 2 along the inside edge of the gasket, at the bottom, effectively making a higher "wall" along offending area.
When everything is dry I then attach the covers dry, this works well for me as when the gasket was attached to the cover, I usually seemed to catch the gasket on rockers etc. and ruin the seal.
My 2 cents...Joe
P.S. Studs are a plus
[Re: taxidermy man]
#2363660
09/01/17 06:34 PM
09/01/17 06:34 PM
Posts: 16,146 Mesa, Arizona
dart4forte
Mesa, Arizona
Valve cover mating surface may be warped. Had the same problem with a new set of MP covers. Take them to a machine shop to check if they are tru.
Abe Lincoln
[Re: dart4forte]
#2363706
09/01/17 08:17 PM
09/01/17 08:17 PM
Posts: 49 mn.
taxidermy man
mn.
Valve cover mating surface may be warped. Had the same problem with a new set of MP covers. Take them to a machine shop to check if they are tru. Covers are flat, heads are far from it.
[Re: taxidermy man]
#2364002
09/02/17 12:21 PM
09/02/17 12:21 PM
dart4forte
Mesa, Arizona
Had that problem too. Had the mating surface of the head tru'd as well
Abe Lincoln
