Floor jack pads
#2362649
08/31/17 12:35 AM
08/31/17 12:35 AM
Posts: 1,487 STL
cdstl
STL
I'm looking for some rubber pads that can go on my floor jack lift pad. They are round and have slots in them to straddle the pinch weld while jacking. I cut some dadoes into some 2x6 blocks, and they work, but the blocks split.
Plenty of examples on the internet. What do you guys use?
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Floor jack pads
[Re: Sxrxrnr]
#2362718
08/31/17 07:26 AM
08/31/17 07:26 AM
Posts: 1,487 STL
cdstl
STL
Lookin' at these I guess. Need the slit in them to clear the pinch weld. Jack pads
Re: Floor jack pads
[Re: Dr Dave]
#2363033
08/31/17 08:00 PM
08/31/17 08:00 PM
Posts: 2,592 None
71rm23
None
Why not get some rubber stall mat, cut and glue as needed to your preferred shape? The mat comes in many different thickness Went to Home Depot/Lowes and got something similar. They have rubber matting that I used and put on the pad surface and worked for my use and was around $8 for the padding
Re: Floor jack pads
[Re: cdstl]
#2363114
08/31/17 10:54 PM
08/31/17 10:54 PM
Posts: 1,487 STL
cdstl
STL
These are what I was looking for and bought this morning. You can see in the pictures why I was asking about a pad that would go over the pinch weld. But thanks for the suggestions. Slotted floor jack pads
Re: Floor jack pads
[Re: cdstl]
#2363286
09/01/17 07:41 AM
09/01/17 07:41 AM
Posts: 1,272 Northern Calyfornua
Sxrxrnr
Northern Calyfornua
Lookin' at these I guess. Need the slit in them to clear the pinch weld. Jack pads Sorry, shouda told you to page down the page on the Amazon URL for the slotted version
Re: Floor jack pads
[Re: Challenger 1]
#2363382
09/01/17 11:52 AM
09/01/17 11:52 AM
Posts: 15,551 Norwich CT USA
moparts
Norwich CT USA
Why are lifting the car there? It is the worst place to lift a car. It is not a ridged nascar chassis. Because on a new Challenger there is no way to get a jack under anything else. I use ramps for an oil change, but when I need to pull a tire the jack point on the rocker is the only way
Tom ,
2011 Ram 3500 C&C Diesel 2009 Challenger R/T 1971 Challenger Conv. 511/4 speed 1970 Challenger R/T 503/727
Re: Floor jack pads
[Re: moparts]
#2363488
09/01/17 02:18 PM
09/01/17 02:18 PM
Challenger 1
Cincinnati, Ohio
Why are lifting the car there? It is the worst place to lift a car. It is not a ridged nascar chassis. Because on a new Challenger there is no way to get a jack under anything else. I use ramps for an oil change, but when I need to pull a tire the jack point on the rocker is the only way Oh OK I thought we were working on a old car. Yup I had to run our 300 on at least a 2x6 under one tire to get a floor jack under the front. Have never owned or worked on new challenger.
