Page 2 of 3 1 2 3
Re: Lower contol arm bushings [Re: 11secaarcuda] #2362136
08/30/17 02:29 AM
08/30/17 02:29 AM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
So,..if tightened while on the lift, that would make it easier to do wheelies on a race car then.?!
Re: Lower contol arm bushings [Re: cudaman1969] #2362287
08/30/17 01:00 PM
08/30/17 01:00 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
No, it will just rip the rubber loose when you let it down on the ground. Or, are you joking?
Re: Lower contol arm bushings [Re: 71birdJ68] #2362295
08/30/17 01:18 PM
08/30/17 01:18 PM
fredericksburg,va
fredericksburg,va
Just joking, but, if you tighten the nut at rest, what heppens when you raise the car on a lift? Does it "rip" the rubber then. Sounds like bs to me. Haeven help if the wheel falls in a hole or the front end bottoms out ( like in normal use) your rubbers rip.
Re: Lower contol arm bushings [Re: cudaman1969] #2362309
08/30/17 01:37 PM
08/30/17 01:37 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Then it only goes half travel, but if tightened on the lift, it will go more than full travel when moving in it arc.
Re: Lower contol arm bushings [Re: 71birdJ68] #2362311
08/30/17 01:40 PM
08/30/17 01:40 PM
fredericksburg,va
fredericksburg,va
Wouldn't any travel twist that rubber?
Re: Lower contol arm bushings [Re: cudaman1969] #2362358
08/30/17 03:15 PM
08/30/17 03:15 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Twisting is normal, that is the design, but when you exceed the twist limit it rips it loose from the metal it is anchored to.
Re: Lower contol arm bushings [Re: cudaman1969] #2362360
08/30/17 03:23 PM
08/30/17 03:23 PM
dogdays Offline
dogdays  Offline
I can't believe you are arguing about this. When nut is tightened at ride height, when fully compressed or fully ewxtended, the bushing is twisted halfway. The designers made the bushing for this use.
When you tighten the nuts with wheels dangling, when at level the busthing is already at its limit in one direction. Then when the wheel is pushed farther up, the bushing is past its workable range.
Also, it doesn't just rip or twist out immediately, it takes some time and number of cycles. But the service life of a rubber bushing misinstalled in this fashion will be compromised severely, like total failure in 1/10 the normal life.
Several years ago I got a ride in an A-body that had all poly bushings installed. It felt sharp. steering turn-in was immediate. I asked the owner his opinion of the bushings and he said he loved them for the reason I'd just noted, but in his opinion they transmitted more shock to lower ball joints, which caused the ball joints to wear more quickly.
Back in the day, a trick to stiffen factory rubber bushings was to drive small nails into the rubber. I remember this in a car magazine around 1975.
R.
Re: Lower contol arm bushings [Re: 11secaarcuda] #2362463
08/30/17 06:37 PM
08/30/17 06:37 PM
fredericksburg,va
fredericksburg,va
Do you think that rubber bushing is glued-adhered to that steel pin?
Re: Lower contol arm bushings [Re: 11secaarcuda] #2362468
08/30/17 06:52 PM
08/30/17 06:52 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
What steel pin?
It's adhered to the inner sleeve, which is bolted to the pivot pin.
Don't be the exception.
Re: Lower contol arm bushings [Re: cudaman1969] #2362472
08/30/17 06:59 PM
08/30/17 06:59 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Just put it together like the book says, and stop worrying about the physics of it.
Re: Lower contol arm bushings [Re: Supercuda] #2362529
08/30/17 09:14 PM
08/30/17 09:14 PM
fredericksburg,va
fredericksburg,va
Originally Posted By Supercuda
What steel pin?
This..
Re: Lower contol arm bushings [Re: 11secaarcuda] #2362543
08/30/17 09:51 PM
08/30/17 09:51 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Do you think it's attached to that pin?
I already explained how it attached.
Re: Lower contol arm bushings [Re: Supercuda] #2362550
08/30/17 10:07 PM
08/30/17 10:07 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Looks to me like he just answered the question,
"What steel pin?". shruggy
I have mechanical Aptitude.
I can screw up anything.
Re: Lower contol arm bushings [Re: 11secaarcuda] #2362551
08/30/17 10:07 PM
08/30/17 10:07 PM
Kirkland, Washington
Pacnorthcuda Offline
The bushing is pressed onto the machined end (right side in the pic above). They are a pain to remove.
Re: Lower contol arm bushings [Re: krautrock] #2362558
08/30/17 10:17 PM
08/30/17 10:17 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
Originally Posted By krautrock
supposed to do final torque on the LCA bushings while the car is at ride height.
it's probably fine to snug the LCA nuts down so it pulls the arm into the kmember but no further than just snug.
same with the strut rod bushings and the upper control arm bushings.
i believe the ball joints and tie rod stuff is fine to torque down whenever...
FSM mentioned the shock bolts too, don't recall a mention of the upper control arm but it makes sense and after the alignment loosen/tighten I'd think that would be good
Re: Lower contol arm bushings [Re: 11secaarcuda] #2362566
08/30/17 10:21 PM
08/30/17 10:21 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
Hers's a comparison for ya.
DON'T mess with AC Delco non concentric
I took these photo's myself in my garage of parts I orderded.
Measure your Moog upper control bushings is all I wll say...... been there
Re: Lower contol arm bushings [Re: cudaman1969] #2362568
08/30/17 10:24 PM
08/30/17 10:24 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
...Already winter on Moparts?
Re: Lower contol arm bushings [Re: UCUDANT] #2362643
08/31/17 12:31 AM
08/31/17 12:31 AM
BDW Online content
BDW  Online Content
The AC parts look better to me?'
The offset bushings are supposed to be offset?
Am I missing something
Re: Lower contol arm bushings [Re: DAYCLONA] #2362912
08/31/17 04:16 PM
08/31/17 04:16 PM
fredericksburg,va
fredericksburg,va
Cool, just trying to make people question instead of just taking for granted.
Re: Lower contol arm bushings [Re: BDW] #2362935
08/31/17 04:52 PM
08/31/17 04:52 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Don't think they offer offset on the lowers. The uppers can be had that way, but stock, no.
Page 2 of 3 1 2 3
