Re: Stud installation?
[Re: Clanton]
#2362384
08/30/17 03:58 PM
08/30/17 03:58 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Hand snug in to make sure they go in the whole way then 1/2 a turn (at least) or so out. That way you torque against the threads.
[Re: fourgearsavoy]
#2362577
08/30/17 10:43 PM
08/30/17 10:43 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Think about how most studs are made with coarse threads on the bottom and fine thread on the torque side (usually) and it becomes easier to understand. In torquing we are pulling against the threads to the desiired stretch of the stud. The fine thread gives us better finer touch and better clamping force. At least that's what my Millwright training taught me.
[Re: pittsburghracer]
#2363104
08/31/17 10:44 PM
08/31/17 10:44 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Hand snug in to make sure they go in the whole way then 1/2 a turn (at least) or so out. That way you torque against the threads. SORRY! re-read the reply.. Here is my argument against tightening studs... If you "tighten" studs, you are only adding unnecessary stress to the parent material. Whatever stress you put on the threads before final assembly torque gets added to load stress on the parent material. Torque ratings of studs are guidelines to assure proper stretch of the stud for fastener retaining... To little and nuts will loosen/ to tight and you will stretch/break studs or damage threads. Being that studs are effectively a gear reduction device(already loading parent material more than a bolt torqued to the same LB/ft) you are only adding undue stress to the parent material without any benefit of fastener retaining effect. The bearing under the stud trick is a great solution for installing studs with Loctite. Drop in a bearing ball, apply the Loctite, finger tighten the stud to displace the Loctite to the non-load side of the threads. This gives direct contact of stud to parent material without "squishing" Loctite when torquing.
[Re: TRENDZ]
#2363115
08/31/17 10:55 PM
08/31/17 10:55 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Who said I tighten the studs. You better reread it
[Re: rt66jim]
#2363122
08/31/17 11:01 PM
08/31/17 11:01 PM
TRENDZ
Milwaukee WI
Yep look at my post edited with minor apology! My badd
[Re: rt66jim]
#2363343
09/01/17 11:02 AM
09/01/17 11:02 AM
Posts: 3,527 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
Hi Bill,
MP rockers using 3" studs on 4 of them and one 2 1/2". Needed the short one under the breather cap baffle. Could probably have gotten by with all 2 1/2" ones. I got the 12 point nuts from ARP via Summit. Thanks Jim, I can't remember what size we tried but it seems like if the stud was long enough to get a thread started on it, the nut would bottom out on the end of the threads before it would tighten. I don't know what would be different about the Ersons. How long are your valves? Bill
[Re: 340Cuda]
#2363358
09/01/17 11:22 AM
09/01/17 11:22 AM
RapidRobert
^^^ all good info, I got an edumacation today (& I have a studded 360). thank you!
[Re: rt66jim]
#2363393
09/01/17 12:09 PM
09/01/17 12:09 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
On the finger tight statement. just using your finger to thread in a stud to " finger tight " doesn't mean it is set to the proper depth in the hole. Most studs have a hex key hole in the end . A allen wrench should be used to thread in the stud to bottom, then 1/2 turn back. We all should remember that all readers of there post are not seasoned engine builders.
[Re: 340Cuda]
#2363501
09/01/17 02:37 PM
09/01/17 02:37 PM
Posts: 4,002 Joplin, Mo
rt66jim
Joplin, Mo
[quote=rt66jim]Hi Bill,
MP rockers using 3" studs on 4 of them and one 2 1/2". Needed the short one under the breather cap baffle. Could probably have gotten by with all 2 1/2" ones. I got the 12 point nuts from ARP via Summit. Thanks Jim, I can't remember what size we tried but it seems like if the stud was long enough to get a thread started on it, the nut would bottom out on the end of the threads before it would tighten. I don't know what would be different about the Ersons. How long are your valves? Bill Bill, I don't remember the exact valve stem length. Heads are setup 2" from spring seat to bottom of the retainer.
[Re: rowin4]
#2363610
09/01/17 05:12 PM
09/01/17 05:12 PM
TRENDZ
Milwaukee WI
On the finger tight statement. just using your finger to thread in a stud to " finger tight " doesn't mean it is set to the proper depth in the hole. Most studs have a hex key hole in the end . A allen wrench should be used to thread in the stud to bottom, then 1/2 turn back. We all should remember that all readers of there post are not seasoned engine builders. If you need a wrench of any sort to run in a stud, you are either in need of hole cleaning/repair or you have the wrong studs. The hex head stud is a "recent" (I'm old) development to aid in removal of studs... not for installation. Not even a bottoming tap will allow a quality stud to bottom it's tip in a hole. What you are feeling as resistance is the final thread taper cut which you do not want to be engaged in when tourqing the stud. Take my free advice... It has value.
[Re: TRENDZ]
#2363858
09/02/17 01:18 AM
09/02/17 01:18 AM
RapidRobert
OK, should I drop the ball bearing in there?
