hood and e.t lose #2361999
08/29/17 10:28 PM
08/29/17 10:28 PM
Bad Axe,MI
E
EDDIEB Offline OP
EDDIEB  Offline OP
E
Bad Axe,MI
Got a crack in my 6 pack hood and want to do some more racing this year,what loss in e.t. do you think I would see running with out a hood? Car is a 10.50 car
Re: hood and e.t lose [Re: EDDIEB] #2362040
08/29/17 11:17 PM
08/29/17 11:17 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Probably won't slow down at all, maybe have more mph. 6 pack hood on my car pulls a lot of air in the 1/4 mile, tries to pick the hood up by the scoop. I finally put a dzus button in the center of the hood to a bracket to keep it from coming up. I don't have a problem with it when I run 1/8 mile class. If you run a good air cleaner you'll be fine.
Brian
Re: hood and e.t lose [Re: EDDIEB] #2362043
08/29/17 11:21 PM
08/29/17 11:21 PM
TN
1DGEMAN Offline
1DGEMAN  Offline
TN
It is possible it could affect how the car handles. No time to do a fiberglass fix?
Real Men shift for themselves
Re: hood and e.t lose [Re: EDDIEB] #2362184
08/30/17 09:18 AM
08/30/17 09:18 AM
Locomotion Offline
Locomotion  Offline
Might need to jet a bit leaner. But it all depends how close the jetting was to the fresh air set-up and how well it worked originally. (i.e.: turbulence, seal, etc.) Make sure the top of the carb isn't too close to the bottom of the new hood.
It may actually be more consistent. Underhood air is more consistent and a good bracket racer I know actually blocked of his '68 Cuda Hemi-style scoop with clear lexan or plexiglass.
Re: hood and e.t lose [Re: EDDIEB] #2362310
08/30/17 01:37 PM
08/30/17 01:37 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
My old car didn't show any loss when I put my 6 pack hood from pro stock scoop
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: hood and e.t lose [Re: 67mprfan] #2362317
08/30/17 02:00 PM
08/30/17 02:00 PM
Bad Axe,MI
E
EDDIEB Offline OP
EDDIEB  Offline OP
E
Bad Axe,MI
I won't be running a hood at all
Re: hood and e.t lose [Re: EDDIEB] #2362475
08/30/17 07:03 PM
08/30/17 07:03 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
HI Eddie, hope you are well.I lost no et at all but the hood wasn't sealed, if i were you i'd definitely run a decent filter.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
