Manual steering box rebuild or new
#2362107
08/30/17 12:58 AM
08/30/17 12:58 AM
Posts: 2,403 WASHINGTON, PA
11secaarcuda
WASHINGTON, PA
Looking for suggestions for either having my stock manual steering box rebuilt for my Dart, or purchasing a new unit if available. What have you guys done?
67 Dart GT 340 4 speed 70 AAR Cuda 408 6 barrel 96 Indy Ram original owner 2011 Hemi Durango
Re: Manual steering box rebuild or new
[Re: 11secaarcuda]
#2362251
08/30/17 11:53 AM
08/30/17 11:53 AM
RapidRobert
Too much steering wheel play I am assuming. I would locate the shop manual adjustment procedure which involves the top slotted bolt and the large ring nut (I forget the proper name for it) on the rear side & see if that procedure fixes you up.
[Re: 11secaarcuda]
#2362460
08/30/17 06:31 PM
08/30/17 06:31 PM
Posts: 5,439 So Cal
Sinitro
So Cal
The Flaming River Mopar manual box is built in Argentina. Mancini Racing sells a 16 to 1 manual rebuilt box as well.. Just my $0.02...
[Re: 11secaarcuda]
#2362481
08/30/17 07:18 PM
08/30/17 07:18 PM
Posts: 4,457 Washington
madscientist
Washington
Firm Feel has all the parts you need to rebuild it yourself.
It's actually pretty simple.
[Re: madscientist]
#2362482
08/30/17 07:20 PM
08/30/17 07:20 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
It's actually pretty simple. Bullseye...
[Re: RSNOMO]
#2362846
08/31/17 01:54 PM
08/31/17 01:54 PM
RapidRobert
As needed (1) adj your current one (2) rebuild your current one (3) $300 for a new 16:1 ain't too bad & there was some good threads on if the steering input was acceptable on the street, alot had to do with tire/rim size. when we went to a 16:1 on the A body stock car it was a night and day great improvement difference in the corners, before (with the 24:1) it was a hand over hand discombobulation to turn. they are pretty trouble free, I would for sure adj it correctly & see if it turns smoothly by hand lock to lock then install it & if good on your bench then highly likely its all good.
[Re: Stanton]
#2362880
08/31/17 02:55 PM
08/31/17 02:55 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
A 16:1 box takes 30% more effort to turn - simple math. This can mean the difference between one hand steering and two hands. Two hands is arguably safer BUT who always has two hands on the wheel !! Just some things to consider. And at speed it's almost irrelevant. Trying to parallel park, yeah you'll feel it but pretty anything above a walking speed and you won't notice.
[Re: Supercuda]
#2363830
09/02/17 12:26 AM
09/02/17 12:26 AM
Posts: 5,439 So Cal
Sinitro
So Cal
A 16:1 box takes 30% more effort to turn - simple math. This can mean the difference between one hand steering and two hands. Two hands is arguably safer BUT who always has two hands on the wheel !! Just some things to consider. And at speed it's almost irrelevant. Trying to parallel park, yeah you'll feel it but pretty anything above a walking speed and you won't notice. Correcto.. Parallel parking requires significant muscle effort but... Also also if one is running radial tires this too requires more muscle as well... Just my $0.02...
[Re: Sinitro]
#2363992
09/02/17 11:55 AM
09/02/17 11:55 AM
Supercuda
About to go away
About to go away
up yours
A 16:1 box takes 30% more effort to turn - simple math. This can mean the difference between one hand steering and two hands. Two hands is arguably safer BUT who always has two hands on the wheel !! Just some things to consider. And at speed it's almost irrelevant. Trying to parallel park, yeah you'll feel it but pretty anything above a walking speed and you won't notice. Correcto.. Parallel parking requires significant muscle effort but... Also also if one is running radial tires this too requires more muscle as well... Just my $0.02... And what requires even more effort is a power steering setup with no power, did that for a couple years in my 64 300, with fat radials up front too. I lived. It's kind of like the .45 kicks myth. It kicks in the hands of those who have never fired one and fast ratio steering is hard in the hands of those who have never had it.
